Full Version: [script] FxGraph - 2D/3D Function plotter
Show messages:  1-9  10-29  30-49  50-69  70-89  90-91
5 Aug 2017   [#70] In reply to [#63]
Al, Thank you for getting me started with Elephant.
I've been studying your Basic Parametric Moebius.nod and finding it difficult to understand how it could produce a solid Moebius strip when my many attempts to do so (outside of Elephant) have failed when using Loft to make the complete strip in one go.
Eventually - it took a while - I realised that your node is not producing a solid Moebius strip - with only one surface - but a strip with two surfaces. See below.
Did you also do the moebius.nod? No problem with the strips in that however I've temporarily given up trying to fully understand the nod - it's too complex for me at the moment.
Mike.
10 Aug 2017   [#71]
Hi.
Just stumbled over this information ...
https://mathematica.stackexchange.com/questions/72203/can-mathematica-solve-plateaus-problem-finding-a-minimal-surface-with-specifie
... which may be of interest for marh magician Brian ..
25 Aug 2017   [#72] In reply to [#70]
Hi Mike
By reading your observations, I have checked again
the file I sent, actually something is wrong,
the profiles, which are dorsal oriented that determine the volume
are badly oriented and thus produce a final screwing,
I've reviewed the file that you find at this link:
http://www.mediafire.com/file/9u89bmm8b6lfgyj/Rev-Solidify_Moebius_Strip.rar
I also added some pictures that will make you better
the question...
In the end however, as you see the result is a solid one
best
al
27 Aug 2017   [#73]
HyperbolicParaboloid1:
_FxGraph3D u;v;u*v;-1;1;-1;1;50;50;0;0;0;UV
HyperbolicParaboloid2:
_FxGraph3D a*(u+v);b*(u-v);u*v;-1;1;-1;1;50;50;1.618;1;0;UV
HyperbolicParaboloid3:
_FxGraph3D (u);(v);c*((u*u)/(a*a) - (v*v)/(b*b));-1;1;-1;1;50;50;1.618;1;1;UV
HyperbolicParaboloid4:
_FxGraph3D (u);(v)/(sqrt(1+a*a*u*u));v*a*u/(sqrt(1+a*a*u*u));-1;1;-1;1;50;50;1;1;1;UV
17 Sep 2017   [#74]
Trefoil2_3FourierKnot:
_FxGraph3D cos(2*u);cos(3*u + PI/4);cos(2*u + PI/2)+cos(u + PI/6);0;6.283185;0;0;200;0;1;0;1;UV
Note, there is a small space in the unclosed curve, locate-able by _MarkOpenCurveStart, or MarkCurveStart, or MarkCurveEnd script.
Trimming the curve with a point at say (0,-1,z), and blending the gap, will make a closed curve.
17 Sep 2017   [#75]
Bohemian Stars (Torolf/jotero):
_FxGraph3D cos(a*u)*cos(v) + b *cos(u);sin(v);-sin(a*u)*cos(v) + b*sin(u);0;6.283185;0;6.283185;100;10;1.5;1.1;0;SrfU
This is one version. Parameters "a" and "b" make a big difference.
18 Sep 2017   [#76] In reply to [#75]
Brian - fascinating.
The fine adjustment now available on the slider node made me wonder whether a nod for this would help to explore the effects of changes to a and b.
BTW with the example shown below I made into a solid via extrusion of 0.1mm.
Mike.
Bohemian stars.nod
18 Sep 2017   [#77] In reply to [#76]
Impressive node, Mike.
I may try a 2d slider for a and b.
Got to do a Mod version of Max's release .94...
Just copied the extension directory of Mod version to Max's release 0.94, nodes directory.
Mouse wheel works on sliders & knobs.
18 Sep 2017   [#78] In reply to [#77]
Ah, yes, that new feature in 0.94 plus the later interface.js (see 7713.620) was what inspired me.
Mike.
1 May 2020   [#79]
Viviani's curve:
_FxGraph3D a*(1+cos(v));a*(sin(v));2*a*(sin(0.5*v));0;1;-6.2831853;6.2831853;0;200;0.5;0;0;UV
I plan to do a sphere sweep on this curve.
