Full Version: Autodesk Fusion 360
Show messages:  1-12  13-32  33-52  53-67
17 Sep 2020   [#53] In reply to [#52]
Indeed that article is so direct doesnt mention money once.
The AIBS(tm)- artificial intelligence BS translator computed:
For seven years we led you to believe X Y Z. Now let's get back to ABC.
Weve done enough acquisitions and now want to acquire full control over that
other 'cash cow'. Its you, but please dont worry.
28 Sep 2020   [#54]
Well, it looks like they reversed the STEP export restriction: https://www.autodesk.com/products/fusion-360/blog/changes-to-fusion-360-for-personal-use/ so it is still usable in the short term.
But i agree with everyone, there is no free lunch, especially with Autodesk, and I wouldnt continue depending on it , if it had been part of my workflow.
Dinos
28 Sep 2020   [#55] In reply to [#54]
Not so bad for complex Fillets inside Moi ! ;)
28 Sep 2020   [#56] In reply to [#55]
Does anyone know if the "pcb" part of Fusion is basically a full version of EAGLE ?
28 Sep 2020   [#57]
Autodesk was giving Fusion for free to grow a users base and hurt concurrence.
It's harvest time now :) ...
What I find amazing is the reaction from some users, like they cant give more than 10 or 20$/month or so for a product like that ... no problem to spend thousands in computers and other machinery, but software has no value ?
Anyway I would think twice before using this product, even if easy filleting is tempting, I prefer to support local farmers :O)
28 Sep 2020   [#58] In reply to [#57]
Hi Paq,
3 years ago almost purchased a 3d printer and I just about held back with trying Fusion
even though the feature set looked really good.
I'd pay for software no issues but when the route map is not clear or there is guessing
likely I'd never invest...
Investing is time from the user, not just their money to support the developer/s.
Its looking more promising that Autocad are flexible enough to eat humble pie and
do some u-turns maybe.
Do you think they will remove .step in 2021 or is this set in stone now??
I dont sell crystal balls either.
28 Sep 2020   [#59] In reply to [#58]
If the income doesn't grow as expected, and too many people are still using the free version, they will continue to cut the features to find the good balance.
28 Sep 2020   [#60] In reply to [#58]
Or, Autodesk realized they havent crushed enough competition and people still had options to move away to!!!
(I wouldnt invest ANY business into "subscription" services...)
But hey, all the "holy cow" filleters are ACIS based filleters. Autodesk. Spaceclaim, etc...
Even "PunchCAD with ViaCAD..."
The big dev on Autodesk's branch off and spaceclaim etc, is the error and stop point handling.
So I can buy ViaCad and get awesome filleting for my MoI advanced fillets. I just have to work past cryptic dialogue popups and some back and forth with the sizes that just dont work, where the expensive stuff is more graceful in those areas...
So, ACIS based filleting for $99? You bet!!!
28 Sep 2020   [#61]
28 Sep 2020   [#62] In reply to [#61]
http://solvespace.com/index.pl
anygood?
Export
2d vector drawing as DXF, EPS, PDF, SVG, HPGL, STEP
toolpath as G code
as either piecewise linear segments or exact curves
wireframe model, hidden-line removed model, vector shaded surfaces
isometric view, orthogonal view, user-specified other view
section of solid model
with cutter radius compensation
with adjustable canvas size
3d wireframe as DXF, STEP
triangle mesh as STL, Wavefront OBJ
NURBS surfaces as STEP
shaded view as bitmap
28 Sep 2020   [#63] In reply to [#62]
I have made the French version of the Solvespace's site ;)
https://solvespacefr.weebly.com
Not many used because it's not that can we name a really UI friendly prog! ;)
It's perfect for solve some parametric problems of small objects...but a little hard learning curve!
Draw under constraint
You modelize small objects but make big ones will be very painful!
and useful for solve this sort of thing
28 Sep 2020   [#64] In reply to [#63]
https://youtu.be/qJEWOTZnFeg
Ton from Blender talks about Autodesk @ 46 53
Between concentrating on his strong Austrian accent its rather amusing.
________
How Blender got started 2:47
An early design decision that paid off 7:40
When Blender had $5.5M in cash 11:36
How Blender almost didn't happen 14:36
Why making Blender open source was the best decision 19:03
Ton isn't interested in money 23:42
What separates Blender from other open source projects 27:11
Why Blender's game engine is lagging behind 35:54
The fallout from my Blender UI proposal 40:50
》》》》》》》》》》 》》》》》 Ton's thoughts on Autodesk 46:53
Disney buying Pixar 1:08:10
What's holding Blender back 1:11:06
The UI debate 1:21:38
28 Sep 2020   [#65]
Else you have also this free one but not sure that is the more speedy for make something complex ;)
28 Sep 2020   [#66] In reply to [#62]
Seems Free Cad more appetizing ;)
28 Sep 2020   [#67] In reply to [#66]
For those who can justify it...quick hurry....
40% discount on 1year plus fusion360 subscriptions at moment.
