Full Version: STL save as assembly
Show messages:  1-15  16-28
13 Nov 2013   [#16] In reply to [#15]
""I worked at the Deep Submergence Unit """""""""""
Intense stuff.... :o
Take care.
14 Nov 2013   [#17]
OK, here is a telescopic riser joint I am using as a classroom aid for my training program..
An actual TJ in service onboard an offshore rig. It is 65 feet long and 75,000lbs.
The render of one made with MOI
The build of the classroom model
The class model after clean up
14 Nov 2013   [#18] In reply to [#17]
Me likey!!!
Is that render still Carrara?
14 Nov 2013   [#19] In reply to [#18]
Yes it is....old habits die hard
14 Nov 2013   [#20] In reply to [#19]
I would have to say I don't think I've seen anybody render with Carrara as well as you..... I wish I was a fly on the wall in your work area for a bit....
Thanks for sharing.
15 Nov 2013   [#21] In reply to [#20]
LOL....You would hear a lot of cursing and screaming that DAZ has let the product languish technically since they purchased it to emphasize their....."content" delivery
15 Nov 2013   [#22] In reply to [#21]
It would just be ambient noise while I focus on what your doing.
Ray Dream was my first 3d modeler.
3 Dec 2013   [#23]
A quick print out of the CreatureBox JellyBean character, I used to paint warhammer figures years ago so I will break out my paints and get him colored up. The figure is about 4"" tall, I had to change the diameters on the arms cylinders and fingers to get them to be rigid enough to clean up...still has the same feel though
3 Dec 2013   [#24] In reply to [#23]
That is sure a nice printer you've got there.
4 Dec 2013   [#25]
It shows off your software nicely
27 Mar 2023   [#26]
Hi ,
I am using this handy plugin as well .
I am getting segmented curves in STL at diameters greater than 100mm. I did look in the script and only see angle @ 5
I typically use angle 6 , divide 1 - all and minimum .25 when exporting to get smooth curves
How do I add divide 1 - all and minimum .25 to the script?
27 Mar 2023   [#27] In reply to [#26]
Hi DVR,
It would need to set up an options string that looks like this:
NoUI=true;Angle=5;MaxLength=1;MaxLengthApplyTo=all;MinLength=0.25
I've attached a modified version of the script that will do that.
SaveMultiSTL.js
27 Mar 2023   [#28] In reply to [#27]
Thank You Michael!
This works brilliant . Do not have to remember the settings anymore
