Full Version: The script for chain
Show messages:  1-9  10-29  30-49  50-69  70-80
11 Aug 2013   [#30] In reply to [#29]
Thank you Michael.
I was just throwing the questions and thoughts out there, in case there was any interest, and to make a start
on the scripting procedure.
Rigid Flow looks like it will work well, but the chain link length must first be shrunk or stretched a little bit, so the chain length is correct,
or the links will have a gap, or overlap.
The result may not be perfect, according to physics, but should be fairly close.
Wrote some draft code this morning, simple math and such, but it doesn't work yet. :-)
-Brian
12 Aug 2013   [#31] In reply to [#29]
- Hi Michael
This chain script is turning out to be harder than I thought, when the ends are constrained.
In real life, (under light loads,) chains do not stretch or bend much, or at all, so the curve would change.
One chain link amounts to two points, a constant distance apart, I'm calling the "innerLength."
So the target curve should be represented as a polyline, with constant length line segments.
(It would be like a low resolution curve, made up of constant line segments.)
Array Dir command places points a constant distance along a curve, but sequential pairs are nearly always different distances in space.
ArrayGem script places the points along a curve, with sequential pairs a constant distance apart, in 2D anyway. (need to check 3D).
But ArrayGem usually does not place a point at the end of the curve, it has "left over" curve distance beyond the last point.
Is it possible to have a version of ArrayGem which has start and end points on the curve, and divides up the distance between points to
the constant spacing?
12 Aug 2013   [#32] In reply to [#31]
> curve, and divides up the distance between points to the constant spacing?
It could be possible in the future at some point, but it would require a pretty significant change to the mechanism that ArrayGem uses to work, currently it uses an iterative solver that is set up to find a spot along a curve at a certain distance away from the previous object.
To do it the way you are describing is not just a small tweak to the mechanism, it means making a new iterative solver that behaves differently from the current one. Those are not really simple things to make work well, it involves quite a bit of testing and tweaking.
12 Aug 2013   [#33] In reply to [#32]
Thank you Michael :-)
I've still got ideas to try. I may try dividing up the leftover curve of ArrayGem...sounds sort of iterative.
Sounds like a bunch of spheres touching.
Then again, a rigid flow may be good enough for nice drawings. The artist can adjust his spacing...
15 Aug 2013   [#34]
Spent a lot of time trying out ArrayGem.
I've concluded that for a 3D curve, ArrayGem requires a matching surface (always or usually).
Flow rigid works well also.
-Brian
15 Aug 2013   [#35] In reply to [#34]
Hi Brian, yeah ArrayGem needs both a curve and a surface that the curve is on - the surface normal is used to control rotation of the items so that the initial "up" direction of the base circle maps to the surface normal direction.
18 Aug 2013   [#36]
Did some more work on the chain script.
Copied link1 to link2 and rotated 90 degrees.
Created Flow baseline. These were fairly easy as they just follow the same pattern as the previous factories.
Currently bogged down with trying to get "Array Dir" factory to work in script.
Not sure if the Array output is a list of multiple chain links or ...?
Still fuzzy on objects versus object lists, and object lists with one object, and how to concatenate
link1 and link2 with .addobject...etc...
Then will have to get the Flow factory to work in script...
- Brian :-)
18 Aug 2013   [#37] In reply to [#36]
Tried some array permutations this morning, changing the objectlist formation. Array dir script still not working.
Maybe my Mode string is wrong, or the ObjectList is wrong.
Not sure how foreign languages figure in to the Mode string, maybe have to look at CSS or something...?
Are Array Dir, or Flow factories asynchronous?
Is there a list of asynchronous factories?
18 Aug 2013   [#38] In reply to [#36]
Array dir's inputs are like this:
index 0 = object list - objects to be arrayed.
index 1 = integer - number of items to make in the array (the original object is included in this count, so for example num items = 3 will actually make 2 copies).
index 2 = point - base point
index 3 = point - offset point
index 4 = point - extent point
index 5 = string - can be one of: "Offset, Count" or "Extent, Count" or "Offset, Extent"
How the points are interpreted depends on the mode, the most simple mode is "Offset, Count" mode that will be where only the base point and offset point are set and that defines a distance that is used for each generated copy.
Which method are you using for generatring the output, is it factory.calculate() ? That method always generates an object list for its output. For array dir it will be all the copied objects that were generated.
> concatenate link1 and link2 with .addobject...etc...
Yeah the "object list of a single object" can be kind of awkward, that comes into play though when you use some general purpose interface that is set up to be flexible so that it handles both commands that generate one object and also commands that generate multiple objects with a common way of operating. So for example the .calculate() method is like that it always returns an object list with the objects that were generated in it, that way it behaves the same way for all factories instead of returning different things depending on whether the factory made only one object versus a bunch of them.
For concatenating 2 lists together, you need to do something like this
var list1, list2;
// Combine list2 into list1
for ( var i = 0; i < list2.length; ++i )
var obj = list2.item(i);
list1.addObject( obj );
If you need to do this a lot, make a helper function that will do that task for you so you can call your function to do it when you need it.
And one thing to note is that the geometry database is not exactly the same thing as an object list, although the geometry database contains within it a list of objects, it has its own interface for dealing with it and has some additional methods like addObjects() that takes an object list. Currently an object list itself does not have a method that adds another object list to it, it only has an addObject() function.
18 Aug 2013   [#39] In reply to [#37]
Localization does not affect the mode string that is passed into code, it only changes the displayed UI part of stuff.
Things like those modes are usually set by a <select> or <moi:select> element, and the options within the select have 2 parts, a "value" property which is always in english and that's what is passed into the acutal code, and then an inner text or a textid (text id for a look up into the current language string table) that controls only what is displayed in the UI when that option is active.
