17-36
37-44
Thx 4 super quick response , really appreciate it !
Awesome tutorial!!
Thank you guys! :-)
Yes, your tutorials are always great Mike. Thanks.
Thanks Rich!
And great work yourself! Very clever stuff.
An interactive online viewer just for fun.
thank you very much mike! great tutorial!
but i have a little problem ( Moi-Newbie) here: i am not able to add the bottom-surface with the planarfunction and i have no idea what i am doing wrong.
thanks in advance!
Oli
Flasche_01.3dm
Thanks Oli, I hope you're able to complete the tutorial.
As for not being able to make the bottom area Planar, please look over the previous post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5530.29
If the bottom profile curves are not flat, not touching, or not tangent, then Network may not make a surface with a planar edge.
If the curves are both tangent and touching, then you can make them flat in a side view by moving the handle bar until a tab says "Flat".
If nothing works, you can also Boolean Difference, or use Trim to cut a plane away from the bad edge.
Good luck!
great.that works.
thank you for the quick support Mike! :)
17-36
37-44
