19-38
39-58
59-69
Hi dinos - re unsafe javascript error - I haven't happened to run across that one before, it looks like some security measure for anti-cross-site script usage that only kicks in for the script engines that have been created by an HTML page and not the other script contexts that are created when you run a shortcut key or command script for example.
I'll have to dig into that to see how to enable script access between 2 HTML script contexts like that.
In the meantime I guess you would have to make your own edit name dialog that might take the name in the URL query string rather than as a global script variable if you want to make an edit name dialog that would work off of a dialog right now.
Hi dinos, I've attached an updated version of EditNameDialog.htm that might work better for you.
This version fixes a bug where it was actually supposed to be possible to not initialize the name at all, that was not working before, and also now there is an alternate way to initialize the name by passing nameval=somename in the query string of the URL as well, like this:
function AddClicked() {
var name = 'This is the name';
var dialog = moi.ui.createDialog('EditNameDialog.htm?nameval=' + encodeURIComponent(name), '', moiWindow);
if (dialog.window.doModal() != -1) {
if (dialog.window.dialogReturnValue != '') {
var name = dialog.window.dialogReturnValue;
moi.ui.alert( name );
This should hopefully work for you for the moment until the cross-page script permission thing is fixed up.
EditNameDialog.htm
Hi dinos, so that cross-domain security error was a timing issue related thing, the same access would work later on once the page had proceeded loading a bit and had it's base URL updated to a
moi:// one.
Anyway for the next v3 beta I've got the cross-domain security checking mechanism turned off completely now and that should prevent this kind of inter-page script exception from happening anymore after that.
I really like this script... thanks...
Peace,
Rich_Art. ;-)
Thanks Michael. This version of EditNameDialog.htm definitely fixes the issue. I will include it with the script, until it the next beta/release version of Moi.
Even after that it might be useful for people using an older version of Moi.
So, here is the fully working version. I will include the instructions again for consistency.
Installation:
Just copy
EditNameDialog.htm and
LightingOptions.htm included in the zip file to your ui folder. Remember to rename/backup the existing files, just in case.
No need to create a preset for your current settings. A "My favorite" preset will be created automatically for you.
You can add a shortcut, if you like :
script: /* Opens Lighting Options Dialog */ moi.ui.createDialog( 'moi://ui/LightingOptions.htm' );
Usage:
Add will create a new preset from the current settings below.
Delete will delete the selected preset.
Update will update the selected preset to the settings below.
Thats it. Everything is saved and restored correctly between sessions in moi.ini.
Please post any bugs you might find.
LightingOptions.zip
Holy cow! Thank you, Mike!
No no... thank Dinos!
Dinos - Great job on this useful script! It's absolutely what I envisioned when I came up with this Lighting Options primer!
And thanks Michael for helping Dinos - I've enjoyed seeing this process of script development work out. Most of it is over my head, but intriguing none the less.
Thanks Mike!
The lighting options are a really nice feature of Moi, and i wouldn't have noticed it if it wasn't for your post.
This was my first attempt at writing a script for Moi. The javascript API is very complete and easy to use and made the process a pleasure.
I will definitely do more scripting for Moi in the future.
Dinos
Hi all!
I just added 7 additional Lighting Option experiments:
After a while, there is only so much you can do, until we get environment mapping and additional lights, but here I show how you can use (-) negative values for Key Fills, and values greater than the default slider's. Please let me know of any errors.
Just look near the start of this thread...
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.6
[Dinos, if you see this, please update the Lighting Options script, thanks!]
Here are a few dark and evil creations: Onyx, Velvet Night, Ornament
A couple of glossy options: Enamel, Clear Coat, Hi-Gloss Plastic
And here it is (I wish), Zebra Stipes... well, one curvy one: Should be useful.
Enjoy.
Hi Mike!
I love the new options!
Velvet Night is my personal favorite :-)
I've added the new Lighting Options to the script.
I've also updated the script to merge any new options (themes) defined in it with the existing/saved options. Makes it a lot easier to add new options.
LightingOptions.zip
Thanks Dinos, great work on the script!
Yes, just when I thought I found most of the major combinations, I discovered you could go below zero on the Key fill attributes.
Moon's lights!
Were would I find the UI folder on my Mac? Thanks!
Never mind found it!
You guys are the best! New toys to play with, and plenty of room to experiment! A big thank you to all of you who continue to help Michael reach the next level. And a special thank you to Michael for such a great program for us non techies to work with!
John
Hi dinos :)
I wanted to use your wonderful plugin, but after I followed all your instructions, I received an error. Please have a check to the attachment.
Would you help me?
Thank you in advance
Fabrizio
Hi Fabrizio.
I think you are using an old version of Moi3D which was based on Internet Explorer, which at that time lacked the JSON method. If you update to Moi3D version 2.52 or the current 3.0 beta the script should work fine.
I hope that helps. Please let me know how it goes.
Dinos
This don't run with moi3d v.3? I get only a small blue-strip with a X (for closing this wind Lighting Options Window) and nothing more happens ...
It seems to be working fine here on V3 (Using PC)
So I'm assuming that Dinos' file: "LightingOptions.htm" resides inside of V3's "ui" folder?
To call up the dialog from the Shortcut Keys list: code:
Hi Lordfox
I installed the lighting options last night in my new computer, and it did not work either, until I remembered the following:
Besides putting the lighting options htm file in the ui folder, it is necessary, one time only, in Moi version 3 screen, to select
options, then view, then Lighting options button.
19-38
39-58
59-69
