Full Version: STL save as assembly
Show messages:  1-19  20-28
14 Nov 2013   [#20] In reply to [#19]
I would have to say I don't think I've seen anybody render with Carrara as well as you..... I wish I was a fly on the wall in your work area for a bit....
Thanks for sharing.
15 Nov 2013   [#21] In reply to [#20]
LOL....You would hear a lot of cursing and screaming that DAZ has let the product languish technically since they purchased it to emphasize their....."content" delivery
15 Nov 2013   [#22] In reply to [#21]
It would just be ambient noise while I focus on what your doing.
Ray Dream was my first 3d modeler.
3 Dec 2013   [#23]
A quick print out of the CreatureBox JellyBean character, I used to paint warhammer figures years ago so I will break out my paints and get him colored up. The figure is about 4"" tall, I had to change the diameters on the arms cylinders and fingers to get them to be rigid enough to clean up...still has the same feel though
3 Dec 2013   [#24] In reply to [#23]
That is sure a nice printer you've got there.
4 Dec 2013   [#25]
It shows off your software nicely
27 Mar 2023   [#26]
Hi ,
I am using this handy plugin as well .
I am getting segmented curves in STL at diameters greater than 100mm. I did look in the script and only see angle @ 5
I typically use angle 6 , divide 1 - all and minimum .25 when exporting to get smooth curves
How do I add divide 1 - all and minimum .25 to the script?
27 Mar 2023   [#27] In reply to [#26]
Hi DVR,
It would need to set up an options string that looks like this:
NoUI=true;Angle=5;MaxLength=1;MaxLengthApplyTo=all;MinLength=0.25
I've attached a modified version of the script that will do that.
SaveMultiSTL.js
27 Mar 2023   [#28] In reply to [#27]
Thank You Michael!
This works brilliant . Do not have to remember the settings anymore
