Full Version: CustomUI
Show messages:  1-12  …  273-292  293-312  313-332  333-352  353-372  373-392  393-412  …  513-522
7 Sep 2018   [#333] In reply to [#332]
Hi LocusDio, you might try putting in a symlink inside of appdata that links to your other folder. See if this helps:
https://lifehacker.com/5496652/how-to-use-symlinks-in-windows
7 Sep 2018   [#334] In reply to [#333]
I can't thank you enough for that information, Michael. Works flawlessly!
22 Oct 2018   [#335] In reply to [#268]
C:\Users\<username>\AppData\Roaming\Moi\
I'm unable to find this folder with my usersame.
22 Oct 2018   [#336] In reply to [#335]
Maybe you must enable "Show hidden files" ?
22 Oct 2018   [#337] In reply to [#335]
Hi Suzanne,
Try using Win+R to bring up the Windows "Run" dialog, and then put in:
%Appdata%\moi
That should then open up the MoI userdata folder. I think it may be in slightly different locations on different Windows versions but there is an environment variable named Appdata and if you put % % around it like above it will substitute it in.
25 Oct 2018   [#338] In reply to [#337]
I've just started using your wonderful program and I'm wondering if you could help with getting CustomUI to work.
I'm using version 3 and I think I have narrowed down the issue to the commandbar.htm file.
The new version of CustomUI that I've downloaded doesn't seem to have the new version of Commandbar.htm, do you know where I could get this from? I believe the fact that I cannot write over this file is the reason that I can't get CustomUI.
Any help you could provide would be most welcome
25 Oct 2018   [#339] In reply to [#338]
Hi TheSpur, the modified CommandBar.htm file for MoI v3 is contained inside the CustomUI.1.03.win.mac.zip which is an attachment on the first message of this thread, go to the bottom of the first message to find the attachments.
It's inside of the \ui subfolder inside that .zip . To install it, the contents of the .zip file are meant to be copied to MoI's main program directory, so there would be new sub-folders for objects and snapshots that are children of the main installation folder, and the contents of the .zip's ui directory should go into MoI's existing ui folder, overwriting the existing CommandBar.htm file.
10 Dec 2018   [#340] In reply to [#1]
Hello Everyone,
I am new to using Moi and came across this awesome feature.
However I can’t seem to get the icons to appear in Moi. I am using version 3.0 can anyone help ?
The first instruction for installation is backup/ui/CommandBar ?
Really noob question but I have no idea what this means ?
Thank you in advance
10 Dec 2018   [#341] In reply to [#340]
This means that you must maybe save your original folder ui/CommandBar in your favorite save place in case of problem with your future UI! ;)
10 Dec 2018   [#342] In reply to [#340]
Hi Takeda, yes part of the installation of the CustomUI extension is that it overwrites one of MoI's files, it's a file named CommandBar.htm that is in the \ui sub-folder inside of MoI's main installation.
So the backup step means to save your original CommandBar.htm file somewhere else so if you have any problem you can restore the original back again without needing to do a full re-install.
Message 6507.343 was deleted
29 Dec 2018   [#344]
Hi, Where can I find light options addon? I found one that didnt work with this plugin. Thx
29 Dec 2018   [#345] In reply to [#344]
Hi Tharso,
Which version of CustomUI are you using - the one for MoI v3 or the one for MoI v4?
13 Jan 2019   [#346]
Just tried to apply CustomUI to new beta, but it doesn't worl correctly - scripts, object and lighting options folders are empty. Anyone has CustomUI setup which works for last beta?
13 Jan 2019   [#347] In reply to [#346]
Hi glmr,
The latest version of customUI works very well when installed properly in MoI4 beta.
Are you Mac or Windows?
13 Jan 2019   [#348] In reply to [#347]
I am on Windows. MoI 4.0 beta Oct-17-2018
UPD: I'm an idiot who doesn't read instructions. Now it works.
13 Jan 2019   [#349] In reply to [#348]
UPD2: can't find snapshot button even with correct installation
13 Jan 2019   [#350] In reply to [#349]
My camera icon is also missing in MoI4beta. It is present in MoI3.
13 Jan 2019   [#351] In reply to [#349]
Hi glmr,
re: UPD2: can't find snapshot button even with correct installation
Is there a file Snapshot.js located in your MoI appdata\startup folder?
13 Jan 2019   [#352] In reply to [#351]
My 82 Snapshot.js file was missing from MoiAppData\startup.
Downloaded max's v2 of customui from his website, to downloads folder, extracted, and copied
82 Snapshot to the MoiAppData\startup directory, and the camera (snapshot) is back.
A few other .js files are still missing, maybe messed up with MiniSidepane.js alterations???
