Full Version: Script list button next to object snaps
Show messages:  1-13  14-21
8 Feb 2014   [#14]
Hi
Is there a way to change the background of the popup window
since i an using this colors for UI in Moi
9 Feb 2014   [#15] In reply to [#14]
Hi Hep;
Open the "Plugins.htm" file and modify the RGB value See attached image.
-sharif
9 Feb 2014   [#16]
Thanks, that work perfect ;-)
3 Apr 2015   [#17] In reply to [#4]
Hi
It would be helpful to get the custom scripts in a list as per image with just shortcut key like the space bar to activate. I love the list but would prefer to keep Moi UI as it is, without adding any buttons
There are so may good scripts coming out , its getting harder to have to remember the name and type them in all the time.
Mark
3 Apr 2015   [#18] In reply to [#17]
Maybe you can make a little file text where you can copy past from it the name of the script after Pressing TAB ?
3 Apr 2015   [#19] In reply to [#18]
"Maybe you can make a little text file where you can copy past from it the name of the script after Pressing TAB ?"
thats a very good idea, although still a bit long-winded
but it would be nice to see a list after pushing a shortcut key within Moi . With the great new subD tools , its becoming more important.
3 Apr 2015   [#20] In reply to [#17]
Hi Mark,
You might try this other script menu here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5993.1
That one does not add any buttons to the main UI, it pops up a dialog when you push your shortcut key to activate it.
3 Apr 2015   [#21] In reply to [#20]
Hi Michael
Thanks for the redirect and solution. This will be helpful.
kind regards
Mark
