Full Version: Script list button next to object snaps
Show messages:  1-7  8-21
7 Feb 2014   [#8] In reply to [#6]
Hi Andrei;
That is a good idea. Here the updated files
-sharif
FavoritePlugins.htm
Plugins.htm
7 Feb 2014   [#9] In reply to [#8]
But how to put here something? Also I have no icons, and if I do not want to have all that scripts that instals with this plugin?
7 Feb 2014   [#10] In reply to [#9]
Hi Andrei;
This is very flexible. You can customize it to fit your workflow.for example open "FavoritePlugins.htm" in a HTML editor. You can delete the command line that you don't need or add another. Make sure to follow the same format, see attched image. For the Icons I have created some and be happy to share (see attached Zip file, just copy the icons you need to icon folder). They are not perfect but at least something to display. Most of scripts don't have associated icon yet. The scripts that don't have the associated Icon they will display with a ? mark.
Hope this helps.
-sharif
Script Icons.zip
7 Feb 2014   [#11]
Thanks Sharif ,Michael and others
Thank you for the info , addons and extentions for Moi. Very helpful.
kind regards
Mark
8 Feb 2014   [#12] In reply to [#10]
Sharif,but is it any way to put here simple scripts I do no know how to saw correctly, scripts that is inserted into moi shortcut list, not the external js or htm.
8 Feb 2014   [#13] In reply to [#12]
Hi Andrei, you should be able to put anything you put inside a shortcut key inside of a button, insert it into the command=" " part of the button.
The only thing to be aware of is if the script itself has any quote " characters in it, switch any of those to single quote ' characters instead so that they won't be taken as the end of the command=" " attribute itself.
8 Feb 2014   [#14]
Hi
Is there a way to change the background of the popup window
since i an using this colors for UI in Moi
9 Feb 2014   [#15] In reply to [#14]
Hi Hep;
Open the "Plugins.htm" file and modify the RGB value See attached image.
-sharif
9 Feb 2014   [#16]
Thanks, that work perfect ;-)
3 Apr 2015   [#17] In reply to [#4]
Hi
It would be helpful to get the custom scripts in a list as per image with just shortcut key like the space bar to activate. I love the list but would prefer to keep Moi UI as it is, without adding any buttons
There are so may good scripts coming out , its getting harder to have to remember the name and type them in all the time.
Mark
3 Apr 2015   [#18] In reply to [#17]
Maybe you can make a little file text where you can copy past from it the name of the script after Pressing TAB ?
3 Apr 2015   [#19] In reply to [#18]
"Maybe you can make a little text file where you can copy past from it the name of the script after Pressing TAB ?"
thats a very good idea, although still a bit long-winded
but it would be nice to see a list after pushing a shortcut key within Moi . With the great new subD tools , its becoming more important.
3 Apr 2015   [#20] In reply to [#17]
Hi Mark,
You might try this other script menu here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5993.1
That one does not add any buttons to the main UI, it pops up a dialog when you push your shortcut key to activate it.
3 Apr 2015   [#21] In reply to [#20]
Hi Michael
Thanks for the redirect and solution. This will be helpful.
kind regards
Mark
