123-142
143-162
163-182
183-202
203-222
223-242
243-262
283-296
hi michael
i was thinking the logical place for access to pre saved view is on the window itself . . on clicking a list would appear in top right where usual prompts appear . .
matt
Hi matt,
It's a big goal with MoI to avoid "bloating" the UI up with things that are for more specialized use... So I'd probably try to avoid putting that in such a high profile area.
It is often challenging to incorporate new features for "power users" while at the same time keeping the overall light and easy-to-learn aspect of MoI.
Thanks.
Carlos
hi michael
I fully understand. Maybe a switch in prefs where power users can switch on some extras. Of course if its too simple you run the risk of dimming down the software imo. MOI certainly has a lot to offer and when i first began using it i noted it was good but seemed a little "empty" of features - how little I knew then!!! It has most things I can think of . .
matt
"Maybe a switch in prefs where power users can switch on some extras"
In my experience, this is usually a downward spiral. Basically think of a switch as doubling the testing workload and adding to maintenance overhead. That's how you have to weigh every checkbox you add to an app. It can get deadly pretty quick.
The best idea is to design the UI so that it works for everyone. Maybe the power users aren't 100% satisfied but if they can get to an 80% happiness level with it, that's enough.
Maybe a cool solution will be a customisable UI where user can put for example all icons for it's scripts on a new dock ! ;)
thats sounds good, a kind of personal tool panel . . .
matt
I've thought before about making the empty space after the "Object Snap" button be a place where you could place your own icons to have a customized tool area.
But there is a lot of work involved in doing UI customization, right now more fundamental tools are still higher priority.
It is actually possible to customize the UI in a manual sort of way right now by editing the .htm files inside of the \ui directory inside of MoI.
Ok, I've been working on getting a UI to control this stuff for exporting to AI and PDF formats.
This is what I'm currently going to try:
Scale can be either "Fit to page" or "Preserve units".
If you push "Line style options", then another dialog will pop up that will let you control how the different kinds of lines are written for line width, color, and if they should go on a specific layer. You can pick "From style" if you want the color or layer to come from its style assignment, or "Custom" if you want to override that with a specific color or layer instead.
Please let me know if anything important looks like it is missing.
Make the dialog box "adaptative" (in horizontal dimension) for the future text translation! ;)
Yup, that is how it works already - the dialog is automatically sized to fit the content inside of it. If the translated text is longer the dialog will also get wider as well.
this looks perfect, orderly and by no means overloaded or too complex to me.
I suppose choices are sticky so one has to set this only once to his/her personal needs.
There's a typo in the export window: silhouettes should have one more T.
What unit are the line widths (0.1, 3, 0.4 ..) in the export option window?
Maybe a little example image with arrows for show the different possibilities will be a big help!
(outline, silhouette etc...
Hi Martin,
Great! At first I was trying to put it all on one single dialog and that was getting pretty overloaded. I also experimented some with having a different individual dialog for doing the line type (width / color / layer) of each category but it kind of seemed nice to have that all on one place so it was easier to see them all at once.
Yeah I want to save everything you see there in moi.ini so any changes you make here will persist between sessions.
Thanks for catching this!
In "points" units.
Thanks, - Michael
It's a good idea, but I think it would be kind of hard to show it very clearly without some fairly large images, and that would then somewhat overwhelm the dialog.
Some example images would probably work work well in the help file.
hi michael
looks good. For me the only thing missing is another option in scale drop down menu - I would love to be able to set a percentage - i.e.. 20%. I think is maybe not an option which is yet programmed . . .
matt
I was going to ask for even more complexity :-) i.e. an units option for the line width but then I remembered that one typographic point equals 1/72 inch.
Since its a set and forget setting here's a quick table showing the point values for different technical pen sizes.
The formula is MM / 25.4 * 72
Yes, i agree.
Otherwise its perfect. It will improve my workflow by 500%. Thanks.
Carlos
This is quite detailed!
it's becoming a quite hefty feature.
Too me it looks great, maybe a resolution indicator in gray text next to the megapixel input box could be handy.
I'm not used to size things in megapixels and seeing the resolution would help to figure out, for example if I need something around 2500px wide for a letter size image @300dpi.
Marc
Hi matt,
You should be able to get a percentage scale using the "Preserve units" option shown above... To scale by 20% you would say:
1 unit in MoI = 0.2 units on page
Won't that do what you are asking for? Or do I maybe not understand how the percentage scale is supposed to work?
123-142
143-162
163-182
183-202
203-222
223-242
243-262
283-296
