Full Version: Hidden line removal progress
Show messages:  1-13  …  54-73  74-93  94-113  114-133  134-153  154-173  174-193  …  294-296
11 Oct 2013   [#114] In reply to [#113]
>Does the folder happen to be the Temp folder?
No they're in a folder called outline test on the desktop. Isn't the temp folder a Windows thing? Never saw one.
>Do you get different behavior if you use File > Open inside of Illustrator to open the file rather than double clicking the file itself?
Tried everything. My Illustrator CS3 doesn't like the large PNG file. Although dragging the .png file into Illustrator worked but it came in way too large. We need another one with CS3 for testing.
11 Oct 2013   [#115]
Some feedback, concerning the AI file:
Illustrator CS2 (win7) and CC (Mac OSX 10.8.5): Working nicely. Got 3 layers, stacked in proper order, easily selectable. Can place/import the PNG file. Fantastic!
Illustrator CS4 (Mac OS X 10.8.5): Not working, at all: says it get an error and do nothing, it just ignore it. Also can't place or import the PNG file into. In my personnel case its not important 'cause we don“t use CS4 anymore. Maybe it affect some other user. Its better to let you know. Or maybe its something on my end, don't know.
Concerning the PDF file: It works, in every of the above setups, but don't have layers as it make hard to select. From my experience i got several no layered PDF files from others, but i think its a case of not tick on 'Perserve Illustrator Editing Capabilities' when saving as PDF, otherwise it export with layers.
Concerning the PNG file/render image:
Photoshop CS2 (win7) and CS4 and CC (both Mac OSX 10.8.5): Working nicely, its in 1 layer with transparentcy, but no AntiAliasing, so it's stepped/jagged on the outline.
The AA issue can be solved with a slight Blur Filter in Photoshop. Its a pretty big image, which is good for print work.
Overall, well done. Thanks.
One question concerning the rendered image: Looks the material main color is a Grey. It will be possible to pick 1 different color on export? It could help on the readbility. Anyway i could do it in Photoshop.
Carlos
11 Oct 2013   [#116] In reply to [#115]
Thanks for all the feedback Carlos!
> export with layers.
That "Preserve Illustrator Editing Capabilities" thing makes Illustrator save a big chunk of private undocumented information in the PDF file that contains illustrator specific data. Illustrator uses that method for making layers come in through PDFs but it only works for PDFs saved by Illustrator itself, not from any other method of PDF file generation.
Since that Illustrator specific data is not documented there isn't really any way for a separate program (like MoI for example) to get layers into Illustrator by PDF import only since Illustrator does not read them in from the regular PDF data.
But it does read them in from the AI v8 format, so that's the format you'll want to use for the transfer if you want layers to come over.
That's pretty weird that CS4 does not work. That's good to know though.
It just happened to be in this case since all the objects were using the default style. The shaded colors will come from the style assignment and look the same as they do in the regular MoI viewport display.
11 Oct 2013   [#117]
That is is great, it will be very helpfull to have different colors on different parts, visually communicating some functions or how something have to be constructed.
Its great to comunicate with others.
Thanks.
Carlos
11 Oct 2013   [#118] In reply to [#96]
Hi Michael, the AI file works great in Illustrator CS6 64bit.
The bitmap doesn't import in Xara but I don't care since it works so well with a layered PDF.
Maybe adding a bitmap option in the export dialog would be nice?
Those who don't know the viewport export scripts or can't work with PDF might find it handy.
On the other hand the export dropdown list will start to be crowded.
Some programs have 75 choice in the dropdown, having to search each time for the right one is somewhat annoying.
An idea would be to separate export types; Solids, Polygonal, 2d.
Marc
11 Oct 2013   [#119]
For me, it's exactly what I need. Thanks michael
11 Oct 2013   [#120]
Hello,
That's great news that it keeps the points as is. On a related note, does MoI have a curve extrapolation function? In the areas where the hidden line generation doesn't completely close off the area or it gets a bit wobbly I import that portion of the AI into Rhino and VSR has a very handy extrapolation function to extend the line so it can be trimmed. Another handy tool that is free for AI to connect lines with curves is SubScribe from Astute Graphics if you don't want to pay for the other plugins.
11 Oct 2013   [#121] In reply to [#118]
Hi Marc,
I've got Xara 8 & 9 (Photo & Graphics Designer versions) & everything imported just fine.
