Full Version: Hidden line removal progress
Show messages:  1-10  11-30  31-50  51-70  71-90  …  291-296
29 Sep 2013   [#11] In reply to [#10]
Hi Matt, this is a good time for me to get some feedback like this.
Is it always a silhouette edge that you'd like to see as a thicker one? That meaning more specifically an edge where the surface normal of that edge is at a 90 degree angle from the viewing direction.
I'm not fully understanding the insect walking rule, can you maybe give some more description of that?
I think I'm also going to try to attempt an option of making an outer boundary that's thickened, like shown in the attached file in this previous message here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4277.14
Would a thickened outside boundary like that be useful too?
29 Sep 2013   [#12] In reply to [#10]
Hi Matt, also another question - is it important to also have the hidden lines (meaning occluded lines that are not displayed at all in the PDFs here in this thread) to be available in the output to also be used for some kinds of illustrations?
I mean like the faint dashed lines that are displayed in MoI's viewport. For modeling purposes it's good to have some access to those to be able to select them, but do you use them in your illustration work as well for some things or not really?
29 Sep 2013   [#13]
Also I was thinking for the background bitmap image to maybe shrink that down by half in width and height to get a downsampled antialiased result with a bit of blending in the border areas and also cutting down file size by a ways.
Do you guys think that would be good or is it better to just keep a finer grained but non-antialiased bitmap in there?
29 Sep 2013   [#14]
hi michael
See attached pdf for more explanation of different line styles needed. At the end of the day if you can export everything except the red dotted lines (hidden lines) and then a simple line style to differentiate the others that would be great. I tried recently export a chain done using the brilliant chain script and the silhouette command. I then exported to illustrator but it was just too cumbersome to clean up. This work would go a long way to making this process a lot more painless.
hope my sketch clarifies things
Another thing on this subject, when exporting to eps, is it possible for any circles/ellipses to have just 4 points at the major and minor axes. This would clear up a lot of points and make editing/construction easier. See bottom sketch in pdf. I suspect that this bit maybe why Isodraw can charge such a high price as we are moving from 3D objects to postscript language which is moving out of your field . .
Matt
lineHelp.pdf
29 Sep 2013   [#15]
This is great news, the samples are looking great!
The rendering and vector curves overlapped is something I have never seen and will be a major timesaver for my work.
When profile lines have less segments (joined curves) it's easier to edit afterward.
I imagine it must be hard to set a mechanism that works great in all situations though.
I use hidden lines from time to time in illustrations or schematics.
As mentioned, a closed shape for the main silouhette would be great.
An option for different colored lines could be enough to edit the thickness of lines in 2d vector editors (for example oulines, details and hidden.)
It might be interesting to have a special export window, like when exporting polygons.
It could have a preview and some options for including the rendering or not, lighting options, hidden lines, resolution, etc.
Or maybe a 'options' button in the export pdf file dialog window could be handy.
Marc
29 Sep 2013   [#16] In reply to [#14]
Michael, thanks a lot for working on the much needed hidden line removal.
I attached a nice pdf about the two lineweight illustration principle from
http://purdy.gatech.edu/wp-content/uploads/2012/07/2_line_wt.pdf
I don't know if you can control line caps on export but this is also covered.
It doesn't hurt if the hidden lines also get exported as long as they can be easily turned on and off like on a seperate layer for example.
2_line_wt.pdf
29 Sep 2013   [#17]
"""""""""""""""""""Also I was thinking for the background bitmap image to maybe shrink that down by half in width and height to get a downsampled antialiased result with a bit of blending in the border areas and also cutting down file size by a ways.""""""""""""""""""
I'm not sure I understand what this mean, would it be easy to post examples?
Marc
29 Sep 2013   [#18] In reply to [#12]
"""""""""""I mean like the faint dashed lines that are displayed in MoI's viewport. For modeling purposes it's good to have some access to those to be able to select them, but do you use them in your illustration work as well for some things or not really?""""""""""
