250-269
270-289
290-309
310-329
330-349
350-369
370-389
510-522
Hi Michael
Thanks for your explanation.
And the changes you made - they did the trick :-)
Hi all,
FYI GUI Builder is NOT fully compatible with 4.0. Sorry, I haven't yet had time to update it and probably won't until Michael locks down all the HTML/CSS for the interface.
""""""""""For lighting options I seem to remember that some modules of CustomUI are not enabled by default, you need to enable them by something like removing a leading character from the filename which CustomUI looks for and skips that module if its present."""""""
I think he is referring to this?
My "Lighting options" is a js file stored in the "scripts" directory, which creates a dialogue from "LightingThemes.htm" located in the ui directory!
So mine came back, when I told Customui to look at my "scripts" directory!
I modify a second scripts.menu.htm to draw from the scripts directory, so I can separate a few things out from commands.
I am pretty much guessing if this mod is proper and legit. Things changed a bit from the last version!
Question for Max,
You've moved to the appdata directory. I would like the ability to keep the install in MoI's install directory. (I keep MoI on a USB stick also, everything needed is in a single dir...
Will this be possible with your new plans? I have really come to rely on your Customui!!!
Thanks again!
Hi BurrMan
I am the same I work with MOI on several computers keeping the scripts updated via a share on Gdrive - having the UI in same location would be beneficial in this type of workflow.
thanks Alex.
Hi Burr, for the next v4 beta MoI will check if there is an appdata directory contained inside of the main one (alongside "commands", "ui", "docs") and if it finds that you've created one there it will use that as the appdata location instead of the regular place.
So that will be a way to automatically redirect anything that's using appdata to be contained within the main program folder.
That'll do!!!
Thank you Mr. Gibson.....
As an afterthought, have you considered some type of redirects mechanism thats user manageable? Like an ini section or something...
All that future developement by 3rd's comes to mind...
Hi Burr, well I was thinking about that but it's kind of a "chicken & egg" problem because by default the moi.ini file is located in the appdata folder.
So that's pretty awkward to try to have something in the moi.ini file that also tried to store its own location...
I am afraid this is going to be a big request so please bare with me. MOI is freaking amazing but as it seems each one of us is using it completely customised. And that's completely fine but through years it still has certain limitations we have overcome.
One of this things is 'Object library'. As this addon is basically asset management it should be considered one the one of the most important aspects of our workflow. Sure, it works great but unfortunately we are still missing some key features.
First of them is 'scale' value alongside align options as you can see on the image. I simply cannot express how much I miss the control the size of added object by the certain number value. Because of that I have duplicates of same objects which brings me to another problem.
My library of objects is now so big MOI that simply cannot open the shelf without that 'infinite' scroll. It also became really slow. I've already changed my library fonts to their smallest values and down-scaled thumbs. I am out of ideas now so yeah, we basically need the support for nested folders / navigation.
Unfortunately Max the author told me due that's currently impossible through our short email corresponds. 'Unfortunately, at the moment I can't implement support of dynamic folders due of MoI limitations. Later I'll ask Michael to add this functions to MoI Javascript API.'
Also even though Max is an author of this script I also consider asset management one of the key feature of MOI. That's why I urge you Michael to introduce support on your side as well for assets management. I cannot thank Max enough for what he did so far but I cannot expect he would be able to do it all the time.
Btw. I've also talked to my other colleges I know use Moi and basically we all agree on these points. I hope you would not mind for bringing this up, as I am working on the big and complex designs it simply became a huge usability problem to me.
I know I'm asking a lot and you already have your hands full in bringing v4 out of beta. I just think this one of the most important aspects of it.
Thank you!
Max's plugin already supports custom folders-- and IIRC, you can put them wherever you like.
FWIW, I don't think MoI's suppport of asset management is "one of the most important aspects of our workflow." In fact, I almost never use it unless it's for Kitbashing, which is a very niche effort.
I recommend trying OnShape or other full engineering CAD package if you're looking for asset management. MoI's stated intent is for artists, not engineers.
Hi agonyii,
I can understand why you would think this but it's not at all accurate, there is a large segment of the MoI user base that you're just not being exposed to, especially beginners who have no previous experience with CAD or any kind of 3D modeling because everything else they have attempted to use has been too complicated for them to get started with.
The primary focus of MoI up to now has been to make it quick and easy to make simple CAD models. Your target of working on big and complex designs is not aligned with that and so that's why you're running into problems. MoI just hasn't been specifically designed to do what you're using it for.
This will not be the case forever though, I do expect to gradually add functions to help with complex designs like you are working with. But this is a tricky process because it will always remain a priority for MoI to retain the ease of use and friendliness for less experienced people.
There have been a couple of significant steps forward for complex projects in v4 already - 64-bit support and faster file loading fall into this category.
The 64-bit support also required a rewrite to have a native Mac build as well. That ended up being about a 3 year effort that is still has a few loose ends to tie up even now. So there has been a very substantial investment of development time in an area beneficial to complex projects in V4 already. I'm sorry but there will not be time in the V4 time frame to add asset management in addition to that, it is something that I would like to work on in future releases though.
I'm sorry that MoI's overall design is not directly aligned with what you need it to do, maybe it is just not the right tool (at this time) for the job you need to do and some other progrram that puts a priority on complex designs instead of a priority on ease of use like MoI does would work better for you?
Thanks, - Michael
Tremendous helper this Script! Thanks a lot
My apologies if this subject has been covered before, but simply put : with MOI3D ver4.0 I can't seem to be able to make a snapshot.
Is it possible? I can't seem to find a script addon or anything relating to it for ver 4.0 . It works brilliantly for v3. Can anybody help?
Hi bluindigo, please see here for a script you can set up on a shortcut key to make a screen capture:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1049.5
Hello,
I just tried to install the customUi for the first time. I followed the instructions and placed the files in the roaming/moi folder but nothing comes up. I'm on Moi3D V3 if that makes a difference.
Hi ICMZ, those instructions only work for MoI v4, for MoI v3 you'll need to use the instructions on the first message of this thread and use CustomUI.1.03.win.mac.zip which is attached at the bottom of that message.
just installed Moi3d V3 with Custom UI on another PC. everything works exept Snapshot. what's wrong?
Hi glmr,
Probably due to restricted permissions, when launching MoI try right-clicking and use "Run as administrator", does it work ok then?
yes, it does! thank you
250-269
270-289
290-309
310-329
330-349
350-369
370-389
510-522
