Full Version: Polygonal Converter.
Show messages:  1-6  …  147-166  167-186  187-206  207-226  227-246  247-266  267-286  …  467-483
26 Feb 2015   [#207]
Max,
Where would I find this command?
>>Use "_ImportObj exact" command to disable this function.
Michael T.
26 Feb 2015   [#208] In reply to [#206]
Hi Max,
The plan sounds good :)
27 Feb 2015   [#209] In reply to [#207]
Hi Michael
"exact" - it is not a script. It's a script parameter.
Type or bind command: _ImportObj exact
Last version of the ImportObj: http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.201
27 Feb 2015   [#210] In reply to [#209]
Thanks Max!
Michael T.
9 Mar 2015   [#211]
Going off Michael's example in another thread, I wanted to make a shape by joining two solids (created with sweeps) using a loft. Works well.
Next I'll have to try making a real object.
9 Mar 2015   [#212] In reply to [#211]
Hi Ed,
i also try making real object (with sweep, boolean, mirror , cut and join, and moving some point)
it's pleasant to try to do everything with MoI (without import)
9 Mar 2015   [#213] In reply to [#212]
Excellent Lawrence.
I've never used a poly modeler as I work with mechanical shapes. But Max's script seems to fill a gap where you want the precision of Nurbs, but need some organic influence.
It's great this can be done entirely inside MoI. Probably not the preferred tool set to model a human head, but your eyeglass model is a perfect example of how I would want to use this script.
10 Mar 2015   [#214] In reply to [#213]
I do not think that pseudo Poly technique with Loft as was shown with glasses can replace Polygons and Sub-D. What you can do inside MoI trying to replicate SubD with Max's plugin is very primitive shapes. Now MoI has SubD module but do not have any good polygonal tools.
10 Mar 2015   [#215] In reply to [#214]
Hi Andrei,
i agree with you, MoI is not a polygonal modeler.
Perhaps some capabilities will come with version V6 or V7. I don't think that is a priority.
But I like to experiment this "pseudo technique" even if at begining i don't know where i go. Here it seems to be a snake skull :)
10 Mar 2015   [#216] In reply to [#215]
LAWRENCE, how many time you spent for this skull :)?
10 Mar 2015   [#217] In reply to [#216]
> how many time you spent for this skull ?
a moment of inspiration : one hour
10 Mar 2015   [#218] In reply to [#217]
You are real experimentalist :)!
11 Mar 2015   [#219]
Well, I've been having a lot of fun with it!
Michael T.
14 Mar 2015   [#220]
ImportObj v1.2
New and almost fully rewritten version of the ImportObj script.
Now it always uses loft for triangles and quads and as a result produces a clean and editable grid.
Also improved normalization algorithm and overall speed.
Use "exact" parameter to disable normalization.
14 Mar 2015   [#221]
Cool!
Not yet French version but French section :)
http://moiscript.weebly.com/_importobj.html
14 Mar 2015   [#222] In reply to [#220]
To: Max Smirnov (SMIRNOV)
Wonderful coding.
-JC
P.S. - Again, Thank you , from a Poly to NURBS Fan!
You're on the cutting edge here (more than some may comprehend) - FOLLOW THAT IDEA!
15 Mar 2015   [#223]
Thanks Max, works great!!!
D/L file just needs to be renamed with ".zip" extension.
15 Mar 2015   [#224]
ImportObj v1.3 :)
Added status info.
Some internal changes.
19 Mar 2015   [#225]
ImportObj 1.4
Made some fixes to avoid loft bug with very small values
19 Mar 2015   [#226]
Thanks Max, amazing stuff!
