Full Version: Cloth simulation
Show messages:  1-3  4-23  24-43  44-63  64-73
15 Feb 2014   [#44]
utf-16 seems works !
19 Feb 2014   [#45]
Wow Max! Great to then use Network on the curves, and shell for thickness! This is truly cool! Thank you so much!
Michael T.
19 Feb 2014   [#46]
New version of the script will be released soon :)
[added] three different types of constraints ( version 0.8 - one type )
[added] flexibility control
[added] increased precision of the cloth structure calculation ( upto 20 iterations per frame. version 0.8 - one iteration)
P.S. This weekend, I hope.
20 Feb 2014   [#47] In reply to [#46]
Cool! :-)
21 Feb 2014   [#48] In reply to [#46]
Nice to see cloth simulation outside Cinema4D as well. :-)
Peace,
Rich_Art. ;-)
21 Feb 2014   [#49]
The new version (v0.95). Even earlier than planned :)
[added] Frame skipping slider (allows to skip frame updating during calculations)
I know about this problem. I'll try to fix it in the next version.
Update (v0.96):
[added] Lock anchor points checkbox (the problem described above is partially solved)
21 Feb 2014   [#50] In reply to [#49]
Very convincing result!
Seems this always only spheres ?
But seems you have had some parameters! :)
21 Feb 2014   [#51] In reply to [#50]
At this moment only spheres and donuts :)).. But I plan to add a new obstacle type - triangles. :)
21 Feb 2014   [#52] In reply to [#51]
Seems donut's don't stop cloth! ( a circle sweeping on a circle)
French Version :) http://moiscript.weebly.com/simulation-tissu.html
21 Feb 2014   [#53] In reply to [#52]
Hint: you can use more than one sphere :)
Use spheres to build a donut.
P.S. Thank you very much for the translation. But you definitly need to enlarge sliders. It's impossible to use the script with such small sliders.
21 Feb 2014   [#54] In reply to [#53]
Ah ok for the trick of the donuts :)
<< But you definitly need to enlarge sliders.
Seems sufficient as you can enter any number on the right's case! :)
And in French words are often more longer than English!
PS What render do you use for your gorgeous images ?
Pss Seems I have a problem!
Gride is exploded when arrive on the spheres!
In fact Spheres were not enough big but curious as they were more bigest than a square of the gride!
Seems sphere must be twice bigger than a "square" of the gride ?
Here gride passes away but the square is smaller than the sphere!
here that works because spheres are biggest :)
Possibilities are endless! :)
(cool your CommandBar Lighting + Dinos for put some car plastic lights! :)
22 Feb 2014   [#55] In reply to [#54]
Hi Pilou
Not any number. Constraints settings can be changed with sliders only.
Octane render (http://render.otoy.com/)
It depends of Timestep value.
Also you can try to increase Shear value to reduce flexibility.
22 Feb 2014   [#56] In reply to [#55]
<< Constraints settings can be changed with sliders only.
Ah, yes you can enter number but you have put some maximum! :)
<< It depends of Timestep value.
So if time is not a good value gride can pass away even it's a little gride! :)
12 Mar 2014   [#57]
Some analogy with this one! ;)
13 Mar 2014   [#58]
top work Max need to have a play with the scripts :)
13 Mar 2014   [#59] In reply to [#57]
cool..
Peace,
Rich_Art. ;-)
24 Feb 2015   [#60] In reply to [#47]
Hi Max,
Have you updated this script since 20 Feb 2014 ?
thanks
24 Feb 2015   [#61]
Really beautiful work Max!
Do you think a reverse-action version of this script could be applied to the scenario of flattening (un-forming / developing) a sheet metal blank that has been pressed over a form block?
- Hamish
25 Feb 2015   [#62]
Finema
Sorry. No. I haven't any plan to improve this script. Maybe later.
Hamish
Thank you :)
Yes, it can be done for a bended or folded surfaces. But not for pressed.
25 Feb 2015   [#63] In reply to [#62]
Thanks Max.
