Full Version: CustomUI
Show messages:  1-6  …  327-346  347-366  367-386  387-406  407-426  427-446  447-466  …  507-522
2 Apr 2019   [#387] In reply to [#386]
Hi Death, what you are showing there is a customized side pane, you probably got it from the dark UI customization.
> I didn't change anything with the sidebar except adding the script in the startup folder.
You must have done so in order to get what you are showing.
If you didn't make a backup of the original UI before modifying it, you can get it by doing a reinstall.
2 Apr 2019   [#388] In reply to [#387]
Yeah, but the ONLY script is MiniSidepane.js, your script (in the previous pic) with an clean install, the items are still missing...
2 Apr 2019   [#389] In reply to [#388]
Hi Death, I'm not sure how to describe it more clearly - the items are missing because you have installed a customized SidePane.htm . The particular version you installed had them removed I guess.
The default UI looks like this:
Note for example the default UI has Draw curve / Draw solid as separate tabs while yours is not like that and instead has Draw/Edit combined together into a single tab. That's due to the custom UI that you are using.
To get back to the default UI you would need to restore the original SidePane.htm and any other files you modified or reinstall.
2 Apr 2019   [#390] In reply to [#388]
Hi Death, or probably to correct what I wrote above, it's not that your customized SidePane.htm has it missing - it's that MiniSidePane.js is not compatible with your customized SidePane.htm and won't work right, like I wrote above here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.385
If you want to use MiniSidePane.js you would need to have the default SidePane.htm , not a modified one.
So either remove MiniSidePane.js or keep MiniSidePane.js and restore the default SidePane.htm .
If don't have the original SidePane.htm then do a reinstall to get the default UI back again.
2 Apr 2019   [#391] In reply to [#389]
Let me try again, because maybe I have been too muddy about this:
On a default installation I wanted the panes to be combined and open, the script to do that is MiniSidepane.js (to be installed into the startup folder), because the default installation doesn't have that.
However, when I do that, the aforementioned items are still missing. I guess Max Smirnov overlooked them? What I need to know is what to do to have them back in there.
Is there a version that has them?
(This is more a question directed a Max).
Suggestion: It would be great, if you (Michael) could implement that (combining/splitting up) of the panes as an checkbox option in the next beta under the Options Menu. I love MoI and think this is the way to go for modeling, but the constant switching between tabs is kind of annoying, especially if one has the screen real-estate to fit the open panes.
Anyway, thanks again for your time, sorry to steal so much of it...
2 Apr 2019   [#392] In reply to [#391]
Hi Death, oops sorry my problem was that I wasn't quite remembering properly what MiniSidepane.js does, I was thinking that it moved things in a different way (to split apart Construct / Transform tabs into individual tabs).
Sorry I was confused about that - there is additionally a problem with MiniSidepane.js that it should not be applied onto already customized UI.
So yeah it's just designed intentionally to remove those particular tabs. I don't think there is a version that keeps them.
But to modify it how you want, remove the 2 lines that have:
doc.getElementsByTagName("moi:PaletteHeader")[2].remove();
doc.getElementsByTagName("moi:PaletteBody")[2].remove();
That is the code that is removing the standard Edit / View / Select tabs.
If you then want to remove just the Edit tab on that row and leave View / Select put in this:
doc.getElementById("EditTab").remove();
doc.getElementById("EditTabContent").remove();
Hope I have that straightened out now, sorry for the confusion.
2 Apr 2019   [#393] In reply to [#392]
Thanks!
And sorry for stealing your time, it is better spent on developing MoI than talking to dummies like me, I appreciate your time and thanks for the solution. I'll try it and let you know things fared...
Have a good night and keep up the good work!
Jack
3 Apr 2019   [#394] In reply to [#393]
No problem Jack, sorry I wasn't understanding it for a while there!
3 Apr 2019   [#395] In reply to [#394]
You pointed me in the right direction, got it done the way I wanted now...
Here's what I tried to do and achieved thanks to your help.
Many thanks! (again)
Jack
5 Apr 2019   [#396]
Hi Death (weird thing to write)
You see all the icons now?
Can you share how and what you had to modify?
Juraj
5 Apr 2019   [#397] In reply to [#396]
When you click on for instance the scale tool, can you show a screen grab of where the sub menu with this config pops up?
5 Apr 2019   [#398] In reply to [#396]
Hi Yuri,
I changed a bunch of things, don't all remember the details.
(I didn't include "Select All" and "Deselect All", since that's just CTRL-A and a "click in empty screen space")
Your screen resolution should be at least 1900x1200 to make it work well, font size (in MoI's OPTIONS) should be 9.5
Drop this file into your user's ApData/moi/startup directory and it should work automatically.
In my case that is:
C:\Users\Jack\AppData\Roaming\Moi\startup (just replace "Jack" with whatever your user name is)
If you don't have a "startup" (no quotes and all lower case) directory, just make one and drop it in there. Alternatively you can use the Moi program directory and drop it into there (again, into the startup directory, if it doesn't exist, just create one).
It should then look like you see in the picture attached.
This will even work with the default MoI installation (and should work with any custom UI's, the 2nd screenshot attached uses the grey custom UI).
If you want your normal MoI panes back, just delete the file from the startup directory and MoI works as if nothing ever happened...
Jack
DeathPane.js
5 Apr 2019   [#399] In reply to [#397]
Hi co3Darts,
where they usually do...
5 Apr 2019   [#400] In reply to [#399]
Thanks! Looks like a nice mini setup :)
9 Apr 2019   [#401] In reply to [#319]
How do you create folder branches in object libraries?
9 Apr 2019   [#402] In reply to [#401]
Folders can be manually created, for example by file explorer under %appdata%/Objects (MoI4Beta), but the subfolders and their contents, do not seem to be accessible through the Object Library icon, so are of no use. (As far as I know.)
22 Apr 2019   [#403] In reply to [#398]
Hello! My MAC user file directory is just Application Data, right? How to implement? Thank you very much!
22 Apr 2019   [#404] In reply to [#403]
Hi jinyicool, on the Mac your appdata folder is in your home directory, under Library/Application Support/Moi.
So the full path is /Users/[your user name]/Library/Application Support/Moi (or ~/Library/Application Support/Moi).
Note that since OSX Lion Apple decided to hide the Library folder by default from Finder. You can use the "Go to folder" menu option and enter it, or use Cmd+Shift+. to temporarily show hidden files, or use one of the methods mentioned here:
http://osxdaily.com/2016/12/12/show-user-library-folder-macos-sierra/
- MIchael
16 Jul 2019   [#405]
hello
i was looking everywhere for a step by step instruction to install the scrip but honestly, there is just random information flying around, like come on take it, easy guys. i have extracted the file to my fold of installation
C:\Program Files (x86)\MoI 3.0 beta Mar-17-2013
and when i lunch moi i get a Script error :
TypeError: Result of expression 'moi.fiIesystem.getUIDir• [undefined] is not a function.
please someone explain step by step
thank you
16 Jul 2019   [#406] In reply to [#405]
Hi semo, that error will happen if you're running an older cracked v3 beta release. CustomUI requires a newer version than that, either the v3 final release or the v4 beta release.
If you are using a cracked version please don't ask for support on the official forum.
