15-34
35-54
55-73
Hi Pilou
You read my mind :)
I am a medium! :)
I am making the French version but have 2 questions! :)
http://moiscript.weebly.com/simulation-tissu.html
Where is this text who say to press Done for translate it?
and when I abort and relaunch the script with something selected i have this message
where is it for translate it?
_Cloth.js, line 53
>>and when I abort and relaunch the script with something selected i have this message where is it for translate it?
_Cloth.js, line 13
(forgot to change this message)
I think you should shorten the labels. :)
Thx for the infos! I had researched only on the HTM :)
Seems I can't modify the JS file without this!
In what code I must save the modifications for have French accents ? Normally I use utf-8
Of course I see nothing like this when I read the line 1 before the // !
The mechanism that loads text files like the .js file knows how to load either ascii files or UTF-16 (little endian), so possibly UTF-16 could work.
I always use utf-8.
I just checked this file in hex editor - everything is correct.
Try to use /* comment */ instead of // comment, or erase this line at all.
utf-8 is equivalent to ascii if there is no "byte order mark" at the start of the file and only uses ascii characters in it.
If you need to use non-ascii characters in a script, try saving it as UTF-16 little endian with byte order mark, the text file loader knows how to load that type of unicode text file.
utf-16 seems works !
Wow Max! Great to then use Network on the curves, and shell for thickness! This is truly cool! Thank you so much!
Michael T.
New version of the script will be released soon :)
[added] three different types of constraints ( version 0.8 - one type )
[added] flexibility control
[added] increased precision of the cloth structure calculation ( upto 20 iterations per frame. version 0.8 - one iteration)
P.S. This weekend, I hope.
Cool! :-)
Nice to see cloth simulation outside Cinema4D as well. :-)
Peace,
Rich_Art. ;-)
The new version (v0.95). Even earlier than planned :)
[added] Frame skipping slider (allows to skip frame updating during calculations)
I know about this problem. I'll try to fix it in the next version.
Update (v0.96):
[added] Lock anchor points checkbox (the problem described above is partially solved)
Very convincing result!
Seems this always only spheres ?
But seems you have had some parameters! :)
At this moment only spheres and donuts :)).. But I plan to add a new obstacle type - triangles. :)
Seems donut's don't stop cloth! ( a circle sweeping on a circle)
French Version :)
Hint: you can use more than one sphere :)
Use spheres to build a donut.
P.S. Thank you very much for the translation. But you definitly need to enlarge sliders. It's impossible to use the script with such small sliders.
Ah ok for the trick of the donuts :)
<< But you definitly need to enlarge sliders.
Seems sufficient as you can enter any number on the right's case! :)
And in French words are often more longer than English!
PS What render do you use for your gorgeous images ?
Pss Seems I have a problem!
Gride is exploded when arrive on the spheres!
In fact Spheres were not enough big but curious as they were more bigest than a square of the gride!
Seems sphere must be twice bigger than a "square" of the gride ?
Here gride passes away but the square is smaller than the sphere!
here that works because spheres are biggest :)
Possibilities are endless! :)
(cool your CommandBar Lighting + Dinos for put some car plastic lights! :)
15-34
35-54
55-73