For me it would be nice to have access to these (as seperate object/sets as mentiond). It would allow me to easily reconstruct certain parts. Like the "six legged pod" example. If I needed more of parts of the legs that were hidden, I could use those to generate something at the proper perspective. There are some 2d techniques that can require "seperating" the parts of the charactor/object onto layers/assigments.
29 Sep 2013   [#19] In reply to [#12]
Hi Michael ..
I personally like the look of objects in MoI now. I often darken the visible edge lines. On my display the hidden lines are lighter and thinner and that's great though I would like it if they could be dashed.
I would also like an alternative where the surfaces did not have any color at all so that for some illustrations it would appear simply as a line drawing.
cheers,
eric
29 Sep 2013   [#20] In reply to [#14]
Hi Matt, thanks for the additional explanation.
So let me make sure I understand the insect walking rule properly. I think it's about local silhouette areas, with a silhouette spot being defined by 2 conditions (previously I accidentally only wrote about one of these conditions). The 2 conditions are:
- On a smooth surface, where the surface normal is at a 90 degree angle to the viewing direction.
- On a sharp juncture between 2 surfaces, where one surface normal points towards the viewing direction and the other points away from it.
And maybe for open surfaces (instead of solids) a third condition is a "naked" edge, meaning an edge that belongs to only one surface rather than being joined between 2 surfaces.
Would having all spots that fit that criteria sorted as "Outer edges" work properly? Or is there some way for an edge to need to be considered an "Outer edge" that does not fit under this definition?
You wrote:
> For me instead of an image a sihouette shape
> would be more advantageous. This could be done if
> you can get your outer boundary shape going :-)
You mean a closed silhouette vector path? Unfortunately I'm not very confident about getting a totally clean actually closed shape for the outer boundary, I'm just hoping to slice things up so that you would have some curves separated out on that full object outside boundary so you could have another kind of thickened shape there like the one shown in the file here: http://moi3d.com/forum/index.php?webtag=MOI&msg=4277.14
The complication with this is that a non-rational cubic bezier with just 4 points in it cannot make an exact circle or ellipse shape, they can only approximate it. Right now MoI does a general purpose refitting step to convert any kind of rational curve into cubic beziers and general fitting mechanisms like that will end up with more points than things built for certain kinds of shapes. It might be possible in the future to make some special cases for circles and ellipses but that's probably not going to happen during this pass of hidden line removal work.
29 Sep 2013   [#21] In reply to [#19]
Hi eric,
Are you talking now about MoI's viewport display? Or about PDF/AI export?
For the viewport display, the hidden lines are actually supposed to be dashed currently. Does your display look different than this? :
Those "hidden lines" there are not solid:
You can get this currently by adjusting some lighting settings so the lighting is so bright it essentially disables shading entirely.
Check out here for a description on how to set that:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3135.3
29 Sep 2013   [#22] In reply to [#15]
Hi Marc,
I was hoping it would be useful for your work!
Also the tricky part is maintaining accuracy, it's fairly natural for fitting mechanisms to use more points in order to make the fitted result reasonably accurate. I may be able to put in some parameters to control the accuracy level at some point but I'm not quite sure about having that done for this round of work.
Unfortunately I think that's going to be really difficult to achieve, I think the best that I'll be able to do is to have an option to just try and separate out portions of curves that are on the full object silhouette so that you will have something to work with, and if you just want to make an accented border it just having a set of curves in that area may hopefully be enough for that kind of use without it being fully closed.
Yeah I haven't gotten to this UI part of it yet. I'm fairly certain that PDF export dialog will get bigger with additional options right on that dialog.
I'm not sure about doing a preview, it would be nice to have but I've got to balance that against how much time it would take to implement it, and I'm not sure if the preview is going to be really particularly useful, like I'm not sure if you'd really be using it as a basis to modify parameters or not as does happen with meshing output.
29 Sep 2013   [#23] In reply to [#17]
Hi Marc,
Basically it means whether the background bitmap should be shrunk down by half and kind of blurred somewhat as a side effect of the averaging process during the shrinking.
The sort of good part is that the blurring would give the alpha transparency around the borders of shapes to have some partially translucent spots rather than only having either fully opaque or fully transparent spots with no in between things.
