24-43
44-63
64-83
84-103
104-123
124-143
144-163
504-522
Curious!
After some good sessions and numerous MOI lauching Moi I have that !
I had translated the list of the LightingOptions of Dinoscript but without success (same message ! )
I have all kill and reload the Lighting Script by Dinos
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5222.47
and your script! No Change!
So seems it's from the Options menu / Vews / Lighting Option there is something?
Edit ! Damned that was the same than before :
I must enter a new Tempo Lighting Preset, then kill it for Get back the list! :)
A very vicious bug! :D
So I believe now that I can re translate the all :)
Edit ! not so easy! works one time then comes back! seems accents make trouble!
You need to delete LightingOptions line from moi.ini
But first send this line to me.
Sending by PM :)
Seems it's a very big line! :)
Not Better!
I see the list in French on the Options Menu one time, but whent I call your Plugin I obtain similar message!
And the erased line in the moi ini comeback ! :)
I have tryed different formats Ansi seems the best but...
It's an headache! :)
So i have found the ultimate solution, not the perfection but near the perfection! :)
I write French without accent! And all works fine!
As that is only for the vertical list of the Dinos Ligthings, it's not a big disaster! :)
This is for my old computer! :)
For the modern seems it's more hard to found a solution!
Another thing : what about put a new image icone button for a specific command on the CommandBar?
Ok I found a solution for the modern computer but that is some tiedous :) Before maybe a morez direct native system by Michael ? :)
No accent, and format must be in Notepad "Ansi as Utf-8" else some problems!
In Moi.ini Kill the line LightingOptions=....
And no possibility to have accent for your icon "Lighting" or other without numerous again some problems!
So this is! That was a big fight for me! :)
(in fact just 3 words must have accent in French: "Défaut", "Pétrole" and "Zèbre" so not a big deal !
Well done Pilou!
Just check your spelling on 'Default' and I don't see Zebre in the list.
Thx for the little default! :)
For the "Zèbre" : Seems it is! :)
(Without accents due bug error message etc... :(
Hi Frenchy,
"""""""""""Another thing : what about put a new image icone button for a specific command on the CommandBar?""""
You can make your image (I think he made his at 64x64 pixals) then go drop it here, and copy the result:
http://base64image.org/
Then edit the corresponding file here:
C:\Program Files (x86)\MoI 3.0 beta Nov-19-2013\ui\customui
and replace the base64 encode with yours...
Message 6507.92 was deleted
Say I want one for the LineWeb Command for example
I have the image ok, but what about the rest of the process till that icon will be added to the CommandBar ?
I don't want replace the 4 yet existing of the Max's Plugin
Hi Frenchy,
You can open the commandbar.htm file with notepad, then note the line for one of the commands already there, like this one:
<moi:CommandButton icon="res://deleteicon" command="delete"><moi:Text textid="Delete"></moi:CommandButton>
This part here is your icon:
If you put your icon in MoI's icon folder, you can then set that to something like this:
icon="icons/plugin.png"
Does that help?
you need to create a new module. (you can use "select" module as template)
copy "07 Select.htm" to "60 LineWeb.htm"
open 60 LineWeb.htm with notepad
<moi:Spacer/>
<moi:CommandButton icon=" ----- put BASE64 icon here ---- " onbuttonclick="LineWeb">LineWeb</moi:CommandButton>
oop's... I had left max's ui.. yes, disregard my comments and look to previous post from max. My bad.
THX I will try that tomorrow! :)
hello :)
I have that when I press my LineWeb icon, image and text icon are good but... ;)
Lineweb is of course installed and works when I press Tab & type LineWeb
My 2 lines of 60 Lineweb.html file are
<moi:Spacer>
<moi:CommandButton icon="data:image/png;base64,........numerous caracters ...." onbuttonclick="LineWeb">LineWeb</moi:CommandButton>
Surely I must add something to the Commandbar.htm but what and where ? :)
PS When You press CTL + SHIFT + CLICK on the Options' Button You can open a Zoo! :D
Hi Pilou, the problem is onbuttonclick="LineWeb" - the contents of onbuttonclick are run as script code, and LineWeb is the name of a command, not script code.
Instead of that put command="LineWeb".
If you wanted to do it in a click handler with script code it would be like this: onbuttonclick="moi.command.execCommand( 'LineWeb' );"
Ops, my fault.
use "command=..." instead of "onbuttonclick=..."
Fabulous! Now Success is complete! Bravo! Thx both of you! :)
I have used the Michael's method, but will test the Max's method also! ;)
And I see that I have not Translated the LineWeb Command! (if possible) ;)
P I have forgotten to make a transparent image PNG! So background icon is here white!
Trying the Max line, works very fine also and some more short to type! ;)
Max method: command="LineWeb"
Michael method : onbuttonclick="moi.command.execCommand( 'LineWeb' );"
Michael also said about "command=" method. ;)
P.S. Check this thread:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=6440.1
24-43
44-63
64-83
84-103
104-123
124-143
144-163
504-522