See attachments.
11 Oct 2013   [#122] In reply to [#118]
Hi Marc,
You mean something like a "PNG Image (*.png)" just directly listed in the file dialog for Export or Save As?
That would certainly be easiest for someone to find. But yeah (as you mention) the downside is if other image formats were also added there it would start to make the file dialog dropdown get clogged up and after some point it gets difficult to find things in it.
For direct image saving I'd been thinking that there would be something like a Render command that would generate an image and the image would be displayed on its own new window. Then there would be a file menu on that window where you could save the image to PNG/TIFF/JPG/etc... That would probably be something for v4 since I'm hoping to wrap up v3 fairly soon here.
Yeah having image saving under some kind of Render function (probably with a Render tab on the pane for accessing it) would help to put 2D bitmap images into one kind of separate category.
It's kind of hard to introduce categories into the regular export without making things take extra steps, like it probably wouldn't be nice to have a separate dialog pop up before the file name one that made you pick between Solids, Polygonal, or 2D type exports before you got to put in the file name.
11 Oct 2013   [#123] In reply to [#120]
Hi OSTexo,
There is a curve extension function under Edit > Extend. If you want 2 curves to meet, you can select both of them, then run Edit > Extend, then at the prompt to select boundary objects you just right-click or push Done at that point to tell it you want to do a "mutual extend" where they extend to each other, rather than extending them to a third boundary line.
11 Oct 2013   [#124] In reply to [#121]
Wow there seems to be a lot of variation in program support for these various things. Kind of a lot more differences maybe between Mac and PC versions and even between different versions of the same program than I would have expected.
11 Oct 2013   [#125] In reply to [#121]
"""""""""""""""""""""""I've got Xara 8 & 9 (Photo & Graphics Designer versions) & everything imported just fine.
See attachments."""""""""""""""""""
Hi Colin,
Yeah PDF works great in Xara! I'm surprised to see other Xara users here.
I was referring to the AI test file import in Xara, it didnt import background file.
As said it works with PDF so no problem there.
Marc
11 Oct 2013   [#126] In reply to [#122]
""""""""""""""""""""""" I'd been thinking that there would be something like a Render command that would generate an image and the image would be displayed on its own new window"""""""""""""""""""""
That's a great plan!
Marc
11 Oct 2013   [#127] In reply to [#125]
Hi Marc,
So for Xara it will be use the PDF import - that brings in the image and also layer assignments.
Illustrator won't read in the layer assignments in PDF so if you want layers to come through you'd use .ai format for Illustrator instead.
And it seems that certain versions of Illustrator (seems to be around CS3 or CS4) have some problems with the images but the current versions seem to be behaving ok.
12 Oct 2013   [#128]
Don't forget the free Xara Xtrem5 ! ;)
http://www.xara.com/eu/specialoffers/designer/
12 Oct 2013   [#129] In reply to [#128]
quote:
The offer will only last until 20th May 2013, so don't hesitate!
12 Oct 2013   [#130]
Wow, this is an unexpected really cool surprise... The first thing I thought when I saw it was, is this feature finding its way to the silhou command??
12 Oct 2013   [#131] In reply to [#130]
Hi ed,
Which particular part do you mean?
Right now though I don't really have any plans for modifying the silhouette command, all this new stuff will be built directly into PDF, AI, and DXF format output for generating 2D drawings.
12 Oct 2013   [#132]
I mean something like the make 2d command on rhino, the main difference (that i see) between the make 2d and MoI's silhou is that MoI doesn't have hidden line removal.
12 Oct 2013   [#133] In reply to [#132]
Hi ed, - if you want to get the hidden line curves back into MoI you can just open or import the PDF, AI, or DXF file that was just written...
What is it that you would be trying to do by generating the hidden line curves only inside of MoI instead of as an export?
I guess it could be possible to add in a "Make2D" like command for generating hidden lines but it would help if I knew why you wanted to do that.
In Rhino you have to do it because there isn't any way to otherwise make a hidden line view for exporting, unless things have changed a lot. It's a pretty clumsy workflow though, you do Make2D and now you have a bunch of curves sitting inside the same model as your original objects, then if you want to do something with them you have to try to hide the original objects and keep the 2D objects separate from them somehow.
