Full Version: CustomUI
Show messages:  1-12  …  33-52  53-72  73-92  93-112  113-132  133-152  153-172  …  513-522
19 Feb 2014   [#93] In reply to [#91]
Say I want one for the LineWeb Command for example
I have the image ok, but what about the rest of the process till that icon will be added to the CommandBar ?
I don't want replace the 4 yet existing of the Max's Plugin
19 Feb 2014   [#94] In reply to [#93]
Hi Frenchy,
You can open the commandbar.htm file with notepad, then note the line for one of the commands already there, like this one:
<moi:CommandButton icon="res://deleteicon" command="delete"><moi:Text textid="Delete"></moi:CommandButton>
This part here is your icon:
If you put your icon in MoI's icon folder, you can then set that to something like this:
icon="icons/plugin.png"
Does that help?
19 Feb 2014   [#95] In reply to [#93]
you need to create a new module. (you can use "select" module as template)
copy "07 Select.htm" to "60 LineWeb.htm"
open 60 LineWeb.htm with notepad
<moi:Spacer/>
<moi:CommandButton icon=" ----- put BASE64 icon here ---- " onbuttonclick="LineWeb">LineWeb</moi:CommandButton>
19 Feb 2014   [#96] In reply to [#95]
oop's... I had left max's ui.. yes, disregard my comments and look to previous post from max. My bad.
19 Feb 2014   [#97]
THX I will try that tomorrow! :)
20 Feb 2014   [#98]
hello :)
I have that when I press my LineWeb icon, image and text icon are good but... ;)
Lineweb is of course installed and works when I press Tab & type LineWeb
My 2 lines of 60 Lineweb.html file are
<moi:Spacer>
<moi:CommandButton icon="data:image/png;base64,........numerous caracters ...." onbuttonclick="LineWeb">LineWeb</moi:CommandButton>
Surely I must add something to the Commandbar.htm but what and where ? :)
PS When You press CTL + SHIFT + CLICK on the Options' Button You can open a Zoo! :D
20 Feb 2014   [#99] In reply to [#98]
Hi Pilou, the problem is onbuttonclick="LineWeb" - the contents of onbuttonclick are run as script code, and LineWeb is the name of a command, not script code.
Instead of that put command="LineWeb".
If you wanted to do it in a click handler with script code it would be like this: onbuttonclick="moi.command.execCommand( 'LineWeb' );"
20 Feb 2014   [#100] In reply to [#98]
Ops, my fault.
use "command=..." instead of "onbuttonclick=..."
20 Feb 2014   [#101] In reply to [#99]
Fabulous! Now Success is complete! Bravo! Thx both of you! :)
I have used the Michael's method, but will test the Max's method also! ;)
And I see that I have not Translated the LineWeb Command! (if possible) ;)
P I have forgotten to make a transparent image PNG! So background icon is here white!
20 Feb 2014   [#102]
Trying the Max line, works very fine also and some more short to type! ;)
Max method: command="LineWeb"
Michael method : onbuttonclick="moi.command.execCommand( 'LineWeb' );"
20 Feb 2014   [#103] In reply to [#102]
Michael also said about "command=" method. ;)
P.S. Check this thread: http://moi3d.com/forum/messages.php?webtag=MOI&msg=6440.1
20 Feb 2014   [#104]
LineWeb in French! ;)
http://moiscript.weebly.com/lineweb.html
20 Feb 2014   [#105] In reply to [#20]
I haven't been reading (following) this thread for sometime. Back when I did I was wondering about just how to install the script on my Mac.
Are there many new developments I should be aware of? Thanks I look forward to any responses!
21 Feb 2014   [#106] In reply to [#105]
>>raytownmike
>>..how to install the script on my Mac
1. Go to the first post in this thread and download CustomUI.1.0.mac.zip
2. Right-click the MoI app icon and choose "Show package contents". Go into drive_c/moi/ui. Backup CommandBar.htm
3. Extract CustomUI.1.0.mac.zip to drive_c/moi
21 Feb 2014   [#107]
Can you give me the process for a Script to the Commandbar?
Say i have this one
script:/*Loop Selection*/moi.geometryDatabase.selectLoop();
Seems ... onbuttonclick="Loop Selection">Loop Selection</moi:CommandButton>
don't work ?
21 Feb 2014   [#108] In reply to [#107]
Hi Pilou
<moi:CommandButton icon="..." onbuttonclick="moi.geometryDatabase.selectLoop();">Loop Selection</moi:CommandButton>
21 Feb 2014   [#109] In reply to [#108]
Huhu
of course if we must type all the script that is an another story! I could not find that !
Many thanks!
21 Feb 2014   [#110]
Tested! Bravo!
Button of the BarCommand for a script (not a Command) works very fine!
21 Feb 2014   [#111] In reply to [#106]
I get to the final step and not sure what to do because to use the words Extract CustomUI.1.0 what does that mean.
For example: Replace something from existing contents? Sorry
21 Feb 2014   [#112] In reply to [#111]
3. Extract files from CustomUI.1.0.mac.zip to drive_c/moi
