18-37
38-44
Hi Burr,
> I don't know why it is not translating with the French strings. It could be the way the filesystem
> is called in the script? I think Michael will have to look at this.
It's working fine for me over here - when I set Options > General > Language to French, I get a French language close button, as shown above.
You can even have the dialog open when you change the language and it updates dynamically as the current language is switched...
Do you see something different than that over there?
I was testing using the current v3 beta - Pilou are you using an old version maybe?
Hi dinos,
> The close button is just the standard moi:DialogClose tag. I'm not sure if this localized
> along with the rest of Moi3D if you are using a different language.
Yup, it is localized and the localization seems to be working fine for me over here...
> I remember looking for a way to close the Dialog window after a command is selected, but
> i couldn't find one. That would eliminate the close button altogether and improve the
> operation of the script.
Buttons or menu items on a flyout will automatically dismiss the flyout when pushed, but that built in default auto closing won't happen if they are on a dialog instead of a flyout menu.
You can add an onclick="" handler to make the dialog close though, you'd want to do the same thing as the button inside of the DialogClose.htm template, which is: onclick="moiWindow.endDialog(0);"
So modifying line #26 of ScriptPalette.htm to be this should do it:
html += '<moi:MenuItem onclick="moiWindow.endDialog(0);" command="' + cmd + '">' + title + '</moi:MenuItem>';
For some people it might be good to have a separate close button if they are using it repeatedly though...
No. I just did a test by changing the English strings text and didn't switch my system to French.
I just assumed Frenchy new this and it wasn't working for him, and wanted to point him at the area that controlled that dialogue text.
Hi Michael.
Thanks for your help. I've updated the first post to include 2 versions of the script: one with a close button and one without.
Personally i prefer the version without the close button as it feels more natural: Shortcut for the popup to appear, command or escape to dismiss.
But i'm sure there are cases where it might be more useful to have a close button.
Dinos
Perfect : I had not enabled the French Language! :)
So when I enable it magically "Fermer" appears as aspected!
Sorry for the little disturb!
Of course I had also the red x button! ;)
> Perfect : I had not enable the French Language! :)
Mystery solved! :)
Why I can not to have this script correctly shown in window?
script: /*! Show all except curves, points and Hidden style*/ var obj = moi.geometryDatabase.getObjects().getBReps(), st = moi.geometryDatabase.findstyle("Hidden",0), sti; if (st) {sti = st.index;} else { sti = "nf";} for ( var o = 0; o < obj.length; ++o ) { if ( obj.item(o).hidden && obj.item(o).styleIndex !== sti) { obj.item(o).hidden = false; obj.item(o).selected = false; }};
In script window it looks like this:
< obj.length; ++o ) { if ( obj.item(o).hidden && obj.item(o).styleIndex !== sti) { obj.item(o).hidden = false; obj.item(o).selected = false; }};"> Show all except curves, points and Hidden style
Looks like it becouse <.
Is it any way to make some categories in this script window, to store scripts more logically?
Hi Andrei,
The problem is caused by the double quotes around "Hidden" and "nf" in the script.
If you replace the double quotes with single quotes it should work fine:
script: /*! Show all except curves, points and Hidden style*/ var obj = moi.geometryDatabase.getObjects().getBReps(), st = moi.geometryDatabase.findstyle('Hidden',0), sti; if (st) {sti = st.index;} else { sti = 'nf';} for ( var o = 0; o < obj.length; ++o ) { if ( obj.item(o).hidden && obj.item(o).styleIndex !== sti) { obj.item(o).hidden = false; obj.item(o).selected = false; }};
This is a limitation of the way the script palette works.
Dinos
dinos, thank you.
Works fine for the "one line" but for the "commands" I see well the name of the Line of the Command but
A little problem!
Of course the command works when I make : Press TAB ...and type _vClone !
Idem if I take a direct native command like Blend!
Hi Frenhcy,
you have to leave a space between the command and the comment:
Blend /*!Blendo*/
Otherwise my script and/or Moi get confused.
Dinos
aaaaaaaaaaaaaaaaaaaaaaaaaaaaah!!!!!!!!!!!!!!
All is fine now! Bravo!
Hi dino!
You use this sign "!" to pick the commands for your palette. In your script I have seen some of this sign.
Can i change this signs for example in to "?" or other?
Then copy and rename your script "Script Palette 2" to make different category of caommands.
I am not a programmer. May be this is a way.
Thanks for your work!!
Hopefully, Hans
Hi Hans!
I havent tried it, but yes it should work as you describe.
Just change the ! at line 22 in the second copy of the script to something else:
title = line.match(/\/\*\!(.+)\*\//);
Its escaped so you should be fine with most symbols.
I wrote this script primarily for me, and released it in case someone else needed a relatively simple way to keep their scripts in a palette. The Shortcut Keys panel inside Options is hardcoded and cannot be altered so i used the ! sign to emulate a check box next to each command. In my mind the ! sign is actually a check box saying "include in the palette" ;-)
I could replace the ! with !1, !2 etc for multiple categories, but there a few issues that i'll have to think about such as naming the categories, passing parameters to the script etc.
If i can find some free time i might give it a shot.
In the meantime what you are describing is the best way to do it.
Dinos
Cool trick!
Excellent!
Nothing but as you can see above the button is not centered ! ;)
So does exist some code for resolve this very very very little disturb ? :)
That's normal that buttons on dialogs in MoI are not centered, that's because it looks weird on larger dialogs. See for example the Close button on Options dialog. This dialog is just using the same thing.
Thx for the info!
dinos,
thank you for your adwise.
thank you for making the test.
Hans
18-37
38-44
