Full Version: CustomUI
Show messages:  1-3  …  164-183  184-203  204-223  224-243  244-263  264-283  284-303  …  504-522
Message 6507.224 was deleted
13 Jan 2016   [#225] In reply to [#223]
Snapshot in CustomUI stopped working last year after reinstalling all Windows 7 programs to a new hard drive.
Previously it had worked. The snapshots directory is located alongside of "ui" and "commands."
To enable writing to Program Files (x86) \ MoI 3.0 \ snapshots, it was necessary to right click
on MoI 3.0, select Properties, Security, Edit, select my user name, and place a checkmark in
the write box, then apply. (Increases Administrator-like privileges)
Similar to using Michael's method here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.171
I was able to create a snapshot2 directory alongside snapshot directory, but was unable to relocate it to AppData directory.
I modified 84Snapshot2.htm to 85Snapshot2.htm file with
vp.render(w, h).save(moi.filesystem.getProcessDir()+"\\snapshot2\\"+time+"-["+vp.name+"].png");
and also modified the end of the last line to ==">Snapshot2</moi:CommandButton>
Also need to rename the function name to "function snapshot2(w, h, button, shiftkey, ctrlkey)
as well as its call in the last line.
Also added the snapshot and snapshot2 subdirectories to the file directory library for quick viewing access.
22 Mar 2016   [#226]
Is there a way to get CustomUi to work on Windows 10?
https://www.dropbox.com/s/vgs6cu0h454fwkg/test.png?dl=0
22 Mar 2016   [#227] In reply to [#226]
Hi ndrakey,
re: Is there a way to get CustomUi to work on Windows 10?
It does work on Windows 10 already, but it needs the final release of MoI v3 in order to run. From your screenshot it looks like your problem does not have anything to do with Windows 10, it's that you're running an older release of MoI which doesn't have the getUIDir() function that the error message is referring to.
Message 6507.228 was deleted
3 Mar 2017   [#229]
Balloons anyone? How to add mod your GUI with helpful tooltip commands:
sidePaneToolTipCode.zip
30 Apr 2017   [#230]
After some tricky tests :)
Seems using Custom UI with the cool Kitbash by Chipp Walter (42 item) http://moi3d.com/forum/index.php?webtag=MOI&msg=8398.1
that Name of Image and file 3dm must be the same and in Uppercase!
Size of image seems have no incidence!
1 May 2017   [#231]
Edit!
After new tests!
Image name and file 3dm must have excatly the same name!
Case is sensitive!
24 May 2017   [#232]
Unfortunatelly I got error message like this when starting Moi after copying files to Moi folder. Win10, any idea how to solve this problem?
24 May 2017   [#233] In reply to [#232]
I would double check to see that the files are in the proper directories.
24 May 2017   [#234] In reply to [#232]
Are you using MOI v2 or MOI v3?
24 May 2017   [#235] In reply to [#232]
Hi Dreviou,
You'll get that error if you're using MoI v2, the CustomUI requires the final release version of v3 so to solve it you'd need to update to the current version.
Message 6507.236 was deleted
24 May 2017   [#237]
That was it, v2, thanks guys! Now it works fine.
9 Jun 2017   [#238]
Hi
Does this still work? I get an error like the one above (for mac users) but I am on pc?
9 Jun 2017   [#239] In reply to [#238]
Hi cnever,
Yes, it still works with the current version. You'll get an error if you're using an older version of MoI though.
9 Nov 2017   [#240]
Thank you so much! :) I'm new to MoI and already got so good results quickly instead of modeling everything in Polygons! And your Addon makes it even better! :)
8 Jan 2018   [#241]
Hi everybody! :)
CustomUI v2
http://moi.maxsm.net/media/files/CustomUI.2.0.beta1.zip
http://moi.maxsm.net/media/files/CustomUI.2.0.beta1.CommandBar.zip
This version works with MoI v4 beta Dec-12-2017 only!!! (and with all later versions of course)
Now CustomUI should be stored in AppData directory.
Installation (Win):
Extract CustomUI.2.0.beta1.zip to C:\Users\<username>\AppData\Roaming\Moi\
Make backup copy of existing C:\Program Files\MoI 4.0 beta Dec-12-2017\ui\CommandBar.htm
Extract CustomUI.2.0.beta1.CommandBar.zip to C:\Program Files\MoI 4.0 beta Dec-12-2017\ui\
Installation (Mac):
Extract CustomUI.2.0.beta1.zip to /Users/<username>/Library/Application Support/Moi/
Make backup copy of existing /Applications/MoI v4 beta Dec-12-2017.app/Contents/Resources/ui/CommandBar.htm
Extract CustomUI.2.0.beta1.CommandBar.zip to /Applications/MoI v4 beta Dec-12-2017.app/Contents/Resources/ui/
8 Jan 2018   [#242]
Cool adaptation!
Bravo!
8 Jan 2018   [#243] In reply to [#241]
Wanderful!!
Thanks a lot Max!!
It works :)
