8-27
28-47
48-67
68-87
88-107
108-127
128-147
508-522
Several scripts of my shortcut key options are missing from the Ext. Scripts.
They are Ctrl-C, Ctrl-S, Ctrl-O, Ctrl-N, Ctrl-G, and Ctrl-I.
I have not checked everything yet.
Any idea of why this would be?
So the Ext. Scripts list was made by scanning "commands" folder, which explains why pipe and rotateobjects are not capitalized,
and why the oneliner scripts are not included.
Checked through all of my shortcuts. _FxGraph and _cMorph are not in the Ext. Scripts list.
ArrayCurve is missing.
ArrayGrid is missing.
IncrementalSave is missing.
PastePart is missing.
CopyClipboard is missing.
Intersect is missing.
Cut is missing.
Nudge is present. Does it do anything? (The six Nudge commands are not present, which is OK.)
New, Open, Paste, and Save are missing, but they do not have htm files.
Hey Brian,
It looks like you're listing MoI's default commands...Not custom ones... There is the ext.scripts FULL that will include MoI's commands in the list. But if you don't want "all the commands listed", If you open the extscripts htm file in notepad, at the top a couple lines down there is an entry for "add command", where you can add just a few that you want. This is the separated list at the top...
Thank you Burrman.
Amazing again!
must try it before French translation manual of this new Max opus!
French Manual! ;)
http://moiscript.weebly.com/customiser-lui.html
Can you put an image of the arborescence ?
Ok I have some results :)
No problem with the scripts :) but for save objects Snapshots!
For the moment I have all in the Moi Folder!
The + appears, i can enter a name, but objects selected don't go on the Folder Objects! (is this the Library Object ?
I see the 3 objects examples from this folder and can load them but not save new!
must I initialize some path even this is yet existing?
Idem for Snaphot : screen don't go on the Snapshot folder!
And I must install the Dinos Lighting Options for run your Light icon?
PS Same result with the CustomInitUAC !
I avoided storing things in the MoI application directory so I store Snapshots and Objects in My Documents, just make directories where you like and point to them as I did in the .htm files below...
Not better! :(
Maybe because I am on Vista 32 bits ?
I have believed that the error was from "Moi" and not "MoI 3.0 beta Nov-19-2013" that I have on my arborescence
Object Library;MoI\objects original should be
Object Library;MoI 3.0 beta Nov-19-2013\objects
or
Object Library;C:\Program Files\MoI 3.0 beta Nov-19-2013\objects
Edit!
Ok I erase all and reload all and now that works fine! :)
It was that I suspected: Object Library;C:\Program Files\MoI 3.0 beta Nov-19-2013\objects
against
Object Library;MoI\objects !!!
Have you the same bug ? And it's a repetive bug!
After use the Max Smirnov SnapShot the "Area, Zoom, Pan, Reset" are not more visible on some views inside MOI!
I have like Danny (thx) the Folder Snapshot out of the Moi Folder so modify only the line !
var Path = moi.command.getOption('ExePath', false) + "\\snapshots\\";
in
var Path = "C:\\Users\\Pilou\\Desktop\\maxsmirnov\\snapshots\\";
And about The Lighting Options by Dinos? Where is it ? adress post ?
What is the installation with Max plugin?
Does it conflict whith the native Lightings options of the Options menu of Moi ?
>> It was that I suspected: Object Library;C:\Program Files\MoI 3.0 beta Nov-19-2013\objects against Object Library;MoI\objects !!!
Object Library;
MoI\objects? Of course it doesn't work :)
You should use a full path or MOI (all capitals) abbrevation.
Tried to reproduce this issue. Yes, "Area, Zoom, Pan, Reset" dissapears after language switching (my script switches language to disable viewport labels).
But seems it's a MoI bug. If you want to reproduce it follow the steps below:
1. Copy EnglishStrings.txt to TestStrings.txt
2. In the Options menu: Switch language to English, Switch to Test, then back to English.
3. It disappears.
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.48
Just download Dinos's LightingOptions.htm, and put it to ui/ folder (overwrite the original one)
Thx for the infos!
I will try that!
But another little question :)
Say I have several libraries of Objects
I must change the text of the "ObjLibrary.cfg.htm" or i can put several lines inside it or...there is another trick ?
put several lines inside ObjLibrary.cfg.htm
Cool & fabulous for the libraries!!
About the Dinos lighting plugin
I have a PC must i paste also this file ? .DS_Store
French or English i have this result so a path must bad somewhere!
No.
Copy the .htm file and go to Options -> View -> Lighting Options
<<< and go to Options -> View -> Lighting Options
Ah Perfect!
The trick was go one time inside the options Menu!
Now I can try to translate all that! :) (text button icons of your plugin if possible etc... :)
Curious!
After some good sessions and numerous MOI lauching Moi I have that !
I had translated the list of the LightingOptions of Dinoscript but without success (same message ! )
I have all kill and reload the Lighting Script by Dinos
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5222.47
and your script! No Change!
So seems it's from the Options menu / Vews / Lighting Option there is something?
Edit ! Damned that was the same than before :
I must enter a new Tempo Lighting Preset, then kill it for Get back the list! :)
A very vicious bug! :D
So I believe now that I can re translate the all :)
Edit ! not so easy! works one time then comes back! seems accents make trouble!
You need to delete LightingOptions line from moi.ini
But first send this line to me.
Sending by PM :)
Seems it's a very big line! :)
Not Better!
I see the list in French on the Options Menu one time, but whent I call your Plugin I obtain similar message!
And the erased line in the moi ini comeback ! :)
I have tryed different formats Ansi seems the best but...
It's an headache! :)
8-27
28-47
48-67
68-87
88-107
108-127
128-147
508-522
