 2-21
 22-28
It would just be ambient noise while I focus on what your doing.
Ray Dream was my first 3d modeler.
A quick print out of the CreatureBox JellyBean character, I used to paint warhammer figures years ago so I will break out my paints and get him colored up.  The figure is about 4"" tall, I had to change the diameters on the arms cylinders and fingers to get them to be rigid enough to clean up...still has the same feel though
That is sure a nice printer you've got there.
     -  Michael
It shows off your software nicely
Hi ,
I am using this handy plugin as well .
I am getting segmented curves in STL at diameters greater than 100mm. I did look in the script and only see angle @ 5
I typically use angle 6 , divide 1 - all and minimum .25 when exporting to get smooth  curves
How do I add divide 1 - all and minimum .25  to the script?
Hi DVR,
It would need to set up an options string that looks like this:
NoUI=true;Angle=5;MaxLength=1;MaxLengthApplyTo=all;MinLength=0.25
I've attached a modified version of the script that will do that.
SaveMultiSTL.js
Thank You Michael!
This works brilliant . Do not have to remember the settings anymore
 2-21
 22-28
