Full Version: Polygonal Converter.
Show messages:  1-6  …  167-186  187-206  207-226  227-246  247-266  267-286  287-306  …  467-483
19 Mar 2015   [#227]
Max, Frenchy or anyone else.
Are the files at the front of this thread the latest and most current? If not, is there a standard place one can go to to get the most recent? Thanks for all the great work!!
20 Mar 2015   [#228] In reply to [#227]
It appears that the most recent versions are in the more recent posts...
So start from the last post and work backwards...:-)
20 Mar 2015   [#229]
Yes! Stay awake! ;)
22 Mar 2015   [#230] In reply to [#192]
I have a big problem, I used today SUBDIV Script first time, but now I can not import any OBJ, also after deleting the script I couldn't import any OBJ .. I didn't see that option since now ---
22 Mar 2015   [#231] In reply to [#230]
Hi Lordfox, re:
Sorry I don't understand this part - MoI does not itself import OBJ files, it's handled by Max's import script. So therefore if you delete the script like you say here then it's normal that you will not be able to import OBJs, because you just deleted the script that can do it.
Maybe you mean something else than that though?
22 Mar 2015   [#232] In reply to [#230]
HI Lordfox, re: image attachment - yes that's normal that you wont' see OBJ listed there. MoI does not natively handle OBJ importing, if you want to do it, you need to use Max's plug-in command to do it. The plug-in is run as its own command, it will not show up in the file types list that you are showing there.
Currently MoI does not have any mechanism for plug-ins to extend the main file open dialog box. I do want to add that in the future but for now since there is no way for a plug-in to in to modify that standard list it's implemented as its own specific named command that you have to launch, rather than trying to use the regular File > Open.
22 Mar 2015   [#233]
I'm sorry dear .. its okay, it works fine ... the subdiv script (beta 6) + the OBJ Importer. So happy :)
22 Mar 2015   [#234]
Tiny but useful script - sBridge. The first one from my new set of tools for subdiv modelling.
This script makes connection between two polygonal faces.
22 Mar 2015   [#235] In reply to [#234]
Subd modeling in MoI, how cool is that!
22 Mar 2015   [#236]
Very Cool !
Can we dream of something like Bridge 2 Faces of a same volume ?
Like this crazzy free TopMod ? http://code.google.com/p/topmod/
23 Mar 2015   [#237]
Hi Max,
Its quite usefull, thank you!
23 Mar 2015   [#238] In reply to [#235]
Wow,that is amazing
23 Mar 2015   [#239] In reply to [#238]
Bridge , sweet sound ....
Excellent work "Maestro"
23 Mar 2015   [#240]
"… The first one from my new set of tools for subdiv modeling."
That’s good news Max. Even if your planned toolkit handles just the basic SubD functions, it sounds like many of the organic shapes people attempt to make in MoI might be possible.
For someone who is already comfortable using MoI and doesn’t require SubD often enough to completely learn a new program, your scripts can fill a real need.
24 Mar 2015   [#241]
This is amazing!!!
24 Mar 2015   [#242]
Very sweet tools Max!
Michael T.
24 Mar 2015   [#243]
Thanks everyone for positive comments :)
I rewrote the Bridge script. No new functions at the moment, but internal logic has been changed. This is a first step to bended bridges.
Also I wrote a script for polygon splitting. As Bridge it's very simple right now.
I decided to write all subdTools scripts with basic functionality, and only after that I'll start to improve them.
24 Mar 2015   [#244]
chippwalters
The latest version you can get here:
http://moi.maxsm.net/media/files/
Frenchy Pilou
Yes. I have plans to make something like this.
24 Mar 2015   [#245]
Totally awesome. I'm well covered with SubD tools, but being able to do this in MoI and with NURBS is awesome!
Thank you so much!
Tom
24 Mar 2015   [#246]
Excellent!
Split = the classical Inset function!
