Full Version: STL save as assembly
Show messages:  1-4  5-24  25-28
4 Dec 2013   [#25]
It shows off your software nicely
27 Mar 2023   [#26]
Hi ,
I am using this handy plugin as well .
I am getting segmented curves in STL at diameters greater than 100mm. I did look in the script and only see angle @ 5
I typically use angle 6 , divide 1 - all and minimum .25 when exporting to get smooth curves
How do I add divide 1 - all and minimum .25 to the script?
27 Mar 2023   [#27] In reply to [#26]
Hi DVR,
It would need to set up an options string that looks like this:
NoUI=true;Angle=5;MaxLength=1;MaxLengthApplyTo=all;MinLength=0.25
I've attached a modified version of the script that will do that.
SaveMultiSTL.js
27 Mar 2023   [#28] In reply to [#27]
Thank You Michael!
This works brilliant . Do not have to remember the settings anymore
