Full Version: Polygonal Converter.
Show messages:  1-4  …  45-64  65-84  85-104  105-124  125-144  145-164  165-184  …  465-483
9 Oct 2014   [#105] In reply to [#104]
Made a small pdf for the customUI Objects, to be placed along with the tetrus .3dm in the Objects folder, if so desired.
I had to manually set the background color in Moi to white, then reset it to the saved "grey" color rgb.
Is there a script way to temporarily set the background color white, and restore the "grey"?
The porcelain lighting seemed to match the 3 default objects.
http://moi3d.com/forum/index.php?webtag=MOI&msg=5410.6
9 Oct 2014   [#106] In reply to [#105]
Hi Brian, check out here for a script that saves the current viewport background color, then sets it to white, then takes a screenshot, then restores the starting color back:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4559.2
9 Oct 2014   [#107] In reply to [#103]
That'd be fantastic, Max, keep up the great work!
9 Oct 2014   [#108] In reply to [#106]
Thank you Michael.
The script works very well.
9 Oct 2014   [#109]
Max,
When I import my OBJ I get a strange error. The mesh is 816 polygons and when I run the Subd converter the mesh just disappear.
Grip.obj
9 Oct 2014   [#110] In reply to [#109]
I did not think that Moi would import .obj format.
9 Oct 2014   [#111] In reply to [#110]
@ Brian
It will if you use Max's importObj script from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.68
That will import quads or triangles (not n-gons) from an .obj file.
9 Oct 2014   [#112] In reply to [#111]
Thank you Michael.
I did download that last week.
It is hard to keep track... :-)
10 Oct 2014   [#113] In reply to [#111]
Michael
importObj supports n-gons :)
Sonk
All polygon points must lay in the same plane, or you will get Geometry error.
In this case script tries to create a curved surface through those points.
I'll check it.
10 Oct 2014   [#114] In reply to [#113]
Hi Max,
Oops, I see now I didn't read it close enough - I saw the if (edges.length<5) part and I thought that was the main thing, but now I see that's only a backup path for if the polygon was not planar enough for planarsrf to construct a surface through it. Sorry!
I guess if the n-gon is non-planar then that will be an issue though?
10 Oct 2014   [#115] In reply to [#114]
Yes, exactly.
Just found a stange obj export bug. When I export "O" letter using n-gon mode, MOI creates four strange polygons instead of normal quads.
f 83/83/83 101/101/101 85/85/85 86/86/86 102/102/102 84/84/84
f 97/97/97 103/103/103 98/98/98 99/99/99 104/104/104 100/100/100
f 105/105/105 137/137/137 106/106/106 107/107/107 138/138/138 108/108/108
f 119/119/119 139/139/139 121/121/121 122/122/122 140/140/140 120/120/120
So importObj can't properly import it.
10 Oct 2014   [#116] In reply to [#115]
Hi Max - it's not unusual to get n-gons possibly with some of their points nearby each other in various juncture areas. There it looks like it's the cut through the middle to deal with the interior hole in the top surface that is probably introducing the points you don't want. That's just part of how the mesher works... OBJ format does not have the concept of a polygon with a hole in it, so any n-gons that would have internal holes within a single n-gon like the top face there will get divided which can easily introduce additional boundary points.
25 Jan 2015   [#117]
Hi!
I'm back (for a while ;)
This weekend I wrote a new beta of subdiv script. Yes :) I finally did it! :)
This version is very unstable, but it works much better with extraordinary vertices. C1 continuous on extraordinary vertices, and C2 on ordinary vertices.
It doesn't support triangles in hq mode yet, so you need to use quads only.
Of course some surface issues may occurs. I think there may be some bugs.
Also I plan to write an optimization block, which can stitch separated ordinary quads to one surface.
25 Jan 2015   [#118] In reply to [#117]
Extraordinary script! ;)
25 Jan 2015   [#119] In reply to [#117]
Hi Max,
Sounds incredible!
Just so I understand how this works...
Can I import an OBJ non sub-divided created in a program light Lightwave, and this script will convert it to NURBS? If so-- WOW!
25 Jan 2015   [#120] In reply to [#119]
Hi Max,
It's late here, so I'll torture your script tomorrow.
I have to say that the results on the provided examples are really amazing.
It's way beyond my expectation, it looks much better on hi-valence point than some commercial plugins Oo
26 Jan 2015   [#121] In reply to [#119]
Hi chippwalters,
The .obj import is here :
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=8e7570bc59ea9e111727dcc1a5a5a3dc&filename=importObj.zip
26 Jan 2015   [#122] In reply to [#121]
Hi chippwalters
This script is more useful for subdivision surface modeling.
Yes, it can process OBJs, but it will produce a huge amount of surfaces. I need to find the way to build more complex surfaces.
But anyway, it works! :)
26 Jan 2015   [#123] In reply to [#122]
Super cool stuff Max!
26 Jan 2015   [#124] In reply to [#122]
Hi Max, some really good looking results in high quality mode!
Only with some more detailed examination with reflective zebra stripes can some G2 discontinuities be seen.
Have you thought any about non-uniform refinement, like with extra density clustered more tightly just around extraordinary vertices rather than uniform refinement?
