9-28
29-48
49-68
69-88
89-108
289-296
I am a non-expert, but did a google search for lineweight sketching, and line weight hierarchy. Found 3 rules here:
http://www.sketchmyworld.com/line-weight-importance-in-product-sketching/
Basic Line Weight Usage
1.The thinnest line is used to describe the edges of a product that point towards a viewer and also for the inner lines.
2.Second thickness lines are used for outlines (edges that have air behind them). These are not only contour lines, but can also occur within an object.
3.The thickest lines are used for the baselines – lines that show the interface between a product and a ground plane.
(Seems like there are a whole lot of drafting and architectural standards for line weight and line type. A person could
spend a lot of time on this subject, I guess.)
hi micheal
FYI info I have enclosed 2 screenshots of what Isodraw CADprocess churns out from the 3D models. There are two line thicknesses. have colored the thin one blue zoo you can see easily.
It is by no means a perfect process and i usually have to tidy some parts up but it saves me hours.
Matt
There is a pretty good explanation for the use of different line widths at the beginning of this pdf:
www.conradiator.com/downloads/pdf/Linethicknesses.pdf
Edit: Added link to paper. Deleted pdf as it is copyrighted.
This paper looked pretty cool. Maybe some good ideas?
www.gvu.gatech.edu/~jarek/graphics/papers/11DrawingSousa.pdf
The example I've posted previously seems to be taken from page 215 of the book "The Complete Technical Illustrator" by Duff/Maxson and I agree there's some personal choice by the illustrator involved about what lines get thick or thin.
Actually the way I would do it and also the way that seems to be most logical is the attached result by Cinema4Ds Sketch & Toon renderer. This is also similar to mattj example from post 6201.28 but without the "overshoot" which again is a personal style.
Hi eric,
> Just using the viewport display as an example ... I would like to be able to export to .pdf with this look.
Yeah I think that will be possible. Probably by default the hidden lines on PDF export will not be displayed but I'll put in an option for having them and when they are enabled it would make sense to give them a faint dashed line style in the PDF file as well I think.
> Now when I export to pdf the hidden lines are solid and as strong as the outer edges.
Yeah in the current version it's just a total wireframe export with no hidden line determination happening at all, this new stuff I'm working on is a major change in this area.
> However, the hidden lines only show as dashed when I zoom in as far as my display allows
> but when I save the normal sized screen display to the clip board and then import it in PhotoShop
> the hidden lines are simply faint light lines ... so if I had a choice I would like the hidden lines to
> display as somewhat thicker than they are now and a little more broken.
Are you using a keyboard shortcut script to do the transfer to photoshop currently? Can you please post the script that you're using? It's probably possible to adjust the script to increase the line width and that ought to make the dash pattern scale up as well so the spaces between dashes won't be so tiny. Right now the dashes are probably so tiny in comparison to the rest of the image that they blur all together.
Hi Matt, so in this last one that you've posted, this one here (from isodraw):
That's slightly different than what you posted before or what was in Martin's example, because both of those edges are thick in this one, meaning both the red and the blue one I've indicted here:
In your other case you had only one of those edges thickened... With only one thickened the question becomes "which one should it be"... and if it's just an artist's judgement call that's not easy to replicate in computer code.
So I'd probably be shooting for doing the same as Isodraw here and having all silhouette edges get thickened...
Does that make sense? Or is there some specific rule for targeting just one of these 2 possible hole silhouette edges?
Yeah I guess that a "sketch" has its own kind of structure that's somewhat separate from "technical illustration".
In the future I would really like to have more options for sketch like output as well but first I think the focus will be more on the illustration and "shop drawing" type stuff instead.
Hi Martin,
The style you're showing here is having an accent on the "border against background", having thickness just where the shape touches the background. That's what I'd like to enable by some kind of "outline" option for extracting out those curves.
The other style is not just a difference with "overshoot", it's more about accenting all silhouettes of the object, not just the outermost one. A shape like this should show a bigger difference:
Just the "outline against background" would be like this:
But all silhouettes would be like this:
So I think I want to be able to do both of these kinds of things, like one option to get silhouettes into their own kind of group and another option that will extract out the outer outline only.
Maybe when enabled the outer outline curves would be a duplicated set of curves going over top of the other kinds though.... Not quite sure about that part.
Hi Matt, also I see now that one thing I got confused about comparing your "insect walking" picture against the one Martin posted, was that your one was only a depression and not a full hole all the way through, is that right?
That's why you only had one accented line there, because there was a floor in yours.
Martin, the one that you posted from
http://purdy.gatech.edu/wp-content/uploads/2012/07/2_line_wt.pdf - I don't see how I'm going to be able to get that same result with only one of the silhouettes of that through-hole being accented, it's not clear to me which one it would supposed to be so instead I'll probably do both of them.
"""""""""""""I'm not sure about doing a preview, it would be nice to have but I've got to balance that against how much time it would take to implement it"""""""""""""""
I understand, it might be overkill for this feature.
An options button might be interesting instead of adding another dialog.
It would make it a simpler and less intrusive, you change it only if you have to.
Saves could 'stick' between sessions.
Marc
I regret posting this as it just added confusion. I didn't look carefully. The example shows a subjective way thats difficult or impossible to put into some sort of rule.
I'm fine with your "border against background" method that gives me a rendering like this:
What will the rule of the internal up arc-circles if this block was on a red table ?
Same rule than an empty backgorund ?
B is satisfying ?
An not only the 2 little arc circles ! As soon as a line has a free touch background all the line must be large!
So a very complex rule!
It's not complicated: Every edge that "touches" the background must become thick.
It's a way to better visualize the object.
The same way Photoshop would apply an Outer Glow Layer Style to a transparent pixel image.
So your example must look like this
Yes simple for your example and rule but i have spoken of this one (and it's mixed rule under lined)
who seems it-self not well applyed on its example! :)
So be simple is the more easy way! :)
Martin's rule looks very good, and simple, for having a "heavy" and a "light" line weight.
As in Conrad Taylor's pdf, adding an intermediate line weight, and/or continously tapered line weights,
and/or broken lines, and/or dotted or dashed lines could add additional rules for the computer programmer to figure out :-)
Background tone helps visualization also.
When I was an art director, this was how I taught my artists to weight their line-art drawings.
To emphasize depth. More interior detail would carry thinner associated line weights.
Impossible, I know. The little inside-only buildup doesn't sit well with me.
None the less, I'll be happy to see what comes of all this.
On this object that seems yet easy
but for a complex one that surely be a nightmare for the coder! :)
Because there is no logic reason that the entiere side circle will be not entierely large, if the straight line "horizontal" is itself large!
They are "touching" both some empty "background"!
This certainly looks very good but I have a hard time understanding the rule that requires to continue the thick horizontal line into the object. It's an aesthetical choice isn't it? It looks good and helps even more to understand the shape but it seems to be impossible to put into an algorithm.
9-28
29-48
49-68
69-88
89-108
289-296
