Full Version: Majik Tutorial: Detergent Bottle
Show messages:  1-2  3-22  23-42  43-44
23 Aug 2013   [#43] In reply to [#42]
Thanks Oli, I hope you're able to complete the tutorial.
As for not being able to make the bottom area Planar, please look over the previous post: http://moi3d.com/forum/index.php?webtag=MOI&msg=5530.29
If the bottom profile curves are not flat, not touching, or not tangent, then Network may not make a surface with a planar edge.
If the curves are both tangent and touching, then you can make them flat in a side view by moving the handle bar until a tab says "Flat".
If nothing works, you can also Boolean Difference, or use Trim to cut a plane away from the bad edge.
Good luck!
23 Aug 2013   [#44]
great.that works.
thank you for the quick support Mike! :)
