Full Version: CustomUI
Show messages:  1-14  …  355-374  375-394  395-414  415-434  435-454  455-474  475-494  …  515-522
27 Jul 2019   [#415] In reply to [#414]
Hi Ogar,
> Dose any one know how make the Z Axis on the grid visible on in the 3D view port?
Sorry no there isn't any way set up to show that currently.
27 Jul 2019   [#416] In reply to [#414]
Not quite the z-axis request, but a line can be drawn at the position of the z-axis, even in Front or Right view,
or a construction line can be added.
28 Jul 2019   [#417] In reply to [#416]
Hi, I suppose you could add a vertical polyline and colour it however you want then lock it. Save the scene as a template and load from that each time. Not perfect but I think it would work :)
Ron
28 Jul 2019   [#418]
Hi again, could someone point me to the HTML than controls the colour of the panel divider for the 4 views ?
Ron
28 Jul 2019   [#419] In reply to [#418]
Hi Ron, for the viewport borders that's one of the few remaining things that is controlled by a bitmap image rather than HTML. You can modify it by changing the bitmap ViewportForeground.png in the ui folder.
25 Oct 2019   [#420]
Hello everyone :)
Newbie here, first post ^_^
Really glad to be part of Moment of Inspiration Family. Thank you for making such wonderful software Michael and HUGE thanks for everyone for making understandable, fast, easy to use, beautiful and most important FUN to work with :)
Have some questions about Custom UI. Some features does not working. Maybe some of you might know and can help me?
(I'm on Moi V3 Windows 10)
Downloaded CustomUI.1.03.win.mac 2015-08-29
1. Obj library - I can not save my objects to library. It lets me name the object, but after hit "OK" the new object did not appears in Obj library next to Max's Cube, Sphere, Plane already created (attached 1st picture)
2. Snapshot does not save my files, or maybe i was looking not in the right MOI "snapshot" folder :(
3. Lightening also does not working. Want to have some highlights on the surface. Maybe this because of lightening script. (attached image)
4. Tested some scripts. Working like a charm :) Not all tested, but happy so far.
So i was wondering is there any solution to fix all this or I should upgrade to V4 Beta?
Many thanks
Appreciate your help.
K.
25 Oct 2019   [#421] In reply to [#420]
Hi Konni, welcome to MoI and to the forum!
So for #1 and #2 I think the problem is that by default Windows will prevent applications from writing into the "Program Files" directory as a security measure. If you run MoI at an elevated privilege that could solve this problem. To do that right-click on the shortcut icon you use to launch MoI and then I think it's the "compatibility" tab where you'll find a checkbox that says "Run as Administrator". Try enabling that.
for #3 Lighting options, I think that is expecting for a list of lights to have been written in the moi.ini file by a separate LightingOptions plugin. Try installing that other plugin from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.43
Hope that works!
26 Oct 2019   [#422] In reply to [#421]
Thank you Michael for such full and informative answer.
Yep - #1 and #2 solved - Run as Admin and it worked. :)
#4 - Lightening Options also solved. Have them in Options ->View ->Lightening Options -> Lightening Presets. And also have these in custom ui bar :)
Thank you once again for making awesome software ^_^
(I'm in V4 Beta now).
28 Oct 2019   [#423] In reply to [#303]
Now I'm using the V4 Beta. Thank you.
16 Dec 2019   [#424]
Hi all,
Sorry, again noob question here.
How to get folders in Object Library?
Appreciate ^_^
16 Dec 2019   [#425] In reply to [#424]
You must have these objects yet in your folder!
16 Dec 2019   [#426] In reply to [#425]
I have these default objects in my folder. I can create new objects and they appear in my Objects Library in Moi and in %AppData folder. But when i create manually folder in appData it does not appear in Moi. And in Moi I do not know how to create folder and save in it some similar items like for example screws or smth...
Thank you
16 Dec 2019   [#427] In reply to [#424]
Hi Konni,
I don't think it supports sub-folders currently.
30 Mar 2020   [#428] In reply to [#1]
Hello Master,
I am getting a script error and no object library, basically nothing happens. What am I doing wrong ?
30 Mar 2020   [#429] In reply to [#428]
hi, michael told you already, that this message comes from using a cracked v3 beta version... spambot maybe?
quote:
Hi Brownie, that error comes from using an old v3 beta release (like a cracked version) which is missing some functions that are in the v3 final release version.
So to fix that make sure you're running the release version of v3 and not a cracked version. If you purchased MoI you can get a new download of the full version installer by putting in your license key at http://moi3d.com/reinstall.htm .
17 Jul 2020   [#430] In reply to [#427]
Hi guys,
I have re-installed both (moi_v3_setup) and (moi_v4_beta_Jan-22-2020_setup)
Then extracted (CustomUI.1.03.win.mac) into MoI3 and extracted (CustomUI.2.0.beta2) into the Roaming\MoI directories.
I am able to get a list of SHORTCUTS in MOI3 but cannot get to the shortcuts in MoI4
When I had a look in the (...\AppData\Roaming\Moi\startup) There is a list of all the buttons that populate the bottom Bar.
But SHORTCUTS is not there.
I have had a search around on the Discussion Forum but could not find an answer
17 Jul 2020   [#431] In reply to [#430]
Hi Maysky, yes it looks like the CustomUI for v4 does not have a shortcuts button like the one for v3 did.
17 Jul 2020   [#432] In reply to [#431]
Ok, So what has to happen for a ShortCut-access-point to be created in the MOI4 customUI?
I guess this question is inappropriate. Sorry.
17 Jul 2020   [#433] In reply to [#432]
Hi Maysky,
First copy the HTML file for it from the v3 CustomUI which is at customui\mods\Shortcuts.menu.htm . Put that into the appdata\Moi\customui folder where there should be other .htm files like "Scripts.menu.htm" and "ObjLibrary.menu.htm".
Then inside the appdata\Moi\startup folder, make a copy of the "80 Scripts.js" file and name it "82 Shortcuts.js" . Edit the new file "82 Shortcuts.js" and change where it has:
var title = "Scripts";
to instead have
var title = "Shortcuts";
and also where it has:
var menu = "moi://appdata/customui/Scripts.menu.htm";
to instead have:
var menu = "moi://appdata/customui/Shortcuts.menu.htm";
Then you should have a Shortcuts button next to Scripts on the bottom toolbar that will work the same as it did in the V3 CustomUI. I think the way it is set up is it will show a menu of shortcut keys that have script code in them where there is a comment marked with a ! sign in it, like if you have a shortcut key set up like this:
script: /*!Invert selection*/ moi.geometryDatabase.invertSelection();
that will display as an "Invert selection" item on that Shortcuts menu.
17 Jul 2020   [#434] In reply to [#433]
Wow! thank you Michael
I will give this a go.
I thought I was being rude
