Full Version: Polygonal Converter.
Show messages:  1-19  …  80-99  100-119  120-139  140-159  160-179  180-199  200-219  …  480-483
3 Feb 2015   [#140]
Finema
>any idea about my problem above ?
Sorry, I don't have a mac. But it's very strange, it should work.
3 Feb 2015   [#141] In reply to [#140]
Max,
I've tested all the example in this thread (and more) and none are running.
I've a 2 x 2,8 GHz Quad-Core Intel Xeon Mac Pro and 6 Go ram.
The Subdivision panel displays a split second and disappears.
No other Mac user had this problem ? It's curious...
Thanks...
4 Feb 2015   [#142] In reply to [#141]
Hi, yes I am a mac user as well and when running the script I see a window flashing up on the left upper corner and that is it.
Maybe this will be resolved soon but anyway your work is awesome !!
4 Feb 2015   [#143] In reply to [#142]
For me the subd script works well with MoI 2.52 (have not updated yet to 3.0) under OSX 10.8.5 with my old iMac.
4 Feb 2015   [#144] In reply to [#141]
Finema
Kroet
Check beta1 or beta2. Does it work?
13 Feb 2015   [#145]
Beta 5.
Fixed bug with high valence vertices (>16-20)
Some surface tuning. Not perfect, but smoother than beta4.
b4 - red, b5 - green
Upd: Fixed tolerance bug, which may cause errors while importing very small models. Reuploaded.
13 Feb 2015   [#146]
Voluptuous!
14 Feb 2015   [#147] In reply to [#146]
As in the beta4, The Subdivision panel displays a split second and disappears.
14 Feb 2015   [#148] In reply to [#147]
have you tried to use beta 1 or 2?
14 Feb 2015   [#149] In reply to [#148]
sorry, no i haven't...
Where can i find it ?
can i install both version on my mac ? V2 and V3 ?
thanks
14 Feb 2015   [#150] In reply to [#149]
beta1 http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.82
beta2 http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.117
All versions of the script works with MoI V3 only.
14 Feb 2015   [#151] In reply to [#150]
i've tested with beta1 and beta2 and it's the same issue > the Subdivision panel disappear
in fact, the script run only with very simple object with low polygon (as cup in attachment)
but fail with more complex objects as hypo also in attachment
14 Feb 2015   [#152] In reply to [#151]
I wrote a new version of importObj script. Now it works much better with twisted polygons.
I've tested this model with different version of subdiv script. Beta 2 and 3 works good. In beta 4 I wrote new LoadMesh function. Seems it have problem with this mesh. I'll check it today evening.
14 Feb 2015   [#153] In reply to [#152]
always the same problem
panel subdivision split and disapear
14 Feb 2015   [#154] In reply to [#153]
I need more information.
MoI version, script version, 3dm model (not obj. I need exactly that model, which you are trying to subdivide.)
14 Feb 2015   [#155] In reply to [#154]
hypo.obj
MoI V3 (mac OS X)
_Subdiv_beta5, 4 ,2 or 1
14 Feb 2015   [#156] In reply to [#155]
Hypo.obj is opened surface. Subdiv script works with solids only.
14 Feb 2015   [#157] In reply to [#156]
ah ok !
14 Feb 2015   [#158] In reply to [#157]
Anyway thank you :)
With your help I found a bug in LoadMesh function :)
Upd: fixed
14 Feb 2015   [#159]
Well done Max!
Had a lot of fun with your importObj & Subdivision plugins.
Got this model from http://opengameart.org/content/low-poly-base-meshes-male-female
Dinos
