 4-23
 24-43
 44
Thanks Dinos !
Does not work, just enpty small window appears, wha tit can be?
HI Andrei, did you possibly put the file in your "commands" folder instead of the "ui" folder like this particular mod is expecting?
yep I put it in command folder, thanks!
Missing this one!
Seems very cool for my old memory!
Bravo! Works fine!
What file must have to edit for have French "Fermer" against the English "Close" button?
May be you have to search for this woard "close" in .htm file?
yes...but it's no so simple for me to find the good file! :)
I am not so strong in this things))) This plugin consist from one file ScriptPalette.htm , if this close word is in that file search in it :) But may be this word is in another file do not know, but try :)
Of course I can try some files of different arborescences but I prefere than an expert tell  me the good file directly, it's more prudent! :)
French Version! (before the French version of the button! :)
http://moiscript.weebly.com/palette-de-scripts.html
Ps Does it possible to make several palettes ?
Finally got the script to work, after following the directions :-)
Note, there cannot be a space before the !
Hi Frenchy.
Thanks for the french version! :-)
There is no easy way to make than one palette. You could make a copy of the script with a different name and change the ! in the code to something else for the second palette, but it would make it an even bigger hack than it already is.
The close button is just the standard moi:DialogClose tag. I'm not sure if this localized along with the rest of Moi3D if you are using a different language.
I remember looking for a way to close the Dialog window after a command is selected, but i couldn't find one. That would eliminate the close button altogether and improve the operation of the script.
Frenchy,
    It is working from the English strings "; Common dialog buttons Dialog close button=Close".
I don't know why it is not translating with the French strings. It could be the way the filesystem is called in the script? I think Michael will have to look at this.
Just make sure you have your Language set to French (Options > General > Language), then the dialog should show this (screenshot from my system with MoI language set to French):
This was with the current v3 version, are you maybe using an older version Pilou?
Hi Burr,
It's working fine for me over here - when I set Options > General > Language to French, I get a French language close button, as shown above.
You can even have the dialog open when you change the language and it updates dynamically as the current language is switched...
Do you see something different than that over there?
I was testing using the current v3 beta - Pilou are you using an old version maybe?
Hi dinos,
Yup, it is localized and the localization seems to be working fine for me over here...
Buttons or menu items on a flyout will automatically dismiss the flyout when pushed, but that built in default auto closing won't happen if they are on a dialog instead of a flyout menu.
You can add an onclick="" handler to make the dialog close though, you'd want to do the same thing as the button inside of the DialogClose.htm template, which is:  onclick="moiWindow.endDialog(0);"
So modifying line #26 of ScriptPalette.htm to be this should do it:
				html += '<moi:MenuItem onclick="moiWindow.endDialog(0);" command="' + cmd + '">' + title + '</moi:MenuItem>';
For some people it might be good to have a separate close button if they are using it repeatedly though...
No. I just did a test by changing the English strings text and didn't switch my system to French.
I just assumed Frenchy new this and it wasn't working for him, and wanted to point him at the area that controlled that dialogue text.
Hi Michael.
Thanks for your help. I've updated the first post to include 2 versions of the script: one with a close button and one without.
Personally i prefer the version without the close button as it feels more natural: Shortcut for the popup to appear, command or escape to dismiss.
But i'm sure there are cases where it might be more useful to have a close button.
Dinos
Perfect : I had not enabled the French Language! :)
So when I enable it magically "Fermer" appears as aspected!
Sorry for the little disturb!
Of course I had also the red x button! ;)
> Perfect : I had not enable the French Language! :)
Mystery solved! :)
 4-23
 24-43
 44
