Full Version: CustomUI
Show messages:  1-2  …  23-42  43-62  63-82  83-102  103-122  123-142  143-162  …
17 Feb 2014   [#83] In reply to [#82]
<<< and go to Options -> View -> Lighting Options
Ah Perfect!
The trick was go one time inside the options Menu!
Now I can try to translate all that! :) (text button icons of your plugin if possible etc... :)
18 Feb 2014   [#84]
Curious!
After some good sessions and numerous MOI lauching Moi I have that !
I had translated the list of the LightingOptions of Dinoscript but without success (same message ! )
I have all kill and reload the Lighting Script by Dinos http://moi3d.com/forum/messages.php?webtag=MOI&msg=5222.47
and your script! No Change!
So seems it's from the Options menu / Vews / Lighting Option there is something?
Edit ! Damned that was the same than before :
I must enter a new Tempo Lighting Preset, then kill it for Get back the list! :)
A very vicious bug! :D
So I believe now that I can re translate the all :)
Edit ! not so easy! works one time then comes back! seems accents make trouble!
18 Feb 2014   [#85] In reply to [#84]
You need to delete LightingOptions line from moi.ini
But first send this line to me.
18 Feb 2014   [#86] In reply to [#85]
Sending by PM :)
Seems it's a very big line! :)
18 Feb 2014   [#87]
Not Better!
I see the list in French on the Options Menu one time, but whent I call your Plugin I obtain similar message!
And the erased line in the moi ini comeback ! :)
I have tryed different formats Ansi seems the best but...
It's an headache! :)
19 Feb 2014   [#88]
So i have found the ultimate solution, not the perfection but near the perfection! :)
I write French without accent! And all works fine!
As that is only for the vertical list of the Dinos Ligthings, it's not a big disaster! :)
This is for my old computer! :)
For the modern seems it's more hard to found a solution!
Another thing : what about put a new image icone button for a specific command on the CommandBar?
Ok I found a solution for the modern computer but that is some tiedous :) Before maybe a morez direct native system by Michael ? :)
No accent, and format must be in Notepad "Ansi as Utf-8" else some problems!
In Moi.ini Kill the line LightingOptions=....
And no possibility to have accent for your icon "Lighting" or other without numerous again some problems!
So this is! That was a big fight for me! :)
(in fact just 3 words must have accent in French: "Défaut", "Pétrole" and "Zèbre" so not a big deal !
19 Feb 2014   [#89] In reply to [#88]
Well done Pilou!
Just check your spelling on 'Default' and I don't see Zebre in the list.
19 Feb 2014   [#90] In reply to [#89]
Thx for the little default! :)
For the "Zèbre" : Seems it is! :)
(Without accents due bug error message etc... :(
19 Feb 2014   [#91] In reply to [#88]
Hi Frenchy,
"""""""""""Another thing : what about put a new image icone button for a specific command on the CommandBar?""""
You can make your image (I think he made his at 64x64 pixals) then go drop it here, and copy the result:
http://base64image.org/
Then edit the corresponding file here:
C:\Program Files (x86)\MoI 3.0 beta Nov-19-2013\ui\customui
and replace the base64 encode with yours...
Message 6507.92 was deleted
19 Feb 2014   [#93] In reply to [#91]
Say I want one for the LineWeb Command for example
I have the image ok, but what about the rest of the process till that icon will be added to the CommandBar ?
I don't want replace the 4 yet existing of the Max's Plugin
19 Feb 2014   [#94] In reply to [#93]
Hi Frenchy,
You can open the commandbar.htm file with notepad, then note the line for one of the commands already there, like this one:
<moi:CommandButton icon="res://deleteicon" command="delete"><moi:Text textid="Delete"></moi:CommandButton>
This part here is your icon:
If you put your icon in MoI's icon folder, you can then set that to something like this:
icon="icons/plugin.png"
Does that help?
19 Feb 2014   [#95] In reply to [#93]
you need to create a new module. (you can use "select" module as template)
copy "07 Select.htm" to "60 LineWeb.htm"
open 60 LineWeb.htm with notepad
<moi:Spacer/>
<moi:CommandButton icon=" ----- put BASE64 icon here ---- " onbuttonclick="LineWeb">LineWeb</moi:CommandButton>
19 Feb 2014   [#96] In reply to [#95]
oop's... I had left max's ui.. yes, disregard my comments and look to previous post from max. My bad.
19 Feb 2014   [#97]
THX I will try that tomorrow! :)
20 Feb 2014   [#98]
hello :)
I have that when I press my LineWeb icon, image and text icon are good but... ;)
Lineweb is of course installed and works when I press Tab & type LineWeb
My 2 lines of 60 Lineweb.html file are
<moi:Spacer>
<moi:CommandButton icon="data:image/png;base64,........numerous caracters ...." onbuttonclick="LineWeb">LineWeb</moi:CommandButton>
Surely I must add something to the Commandbar.htm but what and where ? :)
PS When You press CTL + SHIFT + CLICK on the Options' Button You can open a Zoo! :D
20 Feb 2014   [#99] In reply to [#98]
Hi Pilou, the problem is onbuttonclick="LineWeb" - the contents of onbuttonclick are run as script code, and LineWeb is the name of a command, not script code.
Instead of that put command="LineWeb".
If you wanted to do it in a click handler with script code it would be like this: onbuttonclick="moi.command.execCommand( 'LineWeb' );"
20 Feb 2014   [#100] In reply to [#98]
Ops, my fault.
use "command=..." instead of "onbuttonclick=..."
20 Feb 2014   [#101] In reply to [#99]
Fabulous! Now Success is complete! Bravo! Thx both of you! :)
I have used the Michael's method, but will test the Max's method also! ;)
And I see that I have not Translated the LineWeb Command! (if possible) ;)
P I have forgotten to make a transparent image PNG! So background icon is here white!
20 Feb 2014   [#102]
Trying the Max line, works very fine also and some more short to type! ;)
Max method: command="LineWeb"
Michael method : onbuttonclick="moi.command.execCommand( 'LineWeb' );"
