Full Version: Astonished free mechanical prog
Show messages:  1-3  4-23  24-43  44-63  64-75
14 Sep 2020   [#64]
Tested the new version 5.0 : all works fine ! :)
Import Export SKP etc...
Import STEP (from Moi for hard Fillets ;) Export SAT (with little easy tricky thing)
14 Sep 2020   [#65] In reply to [#63]
Most sub $2000 MCAD's surface modeling are too weak, pretty useless for product design.
14 Sep 2020   [#66] In reply to [#65]
It's for that this little free one is a little gem! :)
and it's making PDF 3D!;)
Here a PDF 3D From a Moi Volume
so you can use the PDF 3D for some dimensions in direct in your favorite 3D PDF Viewer!
15 Sep 2020   [#67] In reply to [#66]
Not sure if this shows designspark have removed some import features over recent years:
http://help.spaceclaim.com/dsm/2.0/en/Content/Importing_and_exporting.htm
It lists autocad dxf. Click on blue autocad link and it will show dxf r12-r14, 2000 etc. (Import and export?!)
Can you confirm Pilou?
More comprehensive settings by file type here, click blue links at bottom of page:
http://help.spaceclaim.com/dsm/2.0/en/Content/File_import_and_export_options.htm
》》》》 Maybe all this is out of date as the "2.0" might be from 2014 and we are now on v5??
15 Sep 2020   [#68] In reply to [#67]
I am only speaking about the Free version 5.0 without Exchange module $ !
We have only rsdoc, OBJ, SKP, Step, STL as import and PCB for electronic components
And for Export rsdoc, amf, dxf, Pdf, PDF 3D, GLB, OBJ, vdb, SKP, stl, xaml, jpg, PNG
and with my little tricks SAB & SAT ;)
and this following as Images Files import
15 Sep 2020   [#69] In reply to [#68]
Correct I think that full version is by ansys
"If your work demands exceed the capabilities including the add-on modules, you can consider the full version offered by the DS Mechanical developer- ANSYS SpaceClaim"
http://www.spaceclaim.com/en/ANSYS-SpaceClaim-trial-DSM-UI-campaign.aspx
15 Sep 2020   [#70] In reply to [#69]
Space Claim is another prog! No so the same price! :) 3 200 $ ;)
With the free DSM 5.0 you can donwload 43 000 objects like this one...or very more little :)
15 Sep 2020   [#71]
So in Moi but you better Union them before export else you must import in Moi 30 objects one by one :)
Not really a big deal but depending of what do you want ! :) (count 2 minutes if you import them one by one for this case)
here my object is not one by one so 2 seconds but i have only one object! But it's a solid as you can see! ;)
16 Sep 2020   [#72] In reply to [#71]
For a quick route to get part designs like boxes and cable glands maybe designspark is a good place to start.
What format are you exporting to to get these models into moi with?
16 Sep 2020   [#73] In reply to [#72]
Moi to DSM : Step format
DSM to Moi you must make this little trick! (I make all that following in 5 seconds)
For use the Step and can edit it in DSM 5.0
Load the .Step : draw anything ( a sphere) on your object Step imported: Right Click on the Top Arborescence : UnLock
Kill the Sphere ...your can make anything you want with your imported object!
Save as my_object.rsdoc
Rename it in my_object.zip put it in a folder on the Desktop say bob
Unzip : you have "C:\Users\Pilou\Desktop\bob\SpaceClaim\Geometry\part1bodies.sab"
this .sab must be convertered in .sat (converter given with DSM 5.0)
so with only one line !!! (put a space after the end " )
This only one line is to input in the Command Windows Box called by Pressing keys "Logo Windows" + R
"C:\Program Files\DesignSpark\DesignSpark Mechanical 5.0\SabSatConverter.exe"
-i "C:\Users\Pilou\Desktop\bob\SpaceClaim\Geometry\part1bodies.sab"
-o "C:\Users\Pilou\Desktop\my_object.sat"
Put you line command somewhere for an easy future use :)
Of course Pilou will be remplaced your name if existing!
Import or Open my_object.sat inside Moi :)
If you had not Union your object in DSM you will have part1bodies.sab, part2bodies.sab etc...
so remake the input...for each one! (the big object above was 30 objects for example)
16 Sep 2020   [#74] In reply to [#73]
Hi Pilou, could this maybe help you automate the process a bit??
https://github.com/arekm/rsdoc-to-sat
Stefano
16 Sep 2020   [#75] In reply to [#74]
Maybe but as it's an old routine maybe the SPaceClaim converter is not updated...depend if it's call the new or not...
And there maybe something to change for have the last version 5.0...
Try it :)
