Full Version: Polygonal Converter.
Show messages:  1-8  …  89-108  109-128  129-148  149-168  169-188  189-208  209-228  …  469-483
14 Feb 2015   [#149] In reply to [#148]
sorry, no i haven't...
Where can i find it ?
can i install both version on my mac ? V2 and V3 ?
thanks
14 Feb 2015   [#150] In reply to [#149]
beta1 http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.82
beta2 http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.117
All versions of the script works with MoI V3 only.
14 Feb 2015   [#151] In reply to [#150]
i've tested with beta1 and beta2 and it's the same issue > the Subdivision panel disappear
in fact, the script run only with very simple object with low polygon (as cup in attachment)
but fail with more complex objects as hypo also in attachment
14 Feb 2015   [#152] In reply to [#151]
I wrote a new version of importObj script. Now it works much better with twisted polygons.
I've tested this model with different version of subdiv script. Beta 2 and 3 works good. In beta 4 I wrote new LoadMesh function. Seems it have problem with this mesh. I'll check it today evening.
14 Feb 2015   [#153] In reply to [#152]
always the same problem
panel subdivision split and disapear
14 Feb 2015   [#154] In reply to [#153]
I need more information.
MoI version, script version, 3dm model (not obj. I need exactly that model, which you are trying to subdivide.)
14 Feb 2015   [#155] In reply to [#154]
hypo.obj
MoI V3 (mac OS X)
_Subdiv_beta5, 4 ,2 or 1
14 Feb 2015   [#156] In reply to [#155]
Hypo.obj is opened surface. Subdiv script works with solids only.
14 Feb 2015   [#157] In reply to [#156]
ah ok !
14 Feb 2015   [#158] In reply to [#157]
Anyway thank you :)
With your help I found a bug in LoadMesh function :)
Upd: fixed
14 Feb 2015   [#159]
Well done Max!
Had a lot of fun with your importObj & Subdivision plugins.
Got this model from http://opengameart.org/content/low-poly-base-meshes-male-female
Dinos
14 Feb 2015   [#160]
<< I found a bug in LoadMesh function :)
<< Upd: fixed
So where are the last releases of load OBJ and Polygonal convertor ?
15 Feb 2015   [#161] In reply to [#160]
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.152
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.145
17 Feb 2015   [#162]
Just made some work and got this results first is original polygonal model, second is from T-Spline third from Max last beta.
T-Spline makes even less surfaces than on original but Max's script much more. Looks like a lot of geometry optimization must be done.
17 Feb 2015   [#163] In reply to [#162]
As I wrote before, it's just a first part of the script. The second phase is stiching surfaces with ordinary edges.
btw, can you check number of control point in t-spline model.
18 Feb 2015   [#164]
Bonus script :) Subdiv Classic..
I wrote this script few months ago for testing purposes.
It produces subdivided polygonal surfaces using classical Catmull-Clark algorithm.
18 Feb 2015   [#165] In reply to [#164]
Hi Max,
Thanks a lot for the last update, I'm really impressed by the result (and I can be very anal with that kind of stuff :)) ... I have the impression that poles area are looking even better than what I've seen
with Npower sub-d Nurbs Oo ... the overall shape is much better now too !
EDIT
The last .obj loader works much better, but well ... it still fails with a lot of my testing models (some sds cage model topology can be very distorted, with extreme non-planar quads).
Wish I could start to promote your converter with some famous models from the modo library (like the hypo, or the old man that npower also use for their own promotional material).
Maybe Michael can give you some advice in that area ?, he should know lots of stuff about file format ... because the converter itself is really amazing !
I hope the surface optimization will not change anything about the overall continuity quality !
19 Feb 2015   [#166]
So just to compare,
Max rules !
19 Feb 2015   [#167]
Hi Max,
Here's the oldman model already imported in MoI.
Looks like the geometry is ok (I had to join all surfaces in Moi, every faces were splitted after the import).
However the Beta5 don't seems to like it ... the object and the interface just vanish after few second.
19 Feb 2015   [#168] In reply to [#167]
I've tested the Oldman on Mac OS X 10.10.2 and MoI V3.
1• open the Oldman.3dm
2• select the solid object
3• use Tab and type : _Subdiv_beta5
Result : object and subdivision panel disappears and have an empty vue.
