17-36
37-56
57-76
77-80
Took another look at LineWeb script, and Pipe2 script, which both use several factory(s).
(The plural of factory denoted with (s), because "factories" is used as an array in some scripts.)
LineWeb deals with points and objects made from points, and factories which are arrays.
Pipe2 has PushButton Update which I'll try to add to the chain script, including removing objects appropriately.
Hi Michael
I am having trouble removing three things from the geometryDatabase, in order to prevent the creation of multiple copies of chains.
The first one is chainobj, which is an input to the FLOW factory.
The second one is baselineobj, whose first item is baseline, an input to the FLOW factory. (I haven't tried removing baseline from the geometryDatabase.)
The third one is flowedchainobj, which is the output of the chain factory.
My current theory is that asynchronous FLOW factory is interfering with the removal from the geometry Database.
For example the command: moi.geometryDatabase.removeObjects( chainobj ); placed before FLOW, does remove the arrayed chain from the screen.
However, placing it after FLOW does not appear to have any removal effect, and multiple chains can be created on top of each other by repeated updates.
FLOW commit does not seem to help.
Any Ideas?
Thankyou
Hi Brian, you probably want to avoid calling .commit() on the various in-between factories. For a regular command, factory.commit() signals to the factory that the command has completely finished and the factory is completely done, once you call .commit() any further call to .cancel() won't do anything. Basically .commit() and .cancel() are mutually exclusive to one another.
Also any factory that has been created during a command goes on the "active factory list", and if the command ends without .commit() ever getting called, it will get automatically canceled during the command end cleanup processing. Either a .commit() or a .cancel() will pull that factory off of the active factory list, since it's considered to be completed after either of those calls.
So anyway probably if you just don't call .commit() for the things you don't want to persist in the geometry database that may cover it.
Otherwise if you do call .commit() you will have to manually remove things you don't want from the geometry database.
If you want to have factories remove the stuff they were showing in response to .update(), you can either call .cancel() on them if you're going to still be running the command (like for parameters changing), or if the command is ending you can actually just not do anything and then .cancel() gets called automatically for any active factory at the command end.
Does that make sense? Let me know if you are still having problems.
Thank you Michael
EDIT: Your descriptions ARE helping.
My script is flawed, and also my understanding . The pipe2 script is becoming more understandable, so I am going to adopt
its methods even more. Lineweb is helpful too.
I think I will make some more changes in my script, and even use a javascript array or two, and more subroutines.
I'm starting to think that .calculate() is more user friendly than .getCreatedObjects() ?
EDIT: Making a little progress. I had left out a few important things, and put in a few poor things. :-)
Thought of the day: Chain links are like "Bones" in an animation program ?
Another thought: script to copy an object, based upon two points, to another location with two points... OK in 2D ?
Maybe ArrayGem does this.
Check out Transform > Orient > Line to line - it does that kind of transformation, which is just basically a move from one line's start point to the other line's start point, and then a rotation by the angle between them (and optionally a scale by the difference in length between them too).
It works like this:
ArrayGem is a slightly different, it builds a "base frame" around the starting circle, and then figures out a target frame that is oriented around the surface normal and then does a frame-to-frame transformation which is also really just a move + rotation as well though.
Thanks Michael
I'll try it out.
(Still working on the chain script, slowly :-) )
Keep up the good work on the chain script, its looking good!!
matt
After a lot of failure, trying to delete flowed chain outside of the subroutine, FINALLY
got it to work, using example of spur gear script, by assigning a chainList = Update(...). So simple and hard. :-)
Fixed simple link length, non-Updateable missing code.
Now to work on twist.
Bravo, bravo, bravo! Hats off for your tenacity, Brian!
Implemented the option to Twist the individual chain links.
Note that some trial and error, guided by the many helpful explanations of Michael, was necessary in order to discover
that Input "0" of the Twist factory would work with sweeplist, from var sweeplist = sweepfactory.calculate();,
but would not work with link1, from var link1 = sweeplist.item(0);.
Also, it was not necessary, in this case anyway, to add sweeplist to the moi.geometryDatabase with moi.geometryDatabase.addObjects( sweeplist );.
As an alternative test, the rail based upon a rounded rectangle worked well with the Twist factory, and would be another way to Twist the first chain link.
Twisting the rail is not done in the current version of the script.
There are several possibilities for the Twist axis. The one used seemed to look well.
The script worked well on one test 3d curve.
ArrayGem in 3d would need a surface for normal.
Chopping the curve up into points which are equally spaced in space, not necessarily equally spaced along the curve, and then
doing a copy to two points is another possibility, but probably needs normal also, in 3D.
This completes the chain script, for now.
I should probably delete old versions...?
ChainMakerAug25_2013PM.7z
Seems to work really well Brian!
WOW! Great job!
SWEET Bem,
""""""""""I should probably delete old versions...?""""""""""""
I would leave them, in case others are following. But, at some point, you'll need space. Might have to start using skydrive or something, or the future generatinons will loose your input! :o
Thank you Burr. Maybe next winter for "skydrive" or some such.
These particular files are super tiny though, like 3KB apiece, so they won't fill anything up for a long time...
Usually it's 3DM files with a lot of stuff in them that tends to fill up attachment space quickly. If you have a big 3DM file to share, that's what can be good to put on a file sharing service like skydrive or dropbox, etc...
Thank you Brian ! :)
If anyone wants to "hang" a chain, there is a catenary script on the forum, which works fairly well with a good radius guess.
I want to improve it by adding bisection, and re-examine the code.
If i want "arraydir" command to start in "Extent, Count" mode, what Key script should i use ?
Hi Bravlin,
It's not possible currently because of the space character in there. I should be able to fix this for the next v4 beta though by making quote " " characters affect the parameter parsing for command parameters.
The current method breaks things into separate parameters just by spaces so it breaks that "Extent, Count" into 2 parameters instead of just keeping it as one.
I'll see if I can make both "mode=Extent, Count" or mode="Extent, Count" work.
17-36
37-56
57-76
77-80
