Full Version: Dark Moi interface by zenox3d
Show messages:  1-13  14-25
12 Jul 2013   [#14] In reply to [#13]
Please don't press "RESTORE TO DEFAULTS" in options,cause it will change everything even your shortcut scripts.That's happends to me so I had to input my scripts from the start.
Regards from Nikola
12 Jul 2013   [#15]
Looks great guys - thanks!
12 Jul 2013   [#16] In reply to [#14]
<< Please don't press "RESTORE TO DEFAULTS" in options,cause it will change everything even your shortcut scripts.
If so maybe a second alert message for confirm will be necessay ?
or put the button Reset on the other side, because some time it's very easy to make an error of clic!
12 Jul 2013   [#17] In reply to [#13]
> Say I am inside the menu Grid
> Button "Restaure defaults" restaures the current menu Grid or all the menus? View Grid Snap etc
> and about ShortCuts ? all are erased except default in case of a presume general reset?
> It's for that i have never pressed this button! :)
When you push the button a secondary dialog pops up that asks whether you want to restore defaults for the current section only or for everything:
If you have the grid section of the Options dialog open and then push "Current section only" on that dialog, only the grid settings should be reset.
It's probably not a bad idea to make a backup of your moi.ini file first before doing that anyway though, just in case. To make a backup, go to %AppData%\moi and make a copy of the moi.ini file in there.
14 Jul 2013   [#18] In reply to [#17]
Ok! Very good to know!
18 Jul 2013   [#19]
Great work zenox3d but is it for v3 or V2, or both of them because i tried with V2 and it doesn't work.
Thanks for your reply :)
18 Jul 2013   [#20] In reply to [#19]
It is for V3 sorry. I saw on the forum that we can use V3 beta for pro work so I thought most of the people use V3 with new tools and upgrades.Also i didn't know that V2 was programmed different then V3 beta.I will make update for the others too about this issue.
Regards from Zenox3d
18 Jul 2013   [#21]
@ Michael
Does it possible to have a color Selector inside the Dialog View Options for BarBody-SidePaneBody?
(it's easy to modify inside the Moi/UI/moi.Css file but...:)
18 Jul 2013   [#22]
Thank you
18 Jul 2013   [#23] In reply to [#21]
It's not really easy to do this because if you change the UI background it would be easy for text to become unreadable. It's not really easy to change the UI by only changing one single color like that, there are many different elements and colors involved in making a UI theme.
18 Jul 2013   [#24] In reply to [#23]
<< It's not really easy to do this because if you change the UI background it would be easy for text to become unreadable. It's not really easy to change the UI by only changing one single color like that, there are many different elements and colors involved in making a UI theme.
Ok no problem just edit by hand! ;)
I have changed it for a low level of grey, seems that works fine with any buttons ;)
18 Jul 2013   [#25] In reply to [#24]
I like it...simple nuance of grey but sophisticated...French touch,what else...
