Full Version: Majik Tutorial: Detergent Bottle
Show messages:  1-11  12-31  32-44
17 Nov 2012   [#32] In reply to [#31]
indeed Michael, but still, your explanation is great and not only serves me but can help others with the same issue.
thanks.
19 Nov 2012   [#33] In reply to [#2]
Hi Mike,
Great tut for a beginner I only get stuck on the ribbed side , where i have to deal with the FLOW things. I cannot find the flow command in the command reference ??
Can you give me some more detail about the FLOW command end its usage ..
Many thanks ... love MoI
Rik Bijl
19 Nov 2012   [#34] In reply to [#33]
The command Flow is only on the Beta V3 for PC or normal V 2.5 for Mac or Beta V3 for MAC
Here 3 little videos video about It (sorry in French but very visual :)
http://moiscript.weebly.com/enrobage-dobjet-v3.html
http://moiscript.weebly.com/enrobage-dun-tore-v3.html
http://moiscript.weebly.com/bonus.html
19 Nov 2012   [#35] In reply to [#33]
Hi Rik, Flow is new for v3 and hasn't been added to the documentation yet, I'm only going to focus on updating the documentation when all the features for v3 are complete, otherwise it's too easy to have to throw it out and start over again if there are any changes that happen during the beta.
There are some links collected for Flow examples and explanations here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4856.2
And a few other ones:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5130.5
http://moi3d.com/forum/index.php?webtag=MOI&msg=5097.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=3628.246
19 Nov 2012   [#36] In reply to [#35]
Wow! great tutorial.
19 Nov 2012   [#37] In reply to [#35]
Thx 4 super quick response , really appreciate it !
21 Nov 2012   [#38]
Awesome tutorial!!
21 Nov 2012   [#39] In reply to [#38]
Thank you guys! :-)
21 Nov 2012   [#40] In reply to [#39]
Yes, your tutorials are always great Mike. Thanks.
21 Nov 2012   [#41] In reply to [#40]
Thanks Rich!
And great work yourself! Very clever stuff.
An interactive online viewer just for fun.
23 Aug 2013   [#42]
thank you very much mike! great tutorial!
but i have a little problem ( Moi-Newbie) here: i am not able to add the bottom-surface with the planarfunction and i have no idea what i am doing wrong.
thanks in advance!
Oli
Flasche_01.3dm
23 Aug 2013   [#43] In reply to [#42]
Thanks Oli, I hope you're able to complete the tutorial.
As for not being able to make the bottom area Planar, please look over the previous post: http://moi3d.com/forum/index.php?webtag=MOI&msg=5530.29
If the bottom profile curves are not flat, not touching, or not tangent, then Network may not make a surface with a planar edge.
If the curves are both tangent and touching, then you can make them flat in a side view by moving the handle bar until a tab says "Flat".
If nothing works, you can also Boolean Difference, or use Trim to cut a plane away from the bad edge.
Good luck!
23 Aug 2013   [#44]
great.that works.
thank you for the quick support Mike! :)
