6-25
26-45
46-65
66-75
If you have Moi just load the Step file and save it in SKP for use it inside DesignSparks ! ;)
If not you can use for example Free CAD for convert them in OBJ
http://www.freecadweb.org/wiki/index.php?title=Feature_list
then Load this OBJ inside Sketchup and save it as SKP ;)
http://sketchucation.com/forums/viewtopic.php?t=20584 (plugin obj import by TIG)
Yes, but I need NURBS, not mesh models in DesignSpark. As I said it's useless.
so look at formats of SpaceClaim but it's no more a free product :)
http://files.spaceclaim.com/SupportedFormats.pdf
I know SpaceClaim :) but it's too expensive.
A last find some times for test it! :)
Works very fine! DesignSpark has a new version 2 !
Very similar than SpaceClaim !
Thx to Max Smirnov!
VIDEO
Do you know another speedy method against this "duplicate trick" for pushpull only a face from a volume after a fillet ?
There are many different push/pulls happening in that example there, so I'm not exactly sure which particular one you're trying to do.
But in MoI v3, you can use the Extrude command on a sub-selected face in a solid and get it to behave like many of those steps, here's an example:
To do that, select the face and then run Construct > Extrude.
Yes in Moi, Pushpull the "face" created after the Fillet is automatic! :)
The problem for me is make the same inside DesignPark!
And this at first view is impossible directly as I understand for the moment! ;)
Maybe there is a parameter to enable somethere...for make this possible...
Hi Pilou, sorry I don't know how to get that same behavior from SpaceClaim, it seems that it wants to move the fillet as well by default?
Maybe try holding down Ctrl or Alt when you do the pull, does that do anything differently?
You may need to ask in the DesignSpark or SpaceClaim forums to get a proper answer on that.
I have found! :)
But not sure that will work more speedy than my first "duplicate" above! :)
You must select strictly 3 edges!!! (1, 2, 4 don't work)
Hey Frenchy,
Just include the edge that belongs to the fillet in the selection. So, Select face, then Ctrl click the edge that you want to go along with the extrude.
You rocks! (click first the edge then Select face with Crtl works also! ;)
A little trick for the "Only read file STEP imported"!
Import the STEP file created in Moi ;)
Add a solid to the drawing (cube, cylinder, sphere, whatever).
Right click on the top-most name of the component tree (the name of the whole thing).
Unlock. Everything in the tree is now unlocked.
Just to change the not cuty Black color! :)
Frenchy's going Black Hat!!!!!!! Heaven help us........ :)
@Burr:)
Amazing thing: you have the export in PDF 3D!!!
So Moi format Step in PDF 3D ! ;) (or of course anything that you have in DesignSpark)
Inside DesignSpark : Menu File/ Save as PDF faceted Geometry
The file PDF3D:
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/kub2.zip
cool
Direct editing... my software (Geomagic Design) does this too. Many software's do.
Design Spark isn't bad actually but just nowhere near as good as paid-for software.
In V2 Blend Function is missing so Install first V1
http://zwcad.com.tw/nick/FREE3D/
then V2
Edit : Seems this site is not more accssible!
And something else!
So you can make cotation of Moi object!
In 2D or 3D! Then export in DXF or PNG!
by Chri
Here direct export in the free DraftSight
6-25
26-45
46-65
66-75
