178-197
198-217
218-237
238-257
258-277
278-296
Etno...logic! :)
Down to one thing left on the cleanup list!
must be one day to go then . . . :-)
Zero things left on the list! I'll see if I can make a build before I fall asleep...
Suspense!
New Nov-19 beta is up:
http://moi3d.com/beta.htm
It will take me a bit to assemble the release notes and make the regular main announcement.
The main new thing is hidden line removal when exporting to AI, PDF, and DXF formats.
If you make some nice hidden-line exports to PDF / AI / DXF, it would be cool to see some posted here!
Some quick notes:
Shift while drawing now works for an enhanced straight snap. When you hold down shift straight snap will have priority over object snap, and the current straight snap line will stay locked on for as long as you hold shift. Also when you hold down shift straight snap will activate to the closest straight snap line regardless of how far away it is to the mouse.
AI format for clipboard transfer should work on on OSX.
Some bugs fixed in surface/surface intersection, some cases that didn't work before with things like 2 pipes crossing each other should work better now.
Layers are exported to DXF format
Bug fixes to Blend between 2 edges that touch each other at sharp "pole points", and to order sorting for loft to point.
Thanks Michael! Very cool outcome.
Here's one straight off the bat without delving too much, piece of cake with professional result :)
Just at first glance a couple of things; an option to open the file after generation for PDF I guess don't know about the other two formats they'd have to be associated to a program.
Landscape/Portrait option?
That's all for now.
Final_assembly_01.pdf
Thanks Danny - that's a good looking result right off the bat! :)
I think I see a couple of spots where some silhouettes may have been missed, can you please e-mail me that model to
moi@moi3d.com so I can test some with it?
Maybe just for PDF only I guess? The other formats are kind of more editing oriented...
Yeah some page setup stuff would probably be good. I'm not entirely sure if I'll get that in quite yet, I am a little burned out on wrestling with PDF. But it would be good to be able to get a final PDF generated straight out.
Thanks for testing it!
@Michael
French version on your Email! ;)
The output is amazing. Top quality, even better than top Cad applications i've seen.
There's one question: i'm only able to output the 3D view, even when i choose to output some other view, Moi still output allways the 3D View. Maybe there's a bug or i'm doing something wrong.
Cheers.
Carlos
Attached is a screen shot of my PDF. Works great!
This is a desk-top CNC milling machine I just spent three months modifying to greatly increase its accuracy. I used MoI to help me visualize how the new components and custom-machined parts would integrate into the machine. With MoI I did a lot of design modifications "on screen" before custom-machining several parts. As a result, it worked perfectly the first time.
My choice of colors is weird, but the output is very nice.
Ed
Marysville, Washington
Click images to enlarge:
thanks for making the new Beta available. Here's a quick PDF export of one of my models. If there wheren't some important missing lines it would be perfect. Is this my fault (bad modelling) or are you able to tune the export to avoid this? If you want the 3dm file let me know.
-Martin
vise.pdf
Tried it, and it works good! Just one thing, that maybe its my fault, but lets say, for example, I make a cylinder, and export the front view in dxf. It should be a rectangle, and indeed it is, but at some corners the lines are not touching exactly. Am I doing something wrong?
Awesome Michael,
here are two simple model of mine, as .pdf output with standard settings.
Best regards
Yep, i was doing it wrong, so no worries. I was saving instead of exporting it.
The control of the output is perfect. Thanks.
Carlos
I'll just put all the replies in one message here...
@Carlos
> something wrong.
Are you setting it by the "Projection view" option in the export dialog? (as opposed to for example just maximizing a particular view)
Do you possibly have a custom CPlane set that has altered the Top/Front/Right views to make them look as if they were a 3D view?
Do other settings on the dialog like enabling outlines on/off work ok?
@Ed
This is a really cool way to use MoI and the PDF output looks great too!
@Martin
I think what you're seeing there is if 2 objects are just sticking partially through each other, they just end up hiding pieces of one another and no separate curve for the intersection between the parts is generated. Basically the hidden line removal engine will only generate silhouettes as new things to display, not intersection curves. That's mostly because it can be highly time consuming to try and generate intersections between everything. So usually to get a totally clean output you need objects not to just stick through each other but to be booleaned together so they have edge geometry where they run into each other. You can also use Construct > Curve > Isect to generate intersection curves before doing the output as well. If that doesn't describe what you're running into there, can you please send the 3DM file to me at
moi@moi3d.com so I can take a look?
@Max
Whether things are hidden or visible is determined by an internal pixel grid, so the resolution of that grid has something to do with the accuracy of how tightly a hidden spot matches up to other things. You can increase the density of the grid to get better accuracy, try adjusting the "Canvas megapixel resolution" parameter up to 30 or 40. Note that this will also generate a higher resolution shaded background image which will increase file size too.
I have a couple of ideas for some things to try to increase the accuracy of this (separate from the pixel grid density) for the cases of edges being hidden because they're crossing over a silhouette. Can you please send me the 3DM model file with the particular cylinder that you were looking at so I have a good known simple example case to work with?
For the moment though increasing the "Canvas megapixel resolution" parameter should help.
@ Stefan
Wow these are looking mighty nice! Crisp and clear. Being able to get this kind of output really easily now opens up a lot of possibilities!
Looking good so far! :)
Hi Carlos,
Actually it's supposed to work the same no matter whether you're doing "Save As" or Export...
But one thing to note is that the view is controlled by the view setting on the dialog, not whether you have a particular view maximized in the modeling UI or not. Is that maybe what you were running into?
Please let me know if you do see a difference in behavior between Save and Export for the view handling, it's not supposed to be like that.
178-197
198-217
218-237
238-257
258-277
278-296