2 Jan 2021   [#80]
Doe this work with V.4.0?
2 Jan 2021   [#81] In reply to [#80]
Normally yes! ;) (tested)
And bravo to Max Smirnov for this true gem!
Fermat Spiral in the V4 with extrude to point + a little sphere! ;)
So yes all is working like a charm!
You can see at my little site https://moiscript.weebly.com/fx-graph-3d.html
2 Jan 2021   [#82] In reply to [#81]
I feel like this website has changed a bit! "http://moi.maxsm.net/"
Those days when I did only had accesses to trial versions of Moi3D I could see the instructions on how you could activate FxGraph.
I cannot find it now! Also there were a place I could see different versions of Max's scripts now I cannot find those!
is v.1.1.2016.04.17 the latest version of FxGraph?
I need a little help to get it up and running cause I forgot how it was done!
I'd be happy if you help me :-)
2 Jan 2021   [#83] In reply to [#82]
Hi Psygorn,
That is the latest version of FxGraph3D, as far as I know.
(Except that the nodeeditor program MathPts performs more or less the same as FxGraph3D. Inputs a,b,c,d can be added.)
The two files FxGraph3D.exe and the .htm file, (I use _FxGraph3D.js and _FxGraph3D.htm), can be placed in the MoI command folder, OR (for myself) it goes in %APPDATA% \commands folder with all of my other "non_stock" MoI programs, (excepting nodeeditor node programs.). (CustomUI can access the program.) (Or Shortcut key)
Parameters for FxGraph3D can be added manually,
or else a string of values matching the manual entries can be (Tab) copy pasted from say a text editor, into the command window, enter.
Or see Michael's and Burr's method earlier in this thread.
Edit: Added 3D suffix.
2 Jan 2021   [#84] In reply to [#82]
All Max Plugins updated http://moi.maxsm.net/media/files/
the 2 Graph FX
http://moi.maxsm.net/files/scripts/FxGraph3D.v.1.1.2016.04.17.zip
http://moi.maxsm.net/files/scripts/FxGraph.v.1.2e.2016.04.17.zip
Unzip and put them in the Moi's commands folder
A sort of Manual but sorry in French
https://moiscript.weebly.com/fx-graph.html
2 Jan 2021   [#85] In reply to [#83]
Hello Bemfarmer,
tanx for the info I have downloaded CustomUI.2.0.beta2.zip file from "http://moi.maxsm.net/media/files/"
I have it unzipped now I see for folders inside of it (customUI, Objects, Snapshots & Startup)
What is the next step? Where should I copy these folders to have it up and running?
Or how can I use FxGraph using a short key?
2 Jan 2021   [#86] In reply to [#84]
Dear PILOU, what is the difference between these two?
1-http://moi.maxsm.net/files/scripts/FxGraph3D.v.1.1.2016.04.17.zip
2-http://moi.maxsm.net/files/scripts/FxGraph.v.1.2e.2016.04.17.zip
1 is 3D and 2 isn't?
if they both are the same then which one is the latest? 2?
2 Jan 2021   [#87] In reply to [#85]
Hi Psygorn, CustomUi and FxGraph are different things, one is a UI mod that adds several buttons on the bottom toolbar and the other is a plug-in command.
For installing CustomUI see here for where to copy the files:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.452
For FxGraph unzip it and copy the files into the MoI appdata commands folder, it's in the same location as described in the above link for CustomUI as well.
2 Jan 2021   [#88] In reply to [#86]
Hi Psygorn,
They are different - FxGraph plots a function curve (parametric function of one parameter) while FxGraph3D plots a surface (parametric function of 2 parameters) .
The latest ones are on Max's file archive page:
3 Jan 2021   [#89] In reply to [#85]
Hi Psigorn,
Excellent responses from Michael.
Pilou site looks very good. (Based upon my poor French.)
(Understandable, concise, succinct, with examples...come to mind)
(Added 3D suffix in my previous post.)
