3-22
23-42
43-62
63-69
Thanks Michael. This version of EditNameDialog.htm definitely fixes the issue. I will include it with the script, until it the next beta/release version of Moi.
Even after that it might be useful for people using an older version of Moi.
So, here is the fully working version. I will include the instructions again for consistency.
Installation:
Just copy
EditNameDialog.htm and
LightingOptions.htm included in the zip file to your ui folder. Remember to rename/backup the existing files, just in case.
No need to create a preset for your current settings. A "My favorite" preset will be created automatically for you.
You can add a shortcut, if you like :
script: /* Opens Lighting Options Dialog */ moi.ui.createDialog( 'moi://ui/LightingOptions.htm' );
Usage:
Add will create a new preset from the current settings below.
Delete will delete the selected preset.
Update will update the selected preset to the settings below.
Thats it. Everything is saved and restored correctly between sessions in moi.ini.
Please post any bugs you might find.
LightingOptions.zip
Holy cow! Thank you, Mike!
No no... thank Dinos!
Dinos - Great job on this useful script! It's absolutely what I envisioned when I came up with this Lighting Options primer!
And thanks Michael for helping Dinos - I've enjoyed seeing this process of script development work out. Most of it is over my head, but intriguing none the less.
Thanks Mike!
The lighting options are a really nice feature of Moi, and i wouldn't have noticed it if it wasn't for your post.
This was my first attempt at writing a script for Moi. The javascript API is very complete and easy to use and made the process a pleasure.
I will definitely do more scripting for Moi in the future.
Dinos
Hi all!
I just added 7 additional Lighting Option experiments:
After a while, there is only so much you can do, until we get environment mapping and additional lights, but here I show how you can use (-) negative values for Key Fills, and values greater than the default slider's. Please let me know of any errors.
Just look near the start of this thread...
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.6
[Dinos, if you see this, please update the Lighting Options script, thanks!]
Here are a few dark and evil creations: Onyx, Velvet Night, Ornament
A couple of glossy options: Enamel, Clear Coat, Hi-Gloss Plastic
And here it is (I wish), Zebra Stipes... well, one curvy one: Should be useful.
Enjoy.
Hi Mike!
I love the new options!
Velvet Night is my personal favorite :-)
I've added the new Lighting Options to the script.
I've also updated the script to merge any new options (themes) defined in it with the existing/saved options. Makes it a lot easier to add new options.
LightingOptions.zip
Thanks Dinos, great work on the script!
Yes, just when I thought I found most of the major combinations, I discovered you could go below zero on the Key fill attributes.
Moon's lights!
Were would I find the UI folder on my Mac? Thanks!
Never mind found it!
You guys are the best! New toys to play with, and plenty of room to experiment! A big thank you to all of you who continue to help Michael reach the next level. And a special thank you to Michael for such a great program for us non techies to work with!
John
Hi dinos :)
I wanted to use your wonderful plugin, but after I followed all your instructions, I received an error. Please have a check to the attachment.
Would you help me?
Thank you in advance
Fabrizio
Hi Fabrizio.
I think you are using an old version of Moi3D which was based on Internet Explorer, which at that time lacked the JSON method. If you update to Moi3D version 2.52 or the current 3.0 beta the script should work fine.
I hope that helps. Please let me know how it goes.
Dinos
This don't run with moi3d v.3? I get only a small blue-strip with a X (for closing this wind Lighting Options Window) and nothing more happens ...
It seems to be working fine here on V3 (Using PC)
So I'm assuming that Dinos' file: "LightingOptions.htm" resides inside of V3's "ui" folder?
To call up the dialog from the Shortcut Keys list: code:
Hi Lordfox
I installed the lighting options last night in my new computer, and it did not work either, until I remembered the following:
Besides putting the lighting options htm file in the ui folder, it is necessary, one time only, in Moi version 3 screen, to select
options, then view, then Lighting options button.
tried today again - it dosn't run :( lighting options not found
snapshot also not run
but the other things are ok - costum ui
edit: after 8 months I can run it - I did delete the .DS-store file in the ui - because I copied there the htm and the second file
Added a simple configuration for basic Solid shading with no specular or shadows - great for graphics tracing of 3-D type and simple objects.
metallicLighting is shown as true in the script, and false in the picture. (This metallic setting does not seem to make any visual difference.)
For selection with CustomUI, I added the "Solid" lighting version to the custom LightingOptions.htm under ui.
It was necessary under MoI options, View, Lighting options, to update "Solid" selection.
Got it, and thanks!
3-22
23-42
43-62
63-69
