19-38
39-40
> Unfortunately, the values of aRadius and bRadius are now set to zero, in MoI4, but are ok in MoI3 :-)
That's a bug in v4 with handling whitespace characters in the default value. If you remove the line break for the default="" attributes that should avoid the bug right now.
So where you currently have:
<tr>
<td>aRadius</td>
<td><input id="aRadius" class="numericinput" default="10
" style="persist:true;"></td>
</tr>
Remove the line break like so:
<tr>
<td>aRadius</td>
<td><input id="aRadius" class="numericinput" default="10" style="persist:true;"></td>
</tr>
I'll fix it up for the next v4 beta, thank you for reporting it.
Thank you Michael.
The script is working again in MoI4, and continues to work in MoI3.
The white space was introduced unintentionally, while removing decimals, a day or so ago :-)
...5 or 6 or so decimals were causing occasional shift of the htm screen to the left, a fraction of an inch, in MoI3, but not in MoI4...
The _CycloidTrochoid script is now updated, a few posts back.
19-38
39-40
