455-474
475-494
495-514
515-522
Thanks for that & yes, that Custom UI folder was the first place I looked & there's NO Sub-D listed within there.
The actual Sub-D icons are part of the MoI V3 installation as I found them within the Icons folder...
I've attached two screen captures of my MoI V3, first is as a "floating window", second as maximised...
...in both cases I have to scroll across to reach stuff I use because of the Sub-D's which I don't use.
If I can get rid of the Sub-D "placement" then I'm hopeful of getting back to NOT having to scroll.
regards Colin
Hi Colin, can you please post the CommandBar.htm file that you have at:
C:\Program Files (x86)\MoI 3.0\ui\CommandBar.htm
That probably has the buttons embedded there.
Hi WN,
Thanks for taking the time to look & respond.
When I was saving the various add-on Scripts & Custom stuff, I made a conscious decision to save notes on their install.
So I had the relevant info of Max's Custom UI to reference to but there's nothing related to the block of four Sub-D icons.
Nor is there anything named or inferred as "Sub-D" within the Custom UI folder where stuff can be "turned ON or OFF" using "-"
All of which makes me assume it must be part of the original V3 Command Bar install..?
regards Colin
Hi Colin.
If I remember correctly, this plugin is installed separately, then you need to delete its files.
I also have the file " 88 SubdivTools.js" but renaming it doesn't work, only deleting or moving it.
I don't see it in your screenshot.
Hi Colin,
No, those sub-d buttons are not part of the regular V3 UI.
But they may pre-date CustomUI and may have had instructions to insert them by modifying CommandBar.htm .
If you can post your CommandBar.htm I will see if that's where they are.
Thanks for clarifying that.
Here's that CommandBar.htm you're wanting.
HTH, Colin
CommandBar.htm
Hi Colin, yeah they were added in to there.
I've edited them out so if you replace your current CommandBar.htm with this attached version that should get rid of them.
CommandBar.htm
Thanks greatly for that, it's much appreciated.
Just tested & works a treat.
regards Colin
455-474
475-494
495-514
515-522