The bad part is that with less resolution the pixels are larger and more noticeable when zoomed in.
Maybe to start with I won't try to do any kind of processing on the background image and just leave it up to you to do any blurring or down sampling if you want that.
29 Sep 2013   [#24] In reply to [#18]
Hi Burr,
re: generating hidden lines also in addition to visible lines.
I think enough people have mentioned that they will occasionally use these that I'll try to have an option for making them, probably just unchecked by default.
29 Sep 2013   [#25] In reply to [#16]
Hi Martin,
Thanks for posting this, this also helps as well. Although in one area it seems to be different than what Matt posted previously, I'll ask some more about that in a separate message in a bit here.
It is possible for me to control line caps in the PDF file, but trying to do this implies both discovering and maintaining some information about how different categories of lines touch one another. There's a good possibility that trying to figure that out and maintain that information throughout the whole process could add quite a bit of complexity to the whole thing so it's not too likely that I'll attempt that part.
I'll see about having an option for this.
29 Sep 2013   [#26]
Hi Matt & Martin - I'm still a bit confused now about what should be considered an "exterior" or "outer" edge.
I think I see that what I was thinking previously about it being silhouettes doesn't seem to be quite right - they seem to be silhouettes but it looks like only some silhouettes are considered exterior and others aren't.
In order for these to be categorized by MoI I need to be able to make some kind of quantifiable way to categorize these things, I can't rely just on human judgement.
So one thing that has me confused right now is in Matt's insect walking PDF above, this is shown as the exterior edge:
In the one Martin posted, this one is shown as the accented edge:
So to me it seems as though those are 2 different choices, the first one is the longer one on the top surface, while the second one is the short one on the bottom side...
As far as silhouettes go, there are these 2 different silhouettes for that hole:
Right now I don't understand how I should distinguish between these to pick just one of them as the exterior edge.
29 Sep 2013   [#27] In reply to [#21]
Hi Michael
Just using the viewport display as an example ... I would like to be able to export to .pdf with this look.
Now when I export to pdf the hidden lines are solid and as strong as the outer edges.
Thanks for the lighting tip ... that works.
However, the hidden lines only show as dashed when I zoom in as far as my display allows but when I save the normal sized screen display to the clip board and then import it in PhotoShop the hidden lines are simply faint light lines ... so if I had a choice I would like the hidden lines to display as somewhat thicker than they are now and a little more broken.
cheers,
eric
30 Sep 2013   [#28]
hi micheal
Yup you've you've understood right. Although in later examples which someone posted, the one with a hole in a plate, strictly speaking the thick thin lifework work would be as my image.
As for naked edges, thats down to the illustrators own interpretation so if it could be in its own style for easy selecting it would be a bonus, otherwise for me it would be enough just to be a thin line.
no to worry with the overall shape. I notice even in isodraw that the overall all fill (they call it a contour) is a bit rough but as it is lying under a thick silhouette lie its usually covered.
Matt
30 Sep 2013   [#29] In reply to [#26]
I am a non-expert, but did a google search for lineweight sketching, and line weight hierarchy. Found 3 rules here:
http://www.sketchmyworld.com/line-weight-importance-in-product-sketching/
Basic Line Weight Usage
1.The thinnest line is used to describe the edges of a product that point towards a viewer and also for the inner lines.
2.Second thickness lines are used for outlines (edges that have air behind them). These are not only contour lines, but can also occur within an object.
3.The thickest lines are used for the baselines – lines that show the interface between a product and a ground plane.
(Seems like there are a whole lot of drafting and architectural standards for line weight and line type. A person could
spend a lot of time on this subject, I guess.)
30 Sep 2013   [#30]
hi micheal
FYI info I have enclosed 2 screenshots of what Isodraw CADprocess churns out from the 3D models. There are two line thicknesses. have colored the thin one blue zoo you can see easily.
It is by no means a perfect process and i usually have to tidy some parts up but it saves me hours.
Matt
Screen Shot 2013-09-30 at 8.29.56 AM.png  Screen Shot 2013-09-30 at 8.30.12 AM.png
