Full Version: CustomUI
Show messages:  1-11  …  412-431  432-451  452-471  472-491  492-511  512-522
27 May 2021   [#472] In reply to [#470]
Hi Psygorn,
> And how can I change the size of command bar icons (I am talking about Custom UI icons)
The icon size for a command button comes from this line in moi.css :
moi\:CommandButton > img, moi\:CommandMenuButton > img, moi\:CommandSplitButton > img {
	width:3.25em;
	height:3.25em;
So to change the size of the command bar icons you would need to put a new CSS style rule that overrides that one. You could put it inside a <style></style> block inside the <head> section of a document and then all the command buttons in that document would use your overridden icon width and height.
27 May 2021   [#473] In reply to [#471]
Hi Psygorn,
> However, I have few new questions:
> How can I remove icons within the red boxes?
The red box on the bottom does not contain any icons already so that one is already done! ;)
For the other ones, if you want only those command buttons to not have icons you would need to add something to distinguish them from the other command buttons like adding a class="noicon" to them, and then put in a rule in the top of the document to hide the icons in things that have a class named "noicon" which would be something like this:
moi\:CommandButton.noicon > img, moi\:CommandMenuButton.noicon > img, moi\:CommandSplitButton.noicon > img {
    display:none;
> What should I do if I want them here?
That area is defined by the file SidePane.htm, so you would insert them into that file.
One thing you should be aware of is that usually this kind of major customization to the UI will cause some problems down the line when you want to move to a new version of MoI.
27 May 2021   [#474] In reply to [#473]
Thank you for your reply.
I should alter CommandBar.htm or BrowserPan.htm right?
27 May 2021   [#475] In reply to [#474]
Hi Psygorn,
Yup, just make a backup copy of it and then you can experiment with changing them.
27 May 2021   [#476] In reply to [#473]
display:none;
Instead of Doing above I went to -> AppData\Roaming\Moi\startup and there I opened .JS files responsible for custom ui icons in there I put "//" before the line that starts with : var icon = "....
In other words I deactivate that part. the icons disappear from the command bar or browser pan area.
My question is that was it a safe move? or it will cause me problems?
27 May 2021   [#477] In reply to [#476]
Hi Psygorn,
That will result in the icon being blank but I think you'll have a blank area taking up the same size as the icon would have.
It shouldn't cause any problems.
27 May 2021   [#478] In reply to [#477]
I think there is no blank unused areas.
If you notice I had removed select buttons hide/unhide button from the Browser Pan area. and I think they are just disappeared without leaving a blank space in their place. I am not sure.
27 May 2021   [#479] In reply to [#478]
Hi Psygorn, sorry maybe I didn't understand what you were asking about. The "icon" of a MoI command button means the part of the button that displays an image in it. When you said you wanted to get rid of those "icons" I thought that meant you wanted to have some buttons where the image part of the button was removed leaving only the text part still in place.
But it seems that when you said you wanted to remove some "icons" you meant you wanted to remove some buttons entirely is that correct?
Anyway seems that you've got it figured out.
29 Sep 2021   [#480]
just one request: DARK UI
29 Sep 2021   [#481] In reply to [#480]
Hi jabber,
It's still a work in progress but here's a sneak peek:
Message 6507.482 was deleted
30 Sep 2021   [#483]
Before that if you have a Windows System you can make that ;)
Key Logo windows + "+" toggle on an Inverse color Interface
Key Logo windows + "Escape" toggle on Normal color Interface :)
11 Dec 2021   [#484] In reply to [#481]
Sorry to ask you despite a subject widely documented on the forum. But I'm not sure I'm doing the right customization of my toolbox on my own.
I wish I had Curve / Solid combined into one tab, because currently with my custom palette, when I click on the "solid" tab to open it, the "Construct" tab or the "Transform" tab closes. I think that would fix the problem which I think is a vertical space issue. I attach my files:
In Moi 4.0:
SidePane.htm
SidePaneTabs.js
SidePaneContextArea.htm
SidePaneTitleBar.htm
SidePaneFilename.htm
In Moi > startup:
SeparateSidePanePalettesNotViewSelect.js
In case there is an interaction between them. the rest of the palette suits me as it is.
- Zooen
11 Dec 2021   [#485] In reply to [#484]
Hi Zooen, that's the intentionally designed behavior that if you open a tab which would cause the side pane to become longer than the available vertical space that it will collapse tabs at the bottom up until there is enough space to fit it without a scroll bar.
The script SeparateSidePanePalettesNotViewSelect.js is making that situation worse by ungrouping all tabs.
What happens if you just remove SeparateSidePanePalettesNotViewSelect.js and let the UI work as it is supposed to?
11 Dec 2021   [#486] In reply to [#485]
Thank you for your quick response (on weekends!). I remove SeparateSidePanePalettesNotViewSelect.js, Solid and Curve are combined as I wanted. But I would really like to have Construct and Transform on two separate (therefore open) tabs because they are the two tabs we use the most. As you can see the selector is on the left. I think, but I could be wrong, that with this position it should work.
Can I make a modification to test the desired layout?
- Zooen
11 Dec 2021   [#487] In reply to [#486]
Hi Zooen, try putting this attached script into the appdata startup folder. It's a modified version of the other script. This one will only ungroup the Construct / Transform palette and not others.
- MIchael
SeparateSidePanePalettesOnlyConstructTransform.js
11 Dec 2021   [#488] In reply to [#487]
Thanks Michael,
This is exactly what I wanted, with even better working comfort!
I was even able to slightly increase the UI size!
- Zooen
Message 6507.489 was deleted
7 Mar 2022   [#490] In reply to [#1]
Is the link to the file gone? Where is it?
7 Mar 2022   [#491] In reply to [#490]
Hi aum,
Yes it looks like Max has removed the file attachment with his CustomUI mod in it, I don't know why.