So for example if you want to know what values the array dir command can take, open up ArrayDir.htm and look at the control for <moi:Select id="Mode"> , the value="" properties on the child options there have the different string values that the code will actually recognize.
Array dir is not asynchronous. Usually it's the ones that need to do some more in depth calculations that are asynchronous. Here's a quick list of async ones:
ArrayGem, Blend, Booleans, Intersect, Project, Silhouette, Flow, Twist, Extrude, Fillet, Chamfer, Join, Loft, Offset, Shell, Inset, Network , Nsided, Revolve, RailRevolve, Sweep, Text.
18 Aug 2013   [#40] In reply to [#38]
Thank you Michael.
My problem was with improper list creation of link1 and link2.
Now have array working with offset, extent.
On to Flow factory...
I'll post an update later.
18 Aug 2013   [#41] In reply to [#40]
Latest ChainMaker script.
Array Dir works to array the links on a base line.
Still cannot get Flow to work. One of the inputs must be wrong. It gets to a point were I run out of things to try.
18 Aug 2013   [#42] In reply to [#41]
Hey Bem,
Thats a great result already. Unwrapping the flow curve and leaving it allows to just run a rigid flow with the 2 curves quickly and get a result.
I suppose if you automate the flow it will be complete, but it's already a great command...
18 Aug 2013   [#43] In reply to [#42]
I wonder if you can just get to that point there, Have the end of your command select all solids, then launch the regular flow command? Pick the curves and done.
18 Aug 2013   [#44] In reply to [#43]
So for instance, I just made a copy of the flow command and named it ChainFlow, then I copied the code for ChainMaker js and htm to the top part of the new ChainFlow.
It "looks" like it could work, but both commands are running at the same time.
Is there a "pause here until finished" that could be added? The flow is waiting while chainmaker is running. Once chanmaker is done, it accepts the input curve, but wont pick the target. So they need to be seperated...
Michael,
Can a js call "DoChainMaker();" wait, then call "DoFlow();"? (Or "Function DoChain, FunctionDoFlow) with includes or something like that?
18 Aug 2013   [#45] In reply to [#43]
Thank you Burr :-)
18 Aug 2013   [#46] In reply to [#44]
Hi Burr,
> Michael,
Not really just by including just the existing flow command, because usually the regular commands are pretty intertwined with their UI as well.
18 Aug 2013   [#47] In reply to [#41]
Hi Brian, so I looked into why Flow is not working, and one thing is for flow input index 1, the base curve that should be a curve object and not an object list, so these lines:
	factory.setInput( 0, chainobj );
//	var baseline = baselineobj.item(0);
	factory.setInput( 1, baselineobj );
	factory.setInput( 2, targetCurve );
should have these 2 lines changed like this:
	var baseline = baselineobj.item(0);   // <<< enable this line that you tried before.
	factory.setInput( 1, baseline );       // <<< put in the curve, not the object list here.
But then there's an additional problem which is that the results from arraydir are not returned back to you - that's because of a mechanism in the array commands where during calls to .update(), they don't actually create full object copies and instead make a special lightweight "proxy" object (sort of like an instance) that can be constructed more quickly than an actual full object copy and so that keeps the display more interactive while doing some large number of arrayed items and placing points around. But it's messing up your script in this case because at the time the script calls getCreatedObjects() the system doesn't think any full objects have been created yet because of this special proxy object creation being done instead.
Proxy making is turned off when you do a .commit() but then also at that point the factory considers itself to be completely finished and clears its created object list at that time so you can't call .getCreatedObjects() at that time. Proxy generation is also turned off though if you call .calculate() so for now the solution will be to call .calculate() on the arraydir factory rather than update/getCreatedObjects/commit and also you'll need to add the results of calculate into the geometry database so they will work with the async flow factory.
So that means changing the array section from this:
	var arrayfactory = moi.command.createFactory( 'arraydir' );
	arrayfactory.setInput( 0, linklist1 );
//	arrayfactory.setInput( 1, 5 );
	arrayfactory.setInput( 2, baseStartPt );
	arrayfactory.setInput( 3, offsetPt2 );
	arrayfactory.setInput( 4, baseExtentEndPt );
	arrayfactory.setInput( 5, "Offset, Extent" );
	arrayfactory.update();
	var chainobj = arrayfactory.getCreatedObjects();
//	var chain = chainobj.item(0);  This line does not help.
	arrayfactory.commit();
	factories.push( arrayfactory );
To this instead:
	var chainobj = arrayfactory.calculate();   // <<<<<
	moi.geometryDatabase.addObjects( chainobj ); // <<<<<
After those 2 changes then the flow part should work.
18 Aug 2013   [#48] In reply to [#47]
Thank you again Michael.
I started a text file of a bunch of your script explanations. It is good for review and recollection.
There is no way I would ever have figured it out!
Installed the changes, and Flow does work! It took about 3.5 seconds.
Some tentative observations:
The first two links are missing...I think.
I think end selection of the target curve selection is not working either.
I think there is some cleanup to do on the script also.
Undo leaves link2 persisting...
More work to do tomorrow.
-Brian
18 Aug 2013   [#49] In reply to [#48]
Hi Brian, yeah really the whole current system is tuned more for a combination of some script more for "control flow" plus some C++ backend that does the actual geometry creation. It's not really specifically tuned for someone who's doing all script for everything as you've been doing.
I had been originally hoping that just one "factory" mechanism would work for everything but I think it's getting fairly clear that it would be better for larger scripts to have their own methods to call like createLine( start, end ) and stuff like that rather than running everything through the factory mechanism. The factory mechanism has some complexity to it since it's tuned for generating each thing in an interactive way like how the line command runs rather than just creating a specific line for example.
