167-186
187-206
207-226
227-246
247-266
267-286
287-296
Thanks very much Michael!
Ok, just 2 things left on my cleanup list before putting out the new beta.
Yep ... big smile here too.
eric
Any more surprises than the PDF in the next beta ? :)
The PDF/AI/DXF export is the main thing, there are a few other minor new things as well.
you're just teasing us now . . .:-)
... and probably tucked up in bed whilst leaving us to stew overnight ;-)
Martin.
http://www.merriam-webster.com/thesaurus/banner[adjective]
I've seen this phenomena before...
Etno...logic! :)
Down to one thing left on the cleanup list!
must be one day to go then . . . :-)
Zero things left on the list! I'll see if I can make a build before I fall asleep...
Suspense!
New Nov-19 beta is up:
http://moi3d.com/beta.htm
It will take me a bit to assemble the release notes and make the regular main announcement.
The main new thing is hidden line removal when exporting to AI, PDF, and DXF formats.
If you make some nice hidden-line exports to PDF / AI / DXF, it would be cool to see some posted here!
Some quick notes:
Shift while drawing now works for an enhanced straight snap. When you hold down shift straight snap will have priority over object snap, and the current straight snap line will stay locked on for as long as you hold shift. Also when you hold down shift straight snap will activate to the closest straight snap line regardless of how far away it is to the mouse.
AI format for clipboard transfer should work on on OSX.
Some bugs fixed in surface/surface intersection, some cases that didn't work before with things like 2 pipes crossing each other should work better now.
Layers are exported to DXF format
Bug fixes to Blend between 2 edges that touch each other at sharp "pole points", and to order sorting for loft to point.
167-186
187-206
207-226
227-246
247-266
267-286
287-296
