Full Version: Cloth simulation
Show messages:  1-11  12-31  32-51  52-71  72-73
10 Feb 2014   [#12]
Will the user be able to select a "bending stiffness" for the cloth?
Will there be a "Hair" mode ? :-)
10 Feb 2014   [#13] In reply to [#12]
Hi Brian
Afraid not. At least not in the first release.
10 Feb 2014   [#14] In reply to [#11]
TpwUK
<<Hi Sebastian, that's just it, there are plenty of poly modelling apps that do cloth sims, but this is first I have seen of it in NURBS, so unless anyone knows different, this is going to be unique to MoI.>>
Agree with you Martin
I understand also Sebastian's point of wiew:he belong to other branch of MOI's users:molders,cnc,3dprinters..for them this stuff could be not necessary
anyway Max that's amazing !! I also saw- Moi3d camera- on your youtube...we have to expect this too??...all for free..?? :) :)
10 Feb 2014   [#15]
Can't wait to try it out. Thanks for your contribute! About interface.. Uhm, guess you could type in the name (group) of the colliding objects, that would make it easy
11 Feb 2014   [#16]
Brilliant! :-)
11 Feb 2014   [#17]
Hello!
Today I've started to making the interface.
I don't know when I'll finish it. I'm very busy at work.
Maybe this weekend.. Maybe later.
11 Feb 2014   [#18] In reply to [#17]
Insane Max....... Cant wait to try it!
11 Feb 2014   [#19]
Simply amazing, great work.
11 Feb 2014   [#20]
Holy mother of pearl!
Oh... there are going to be possibilities. ;-)
So! Will there be a 'pause' or 'reverse' of some sort? Would you be able to affect it by a chosen object; like the sphere being moved into it?
And yes, rigidity or tensile viscosity would be a nice touch too, but never mind me, I've been amazed at your result and can't wait to play with the final script.
12 Feb 2014   [#21] In reply to [#20]
I had similar thoughts Mike.
How do you freeze the "cloth" where you want it? Can you single-step through the "animation" and save the desired shape?
Can you output obj files of each step (frame) of the animation? Programs like Element 3D will accept obj sequences and render.
Can you affect the weight or damping of the cloth? That is, can you vary how many wrinkles are produced?
Can you deform anything other than a flat surface? That is, could two spheres collide and leave a dent?
Have you considered a variation of the script to produce ocean water?
This is fantastic work. I'm anxious to try it.
Ed
12 Feb 2014   [#22]
Now that looks like a lot of fun!
Should allow for some nice "relaxing" of surfaces.
Yeah, some control over stretchyness could be helpful and a single-step-mode too to catch the perfect frame...
MoI is starting to really grow up with all the cool scripts you guys are doing!
I never even realized what's possible...
Cheers,
Tom
12 Feb 2014   [#23]
How about reversing the process?
Think of the Sphere as a sculpting tool, the cloth as a portion of a 3D surface.
So the Sphere would make dimples or rounded grooves in the surface.
12 Feb 2014   [#24]
Hi!
Here is my quick answers :)
Mike
Maybe in next version, but not now.
It's impossible with the current engine. I will rewrite it later.
ed
I don't know. Need to check MoI export tools.
Yes. Yes. Already done.
Surfaces only.
Tommy
>>Yeah, some control over stretchyness could be helpful..
Done.
>>..and a single-step-mode too to catch the perfect frame...
I'm writing it now.
bemfarmer
All frames will be saved. You can rewind the record.
Maybe later.
13 Feb 2014   [#25]
Amazing!
14 Feb 2014   [#26]
Yes! I did it! :)
P.S. Sorry, I'm tired now, so I'll write about this script tomorrow.
P.P.S.
14 Feb 2014   [#27] In reply to [#26]
Wow Max that is so super cool!
My favorite part is being able to scrub through all the generated frames at the end!
The spheres are pretty slippery!
15 Feb 2014   [#28] In reply to [#27]
"""My favorite part is being able to scrub through all the generated frames at the end!"""""""""
Should be able to do the screencapture on all those frames for a sequential animation!!!! It "IS" very cool.
Thanks Max.
15 Feb 2014   [#29]
Great, works really well. Is it possible in the future to use other objects than spheres?
15 Feb 2014   [#30] In reply to [#26]
Absolutely awesome Max!
Here's a quick model and render using the Cloth and vSpray scripts :)
15 Feb 2014   [#31]
Very appetizing Danny
and bravo again Max the Wizard of Script Land!
