Full Version: Polygonal Converter.
Show messages:  1-12  …  153-172  173-192  193-212  213-232  233-252  253-272  273-292  …  473-483
9 Mar 2015   [#213] In reply to [#212]
Excellent Lawrence.
I've never used a poly modeler as I work with mechanical shapes. But Max's script seems to fill a gap where you want the precision of Nurbs, but need some organic influence.
It's great this can be done entirely inside MoI. Probably not the preferred tool set to model a human head, but your eyeglass model is a perfect example of how I would want to use this script.
10 Mar 2015   [#214] In reply to [#213]
I do not think that pseudo Poly technique with Loft as was shown with glasses can replace Polygons and Sub-D. What you can do inside MoI trying to replicate SubD with Max's plugin is very primitive shapes. Now MoI has SubD module but do not have any good polygonal tools.
10 Mar 2015   [#215] In reply to [#214]
Hi Andrei,
i agree with you, MoI is not a polygonal modeler.
Perhaps some capabilities will come with version V6 or V7. I don't think that is a priority.
But I like to experiment this "pseudo technique" even if at begining i don't know where i go. Here it seems to be a snake skull :)
10 Mar 2015   [#216] In reply to [#215]
LAWRENCE, how many time you spent for this skull :)?
10 Mar 2015   [#217] In reply to [#216]
> how many time you spent for this skull ?
a moment of inspiration : one hour
10 Mar 2015   [#218] In reply to [#217]
You are real experimentalist :)!
11 Mar 2015   [#219]
Well, I've been having a lot of fun with it!
Michael T.
14 Mar 2015   [#220]
ImportObj v1.2
New and almost fully rewritten version of the ImportObj script.
Now it always uses loft for triangles and quads and as a result produces a clean and editable grid.
Also improved normalization algorithm and overall speed.
Use "exact" parameter to disable normalization.
14 Mar 2015   [#221]
Cool!
Not yet French version but French section :)
http://moiscript.weebly.com/_importobj.html
14 Mar 2015   [#222] In reply to [#220]
To: Max Smirnov (SMIRNOV)
Wonderful coding.
-JC
P.S. - Again, Thank you , from a Poly to NURBS Fan!
You're on the cutting edge here (more than some may comprehend) - FOLLOW THAT IDEA!
15 Mar 2015   [#223]
Thanks Max, works great!!!
D/L file just needs to be renamed with ".zip" extension.
15 Mar 2015   [#224]
ImportObj v1.3 :)
Added status info.
Some internal changes.
19 Mar 2015   [#225]
ImportObj 1.4
Made some fixes to avoid loft bug with very small values
19 Mar 2015   [#226]
Thanks Max, amazing stuff!
19 Mar 2015   [#227]
Max, Frenchy or anyone else.
Are the files at the front of this thread the latest and most current? If not, is there a standard place one can go to to get the most recent? Thanks for all the great work!!
20 Mar 2015   [#228] In reply to [#227]
It appears that the most recent versions are in the more recent posts...
So start from the last post and work backwards...:-)
20 Mar 2015   [#229]
Yes! Stay awake! ;)
22 Mar 2015   [#230] In reply to [#192]
I have a big problem, I used today SUBDIV Script first time, but now I can not import any OBJ, also after deleting the script I couldn't import any OBJ .. I didn't see that option since now ---
22 Mar 2015   [#231] In reply to [#230]
Hi Lordfox, re:
Sorry I don't understand this part - MoI does not itself import OBJ files, it's handled by Max's import script. So therefore if you delete the script like you say here then it's normal that you will not be able to import OBJs, because you just deleted the script that can do it.
Maybe you mean something else than that though?
22 Mar 2015   [#232] In reply to [#230]
HI Lordfox, re: image attachment - yes that's normal that you wont' see OBJ listed there. MoI does not natively handle OBJ importing, if you want to do it, you need to use Max's plug-in command to do it. The plug-in is run as its own command, it will not show up in the file types list that you are showing there.
Currently MoI does not have any mechanism for plug-ins to extend the main file open dialog box. I do want to add that in the future but for now since there is no way for a plug-in to in to modify that standard list it's implemented as its own specific named command that you have to launch, rather than trying to use the regular File > Open.
