3-22
23-42
43-62
63-73
utf-8 is equivalent to ascii if there is no "byte order mark" at the start of the file and only uses ascii characters in it.
If you need to use non-ascii characters in a script, try saving it as UTF-16 little endian with byte order mark, the text file loader knows how to load that type of unicode text file.
utf-16 seems works !
Wow Max! Great to then use Network on the curves, and shell for thickness! This is truly cool! Thank you so much!
Michael T.
New version of the script will be released soon :)
[added] three different types of constraints ( version 0.8 - one type )
[added] flexibility control
[added] increased precision of the cloth structure calculation ( upto 20 iterations per frame. version 0.8 - one iteration)
P.S. This weekend, I hope.
Cool! :-)
Nice to see cloth simulation outside Cinema4D as well. :-)
Peace,
Rich_Art. ;-)
The new version (v0.95). Even earlier than planned :)
[added] Frame skipping slider (allows to skip frame updating during calculations)
I know about this problem. I'll try to fix it in the next version.
Update (v0.96):
[added] Lock anchor points checkbox (the problem described above is partially solved)
Very convincing result!
Seems this always only spheres ?
But seems you have had some parameters! :)
At this moment only spheres and donuts :)).. But I plan to add a new obstacle type - triangles. :)
Seems donut's don't stop cloth! ( a circle sweeping on a circle)
French Version :)
http://moiscript.weebly.com/simulation-tissu.html
Hint: you can use more than one sphere :)
Use spheres to build a donut.
P.S. Thank you very much for the translation. But you definitly need to enlarge sliders. It's impossible to use the script with such small sliders.
Ah ok for the trick of the donuts :)
<< But you definitly need to enlarge sliders.
Seems sufficient as you can enter any number on the right's case! :)
And in French words are often more longer than English!
PS What render do you use for your gorgeous images ?
Pss Seems I have a problem!
Gride is exploded when arrive on the spheres!
In fact Spheres were not enough big but curious as they were more bigest than a square of the gride!
Seems sphere must be twice bigger than a "square" of the gride ?
Here gride passes away but the square is smaller than the sphere!
here that works because spheres are biggest :)
Possibilities are endless! :)
(cool your CommandBar Lighting + Dinos for put some car plastic lights! :)
Hi Pilou
Not any number. Constraints settings can be changed with sliders only.
Octane render (
http://render.otoy.com/)
It depends of Timestep value.
Also you can try to increase Shear value to reduce flexibility.
<< Constraints settings can be changed with sliders only.
Ah, yes you can enter number but you have put some maximum! :)
<< It depends of Timestep value.
So if time is not a good value gride can pass away even it's a little gride! :)
Some analogy with this one! ;)
top work Max need to have a play with the scripts :)
cool..
Peace,
Rich_Art. ;-)
Hi Max,
Have you updated this script since 20 Feb 2014 ?
thanks
Really beautiful work Max!
Do you think a reverse-action version of this script could be applied to the scenario of flattening (un-forming / developing) a sheet metal blank that has been pressed over a form block?
- Hamish
Finema
Sorry. No. I haven't any plan to improve this script. Maybe later.
Hamish
Thank you :)
Yes, it can be done for a bended or folded surfaces. But not for pressed.
3-22
23-42
43-62
63-73
