Full Version: Polygonal Converter.
Show messages:  1-9  …  190-209  210-229  230-249  250-269  270-289  290-309  310-329  …  470-483
25 Mar 2015   [#250]
Very cool!
25 Mar 2015   [#251]
@Max
Does it possible after a _sSplit to have the "flat inset rectangles" selected ?
here the 4 yellow ones on the bridge!
25 Mar 2015   [#252]
Max.
Brilliant work like this shouldn't go unrewarded.
Can I suggest you get a Bitcoin wallet and start accepting donations through it?
Martin.
25 Mar 2015   [#253] In reply to [#243]
Hey Max,
"""""""""I decided to write all subdTools scripts with basic functionality, and only after that I'll start to improve them."""""""""""
As someone who would love for you to start pumping out tools, I wanted to ask about the initial subD Command you've written.
Is there any more that can be done with this? Mostly regarding the lack of tangency and curvature between patches...... (It's kindof a killer for me personally)
Going along with your quote above, maybe you could do "all that you can" with this as the "main tool of the bag", before all the "timesaver" trick scripts.....
Thanks again :)
25 Mar 2015   [#254]
sBridge - small bugfix
sSplit - n-gons support
sScale - new script
25 Mar 2015   [#255] In reply to [#253]
Hi BurrMan
I have some difficulties with subd script. Unfortunatelly Moi javascript tools has very limited nurbs functionality. I can build curves of degree 2 or 3 only. I can't ajust control points weights. I can't build curves with double knots. etc..
So I need to find the way how to improve my script in this situation. But right now I'm tired of it. I need to switch to something else. So I decided to take a rest and write several simple scripts. After few weeks I'll continue my experiments with the main script.
25 Mar 2015   [#256] In reply to [#255]
Understood.. Thanks again... :)
25 Mar 2015   [#257]
Excellent! What a productivity! Bravo!
PS sScale : what is the difference with View Points and use the Edit Frame ?
A trick for the sSplit : don't select the volume only, but select the volume then use the Browser for select faces! ;)
26 Mar 2015   [#258]
@Max
sSPlit
Does it possible to have Ngons like this ?
And selected just after the sSplit ? :)
26 Mar 2015   [#259]
Hi Pilou
How did you make the pentagon, and put the split inside?
I an trying to make a cup
26 Mar 2015   [#260]
I figured i out :-)
first a pentagon
Then sSplit on both side, extrude the inner part to perform the bottom
sSplit on the side for the handle and copy the faces to direct the handle
sBridge it
And Subdiv
2015.03.26-14.22.00-[3D].png  2015.03.26-14.22.13-[3D].png  2015.03.26-14.22.35-[3D].png  2015.03.26-14.23.05-[3D].png  2015.03.26-14.34.02-[3D].png  2015.03.26-14.34.12-[3D].png
26 Mar 2015   [#261] In reply to [#259]
Function Draw Curve Polygon
Extrude
Kill first polygon curve generator if not need
The trick : Select volume so a solid but sSplit need only faces!
So after select volumum (solid) use the Browser button for choise Faces ;)
Then use sSplit !
Et voilĂ
26 Mar 2015   [#262]
Excelent trick - merci
26 Mar 2015   [#263] In reply to [#262]
For kill the internal best is redraw a polygonal volume inside and make a boolean diff!
26 Mar 2015   [#264]
Dedicated thread for Max's SubD Scripts?
With Max working on new scripts and folks experimenting and sharing results, maybe all posts related to his SubD work should go into a new thread.
26 Mar 2015   [#265]
edgeSplit preview
26 Mar 2015   [#266]
A cup of tea! :)
26 Mar 2015   [#267]
Frenchy Pilou
No differences in the v0.5. Check the new one.
My script determines center by averaging a source points. Edit frame uses boundary box center.
It's possible, but not now. My subd script doesn't support ngons.
blowlamp
Thank you. I'll think about it :)
26 Mar 2015   [#268] In reply to [#267]
Cool last one!
26 Mar 2015   [#269] In reply to [#265]
Great work Max, thanks for sharing all of these new tools!
