Full Version: Cloth simulation
Show messages:  1-17  18-37  38-57  58-73
11 Feb 2014   [#18] In reply to [#17]
Insane Max....... Cant wait to try it!
11 Feb 2014   [#19]
Simply amazing, great work.
11 Feb 2014   [#20]
Holy mother of pearl!
Oh... there are going to be possibilities. ;-)
So! Will there be a 'pause' or 'reverse' of some sort? Would you be able to affect it by a chosen object; like the sphere being moved into it?
And yes, rigidity or tensile viscosity would be a nice touch too, but never mind me, I've been amazed at your result and can't wait to play with the final script.
12 Feb 2014   [#21] In reply to [#20]
I had similar thoughts Mike.
How do you freeze the "cloth" where you want it? Can you single-step through the "animation" and save the desired shape?
Can you output obj files of each step (frame) of the animation? Programs like Element 3D will accept obj sequences and render.
Can you affect the weight or damping of the cloth? That is, can you vary how many wrinkles are produced?
Can you deform anything other than a flat surface? That is, could two spheres collide and leave a dent?
Have you considered a variation of the script to produce ocean water?
This is fantastic work. I'm anxious to try it.
Ed
12 Feb 2014   [#22]
Now that looks like a lot of fun!
Should allow for some nice "relaxing" of surfaces.
Yeah, some control over stretchyness could be helpful and a single-step-mode too to catch the perfect frame...
MoI is starting to really grow up with all the cool scripts you guys are doing!
I never even realized what's possible...
Cheers,
Tom
12 Feb 2014   [#23]
How about reversing the process?
Think of the Sphere as a sculpting tool, the cloth as a portion of a 3D surface.
So the Sphere would make dimples or rounded grooves in the surface.
12 Feb 2014   [#24]
Hi!
Here is my quick answers :)
Mike
Maybe in next version, but not now.
It's impossible with the current engine. I will rewrite it later.
ed
I don't know. Need to check MoI export tools.
Yes. Yes. Already done.
Surfaces only.
Tommy
>>Yeah, some control over stretchyness could be helpful..
Done.
>>..and a single-step-mode too to catch the perfect frame...
I'm writing it now.
bemfarmer
All frames will be saved. You can rewind the record.
Maybe later.
13 Feb 2014   [#25]
Amazing!
14 Feb 2014   [#26]
Yes! I did it! :)
P.S. Sorry, I'm tired now, so I'll write about this script tomorrow.
P.P.S.
14 Feb 2014   [#27] In reply to [#26]
Wow Max that is so super cool!
My favorite part is being able to scrub through all the generated frames at the end!
The spheres are pretty slippery!
15 Feb 2014   [#28] In reply to [#27]
"""My favorite part is being able to scrub through all the generated frames at the end!"""""""""
Should be able to do the screencapture on all those frames for a sequential animation!!!! It "IS" very cool.
Thanks Max.
15 Feb 2014   [#29]
Great, works really well. Is it possible in the future to use other objects than spheres?
15 Feb 2014   [#30] In reply to [#26]
Absolutely awesome Max!
Here's a quick model and render using the Cloth and vSpray scripts :)
15 Feb 2014   [#31]
Very appetizing Danny
and bravo again Max the Wizard of Script Land!
15 Feb 2014   [#32] In reply to [#30]
Hi Danny,
I'm impressed, looks great!
wastzzz
I tested this script with other simple shapes (cubes, cylinders), but I am not satisfied with the quality. A cloth stretched over sharp edges looks really bad.
Also I tested it with complex curved shapes. It works, but veeeerrrrry sloooooow...... I need a fast algorithm for collision detection between points and surfaces.
BTW, Don't forget that you can use a lot of spheres :)
15 Feb 2014   [#33]
Most impressive!
Marc
15 Feb 2014   [#34]
Hello Max
When you select points does it possible to have a "circular selection" ?
It's possible by hands with your script but it's some tiedous! :)
And will be very useful in many other cases than your script ! ;)
Have happy coding!
15 Feb 2014   [#35] In reply to [#34]
Hi Pilou
You read my mind :)
15 Feb 2014   [#36] In reply to [#35]
I am a medium! :)
15 Feb 2014   [#37]
I am making the French version but have 2 questions! :)
http://moiscript.weebly.com/simulation-tissu.html
Where is this text who say to press Done for translate it?
and when I abort and relaunch the script with something selected i have this message
where is it for translate it?
